zoom window
rookie37
I'm better at script than writing at lisp although I'm not good at that either.
I want to get away from that and start converting my script macros into lisp
How do I write a zoom window lisp?
Below is script. It explains what I'm tring to do but I want it in lisp.
^C^Cz;w;.end;/.end;/
Also
I have written a simple code to change the line thickness of an entity.
Again, it is in script and isn't very good. I'd like to pick a line or (if I miss) draw a fence and sellect a group. How do I write this in lisp?
^C^C_CHANGE;\\;P;t;
Hi Rookie,
Would this suffice?
(defun c:zw ()
 (setvar "cmdecho" 0)
 (command "zoom"
 "w"
 pause
 pause
 ) ; end zoom
 (setvar "cmdecho" 1)
) ; end program
And for the width:
(defun c:polyw ()
   (if
       (setq obs (ssget))
               (command "_.pedit"
                   "M"
                   obs ""
                   "w"
                   pause
           ) ; end progn
   (alert "\nPlease Select Objects!")
   ) ; end if
) ; end program
Thank you for your prompt reply!
(defun c:zw () (setvar "cmdecho" 0) (command "zoom" "w" pause pause ) ; end zoom (setvar "cmdecho" 1) (princ)) ; end program
How do I make zoom window snap to endpoint before each pause
And for the width:
Code:
(defun c:polyw () (if (setq obs (ssget)) (progn (command "_.pedit" "M" obs "" "w" pause "" ) ) ; end progn (alert "\nPlease Select Objects!") ) ; end if (princ)) ; end program
As it is, it would still be a huge timesaver. How do I modify it so that I can also select an individual line?
For the zoom window to snap to endpoint, I suppose you could use this:
(defun c:zw ()
   (setq pt1 (getpoint "\nSelect First Window Point: "))
   (setq pt1 (osnap pt1 "_endp"))
   (setq pt2 (getpoint "\nSelect Second Window Point: "))
   (setq pt2 (osnap pt2 "_endp"))
     (command "zoom"
     "w"
   pt1
   pt2
     ) ; end zoom
) ; end program
Its not ideal though.
And for the Polyline width alteration, the LISP that I provided should enable you to select a single line, but if it is not what is desired then I am afraid that I do not have the knowledge to create such a LISP :(
I like this better.
(defun c:zw (/ pt1 pt2)
(if
  (and
   (setq pt1 (osnap pt1 "_end"))
   (setq pt2 (osnap pt2 "_end"))
   (command "._zoom" "_w" "_non" pt1 "_non" pt2) ; end zoom
) ; end program
Maybe this for Thickness:
(defun c:changeThickness (/ ss tk)
(prompt "\nSelect objects to change thickness:")
(if
  (and
    (setq ss (ssget))
    (setq tk (getdist "\nEnter a new thickness:"))
   (command "._change" ss "" "_P" "_T" tk "")
Just some ideas to play with.:)
Thanks for your input CAB, I couldnt work out how to put the 'end-point snap' before the pause and still get the program to work correctly, and so I resolved to put a point selection and use the points within the zoom command.
But as for the thickness, I used an 'ssget' syntax (as did you), but I am not sure if Rookie would like a selection similar to an 'entsel' selection pick-box...
Entsel it is.:)
(defun c:changeThickness (/ ent obj tk)
 (setvar "ErrNo" 0) ; reset variable
 (if (setq tk (getdist "\nEnter a new thickness:"))
   (while
     (cond
       ((and (null(setq ent (car (entsel "\nSelect object to change thickness:"))))
              (= 52 (getvar "ErrNo"))) ; <Enter> was hit
        (prompt "\nUser Quit.") ; Bye bye
       ((null ent)
        (princ "\nMissed, Try Again.")
       ((null (vlax-property-available-p
                (setq obj (vlax-ename->vla-object ent))
                'Thickness t))
        (princ "\nNo Thickness or locked layer. Try Again.")
       (t ; OK to update
        (vla-put-thickness obj tk)
        (princ "\nThickness updated.")
