ajs Posted December 1, 2008 Share Posted December 1, 2008 I have a situation in which I need to extract the coordinate of a circle's centerpoint in order to make a decision. This information needs to be extracted without user input during the course of a lisp. There is never more than 1 circle and additionally, it is on it's own layer. I don't currently have the skill to know where to go to extract this information. If anyone can point me in the proper direction, that would be appreciated. Thank You. AJS Quote Link to comment Share on other sites More sharing options...
CAB Posted December 1, 2008 Share Posted December 1, 2008 Change to your layer name. (defun c:test( / ss CenterPoint) (and (setq ss (ssget "X" '((0 . "CIRCLE")(8 . "Layer Name")))) (setq CenterPoint (cdr(assoc 10 (entget (ssname ss 0))))) ) (princ) (princ CenterPoint) (princ) ) Quote Link to comment Share on other sites More sharing options...
ajs Posted December 1, 2008 Author Share Posted December 1, 2008 Thank you. I'm going to look this over and learn from it. AJS Quote Link to comment Share on other sites More sharing options...
CAB Posted December 1, 2008 Share Posted December 1, 2008 Here is more explination. (defun c:test( / ss CenterPoint) (prompt "\nLooking for a circle center point.") (and ; keep evaluating as long as the return values are NOT NILL (setq ss (ssget "X" ; "X" will look in the entire DWG ;; filter is next, AND is implied '((0 . "CIRCLE") ; only get Circle objects (8 . "Layer Name") ; only get objects on this layer ))) (setq CenterPoint (cdr ; return the list without the first item (assoc 10 ; return the list that starts with 10 (entget ; get the entity list from the entity name (ssname ss 0) ; get the first entity name in the selection set )))) ) (print) ; Prints an expression to the command line with a New Line Character ;; in this case it advances to the next command line (princ CenterPoint) ; Prints an expression to the command line (princ) ; clear the return value so nothing else is echoed to the command line ) Quote Link to comment Share on other sites More sharing options...
ajs Posted December 2, 2008 Author Share Posted December 2, 2008 Thanks for the extra info. This is an area that I want to learn more about and your explantion helps me along ---AJS Quote Link to comment Share on other sites More sharing options...
