lisp file to create command to chprop to a specified layer
Hello everyone,
I tried to create a lisp file to change an object's layer to layer "0". I would like it to be "c0". I tried this and some variations of this but I can't get it to work. Please help to correct my code.
(defun c:c0()
(command "_chprop" pause "la " "0" " ")
I think:
(vl-cmdf "_.chprop" (ssget) "" "_la" "0" "")
thanks for the response. What does "vl-cmdf" do? How do I assign the code you gave me to the command "c0"?
to change a selection set
(defun c:c0 ()
 (setq ss1 (ssget))
 (command "change" ss1 "" "p" "la" "0" "")
to change one entity
(defun c:c0 ()
 (setq ent (entsel))
 (command "change" ent "" "p" "la" "0" "")
lpseifert,
Thanks for the response. The selection set one works just like I want it to. Thank you so much and have a great day.
The same as command but it checks syntax before execution (command can to run with wrong syntax) and return T in case of seccessfull ending (command always return NIL). Do not recomended to use intractive functions (as ssget) inside command expression. It reason that I use vl-cmdf in this case.
(defun c:c0()
