wannabe Posted October 17, 2008 Posted October 17, 2008 Another question from me Having created a dimesnion style I want to try and set all of its values. e.g linetype bylayer. However I just can't find the information in the provided help file. thanks in advance Quote
ASMI Posted October 17, 2008 Posted October 17, 2008 1. You should draw some dimension (for ex. DIMLINEAR) and set all properties you need for this single dimension. 2. Add a new DimensionStyle to the DimensionStyles collection. 3. Use method CopyFrom for copy properties from the sample dimension to the DimensionStyle. Current dimension style is only set of system variables which controls new dimensions properties. Quote
NBC Posted October 17, 2008 Posted October 17, 2008 Use a similar syntax as listed below: ThisDrawing.SetVariable SysvarName, sysVarData where: SysvarName is the name of the variable you wish to set sysVarData is the value of the variable Quote
wannabe Posted October 17, 2008 Author Posted October 17, 2008 Excellent, thanks I'll try these when I get to work on Monday Quote
wannabe Posted October 20, 2008 Author Posted October 20, 2008 What I am trying to achiecve is the succesful creation of a new dimesnion style which will have values defined in my VBA macro for: - colour - Dim Lines Linetype - Dim Lines Lineweight - Ext line 1 - Ext Line 2 - Ext Line lineweight - Extend Beyond Dim lines - Offset from Origin Still having some difficulty with this. Quote
NBC Posted October 20, 2008 Posted October 20, 2008 If you already have your required Dimension Style setup in a drawing; type in _.sysvdlg at the command line. This will bring up a box with all your system variables in it. Now the fun bit to filter everything else out, apart from all the variables associated with dimensioning. In the top box on the left hand side; and before the * type in dim. Then hit the Save Filtered button; name your file according to something like dim_variables.svf Using Windows Explorer locate the file you just saved. Right click on it, and choose Open With. Try to select Notepad, or some other equivalent editing program. In the file that is opened you should now see all the variables that are associated with the dimension style. It should now be a simple process to incorporate all those settings into the sample code I posted earlier in this thread. Quote
ASMI Posted October 20, 2008 Posted October 20, 2008 Still having some difficulty with this. Look for my post #2 and this simplified example. It will draw sample aligned dimension in your drawing, creates "Wannabe_DimStyle" dimension style and copy proprties from sample dimension to your dimension style: Sub CreationDimStyle() Dim mSp As AcadModelSpace Dim sDim As AcadDimAligned Dim pt1(0 To 2) As Double Dim pt2(0 To 2) As Double Dim tPos(0 To 2) As Double Dim dCol As AcadDimStyles Dim nDim As AcadDimStyle ' Set poits to draw dimension pt1(0) = 0#: pt1(1) = 0#: pt1(2) = 0# pt2(0) = 0#: pt2(1) = 100#: pt2(2) = 0# tPos(0) = 50#: tPos(1) = 15#: tPos(2) = 0# 'Get Model Space Collection Set mSp = ThisDrawing.ModelSpace ' Add new sample aligned dimension Set sDim = mSp.AddDimAligned(pt1, pt2, tPos) [color="Blue"]' Set some dimension properties[/color] sDim.color = 1 sDim.Linetype = "BYBLOCK" sDim.Lineweight = acLnWt005 ' Get DimensionStyles collection Set dCol = ThisDrawing.DimStyles ' Erase old "Wannabe_DimStyle" dimstyle On Error Resume Next dCol.Item("Wannabe_DimStyle").Delete ' Add new "Wannabe_DimStyle" dimstyle Set nDim = dCol.Add("Wannabe_DimStyle") [color="#0000ff"]'Copy properties from sample dimension sDim to dimstyle nDim[/color] nDim.CopyFrom (sDim) ' Delete sample dimension sDim.Delete End Sub Look for all dimension properties in Developer Help articles. Quote
wannabe Posted October 21, 2008 Author Posted October 21, 2008 Ok, I am now getting close to my required targets for creating a dimension style; using an aligned dimension to copy the properties from. The problem I have is that I cannot locate any method or code that will allow me to set the linetype of the extension and dimension lines. Everything else is perfect. Quote
ASMI Posted October 21, 2008 Posted October 21, 2008 I cannot locate any method or code that will allow me to set the linetype of the extension and dimension lines. Yes this properties missed in Developer Help, therefore if you will look methods and properties of DimAligned in Object Browser you find DimensionLinetype, ExtLine1Linetype and ExtLine2Linetype properties. All used linetypes must be loaded with Load method before you will use it. Quote
