Results 1 to 9 of 9
    Senior Member
    AutoCAD 2007
    Apr 2008
    258
    Default Make Circle As Polyline
    Is There Any Way To Make Circle As Polyline So I Can Make It With Width I Need?
    Luminous Being tzframpton's Avatar
    tzframpton's Computer Details
    HP Zbook
    Multi-disciplinary
    tzframpton's Discipline Details
    BIM Specialist
    Multi-disciplinary
    Full Virtual Design and Construction BIM services for the MEP engineering and construction industries.
    Revit 2019
    Mar 2006
    Dallas, TX - USA
    9,117
    Don't do that... just start the POLYLINE command, then type A for Arc. when you do that, you can create a circle by simply using your POLAR tracking to make two "arcs". The width should be self explanatory after that.
    Tannar Z. Frampton ™ | Frampton & Associates, Inc.
    Forum Deity
    AutoCAD 2002
    Sep 2006
    East Sussex, U.K.
    4,137
    Or go for a Donut, which is a polyline circle with width
    Senior Member
    AutoCAD 2007
    Apr 2008
    258
    Thanks Guys For Your Help
  5. #5
    Super Member profcad's Avatar
    profcad's Computer Details
    Windows 7 Ultimate
    Dell
    Dual - Six-Core Xeon
    32GB
    NVIDA GeForce GTX980TI
    DUAL 24" WIDESCREEN
    Education
    profcad's Discipline Details
    Professor Of CAD
    Education
    AutoCAD Revit Inventor Soldiworks
    Revit 2018
    Dec 2005
    Oklahoma City, OK
    861
    Use the BOUNDARY command and pick a point inside the circle. AutoCAD will create a polyline on top of the circle.
    John Helton
    Professor of CAD
    Oklahoma City Community College
    Oklahoma City, OK
  6. #6
    Senior Member BOB'27T's Avatar
    BOB'27T's Computer Details
    Dell Precision 690
    Dual 21" Dell
    Civil 3D 2009
    Sep 2007
    Tavares,Florida
    416
    Here's another option Adding global width to a circle
    Here's a little trick I learned a while back. I needed to add thickness to a circle & found a slick way to do it. Here goes: Start by making a polygon with 4 sides. Check inscribed in circle when prompted. Next specify your radius. That will create a square. Then select polyline edit, then select fit, then width. Tah Dah! You have a circle with a global width!
    "Those Who Pay Attention Will Be Rewarded"
  7. #7
    Senior Member mugshot's Avatar
    AutoCAD 2008
    Jun 2008
    papua new guinea
    240
    start w/ polyline, set width. w ( upon your choice) then arc.
  8. #8
    AutoCAD 2008
    Jun 2008
    papua new guinea
    240
    or make a polyline that is set upon a width then matchprop the line to your created circle.
  9. #9
    Senior Member bonehead411's Avatar
    Multi-disciplinary
    bonehead411's Discipline Details
    Drawing Office Manager - Manufacturing
    Multi-disciplinary
    Odour Control, Chemical Storage, Scrubbers/Quench Columns, Piping, Ducting, Tanks, Vessels
    not applicable
    Jan 2007
    Sutton Fields, Hull, East Yorkshire, England
    219
    Quote Originally Posted by profcad View Post
    Oh now that's a beauty! Cheers prof.
  1. Join 2d polyline to 3d polyline
    By Tconn in forum AutoCAD Drawing Management & Output
    Last Post: 12th Jul 2007, 05:59 pm
  2. Iintersecting polyline with a circle
    By BIGAL in forum AutoLISP, Visual LISP & DCL
    Last Post: 10th Mar 2006, 03:10 am
  3. can extrude a open polyline to make a polymesh?
    By 3ding in forum AutoCAD 3D Modelling & Rendering
    Last Post: 5th Aug 2005, 02:15 pm
  4. Extruding Circle along polyline
    By dreamer in forum AutoCAD 3D Modelling & Rendering
    Last Post: 9th May 2005, 10:12 pm
  5. Line from inner circle to outer circle
    By jocaan in forum AutoCAD Beginners' Area
    Last Post: 11th Mar 2004, 09:28 pm
