Wise Posted December 4, 2008 Share Posted December 4, 2008 I work in a industry that has been primarily accustom to 2D drafting drawings since the beginning of autocad, recently we have moved into designing entire projects in 3D, Line types have been something that we used for aesthetic reasons, to differentiate wall lines from Center Lines, but now with the future of 3D design this does not work, so here is my question! Is there ANY way to get 3D poly lines to show its line type rather then a solid line? Thanks: D Quote Link to comment Share on other sites More sharing options...
Secretagdan Posted December 4, 2008 Share Posted December 4, 2008 What exactly do you do? The majority of my drawings are completed initially in 3d, and then broken down into 2d drawings for production. Doing this, I get to use all of my line-types that are needed to express drawings. You may look into using the SOLVIEW & SOLDRAW commands to get all of the views that you want. Quote Link to comment Share on other sites More sharing options...
Wise Posted December 4, 2008 Author Share Posted December 4, 2008 I work in mining, so we design the entire mine in 3D, so I with rathern ot have to "break" down the drawing everytime Quote Link to comment Share on other sites More sharing options...
CarlB Posted December 4, 2008 Share Posted December 4, 2008 I don't have an answer, just an observation- if you explode the 3dpolyline to lines, then the linetype will display. I believe you're correct, not possible for 3dpolylines to display other than continuous. Quote Link to comment Share on other sites More sharing options...
Wise Posted December 4, 2008 Author Share Posted December 4, 2008 yea that works but its a lot of work for making some prints, also the ramp tends to be 1 LONG 3d Polyline and does not work well when explodeing it, I dident think there was a real solution thought i would ask thanks Quote Link to comment Share on other sites More sharing options...
whitemarlin Posted December 4, 2008 Share Posted December 4, 2008 Modify-Object-Polyline Select the polyline type "L" for Ltype gen and turn this option ON Quote Link to comment Share on other sites More sharing options...
Secretagdan Posted December 4, 2008 Share Posted December 4, 2008 That answers that. Unfortunately, I do not know how to change line types like that, though seeing the lines at different angles; it may change the spacing depending on the view angle. Are you using hidden viewports, or is everything 2d wire-frame? Quote Link to comment Share on other sites More sharing options...
MaxwellEdison Posted December 4, 2008 Share Posted December 4, 2008 Modify-Object-PolylineSelect the polyline type "L" for Ltype gen and turn this option ON That works for a standard 2d polyline, and can be accessed through the properties palette. This option does not work for 3d polylines however. At this point I am not aware of anyway to make a 3d polyline generate a linetype. Quote Link to comment Share on other sites More sharing options...
Wise Posted December 4, 2008 Author Share Posted December 4, 2008 I am using, 3D polylines, 3D mesh, 3D solids, very little of my drawing is done in 2D, basically its the 3D Poly lines that I have trouble with, the entire Mine is Drawn in 3D then each level (layout) is a cliped part of that mine ie 4000Level, 5000level, 6000Level ect, all the lines, wall lines, and centerlines are 3D polys Quote Link to comment Share on other sites More sharing options...
MaxwellEdison Posted December 4, 2008 Share Posted December 4, 2008 Is there any reason they cannot be replaced with 2d lines drawn along different axes? Quote Link to comment Share on other sites More sharing options...
