Sudan Posted January 23, 2009 Share Posted January 23, 2009 Newbie here, I'm making a ceramic floor tile design. Thanks to people on this forum I can perform the scale command on a single object. I now want to scale multiple objects all at once. My drawing is a chess board, simple grid of 1" squares on layer "CHESS". At every intersection of each four squares, where their corners meet up, i.e., the lines cross, I have one small decorative hexagon of 1/4" on the side. The center of each of these small 1/4" hexagons is exactly on the intersections of the big 1" squares. All and only these small decorative hexagons are on their own layer "HEXA". I want to scale the small decorative hexagons from 1/4" on the side down to 1/8" on the side. I was able to QSELECT all the objects in layer HEXA. I was then able to scale down all at once to the correctly desired new size of 1/8" on the side BUT! (you knew this was coming) The centers of each hexagon moved. Each moved closer to the particular hexagon object that I performed the SCALE command on. It was as if the position of the selected hexagons got scaled too. I know I can perform SCALE command on each object by itself and get to where I want to be. I just want to know if I can do this on multiple selected objects at once and have the scaled objects maintain their center point after scaled. Thank you. Quote Link to comment Share on other sites More sharing options...
Dipali Posted January 23, 2009 Share Posted January 23, 2009 May be A LISP can do which I know nothing about. for this type of situation I usally create a block of the hexagone with center as block insertion point instead of using simple hexagone. & insert it every where and than when I need to resize I can select them thru filter & change the scale in the property, ot simply edit the block & it updates all without moving it. Quote Link to comment Share on other sites More sharing options...
dbroada Posted January 23, 2009 Share Posted January 23, 2009 I would do it Dipali's way too using a block but I would tend to redefine the block rather than scale it. Quote Link to comment Share on other sites More sharing options...
ReMark Posted January 23, 2009 Share Posted January 23, 2009 Sudan: Look through this list of scale related lisp routines. Maybe there is one that will work in this particular situation. http://cadtips.cadalyst.com/node/tiplisting?keywords=scale%20multiple Quote Link to comment Share on other sites More sharing options...
darn-net Posted January 23, 2009 Share Posted January 23, 2009 I personally like and use the block method. There are several ways to do this. Here's a list. Make the object a block. Redefine block. Make the object a block. Create selection set using grips. Change X/Y scale factors with properties manager. Make the object a block. Insert the block using MINSERT. Select the MINSERT array using grips. Change the X/Y scale using properties manager. Scale them using a lisp program. (Like the one 'ReMark' pointed to can't wait to try it out) Erase all except one. Change object size. Re-array the object. Scale each object individually. If neccessary the MULTIPLE command could be used to save a few clicks. I Stopped at (6). Are there more, anyone? Dave ---- "Most of what I know came from the "F1" key" Quote Link to comment Share on other sites More sharing options...
dbroada Posted January 23, 2009 Share Posted January 23, 2009 7. Select them all (QSELECT) and change their scale in the properties palette. Quote Link to comment Share on other sites More sharing options...
darn-net Posted January 23, 2009 Share Posted January 23, 2009 Would (7.) be the same as (2.) or are you saying there's a way to do this without being a block? Do I hear an (8.)? I've only tinkered with them but is there a dynamic block method? Dave ---- "Most of what I know came from the "F1" key" Quote Link to comment Share on other sites More sharing options...
dbroada Posted January 23, 2009 Share Posted January 23, 2009 Would (7.) be the same as (2.) or are you saying there's a way to do this without being a block? Do I hear an (8.)? I've only tinkered with them but is there a dynamic block method? Dave ---- "Most of what I know came from the "F1" key" I guess so, what is properties manager? This one isn't really suitable for dynamic blocks. With a dynamic block you create a single block with many variations. You would still need to change them to display how you want. Where they would be good is if the pattern is comprised of (say) 4 different tiles. Then you could tweak each tile individually without affecting all the others. Quote Link to comment Share on other sites More sharing options...
Jaelin Posted January 23, 2009 Share Posted January 23, 2009 If they are blocks: In Civil 3D Land Desktop Companion 2009 I have a command under my Utilities/Edit Menu that is Rescale Blocks/Text. This command scales everything in place by a certain scale factor. I'm just not sure if this a standard AutoCAD command or a LDC command. I'm thinking it may be a LDC command only but not sure. This command is what I use to scale my blocks or text. Quote Link to comment Share on other sites More sharing options...
darn-net Posted January 23, 2009 Share Posted January 23, 2009 dbroada I should have said "Properties Palette" not "Properties Manager". My bad. If they are blocks: In Civil 3D Land Desktop Companion 2009 I have a command under my Utilities/Edit Menu that is Rescale Blocks/Text. This command scales everything in place by a certain scale factor. I'm just not sure if this a standard AutoCAD command or a LDC command. I'm thinking it may be a LDC command only but not sure. This command is what I use to scale my blocks or text. Jaelin What command is shown on command line when you run this "Rescale Blocks/Text"? ---- "Most of what I know came from the "F1" key" Quote Link to comment Share on other sites More sharing options...
Jaelin Posted January 23, 2009 Share Posted January 23, 2009 Jaelin What command is shown on command line when you run this "Rescale Blocks/Text"? No command shows up. I can't find a command input for it. Quote Link to comment Share on other sites More sharing options...
Sudan Posted January 23, 2009 Author Share Posted January 23, 2009 Thank you to everyone. This is a great and very helpful forum. 5.Erase all except one. Change object size. Re-array the object. This is what I did. It fits in with my current skill level, just above zero. Thanks to everyone for pointing the way. I will next learn about blocks as that seems very promising from the view point of my begining familiarity. If they are blocks: In Civil 3D Land Desktop Companion 2009 I have a command under my Utilities/Edit Menu that is Rescale Blocks/Text. This command scales everything in place by a certain scale factor. I'm just not sure if this a standard AutoCAD command or a LDC command. I'm thinking it may be a LDC command only but not sure. This command is what I use to scale my blocks or text. I don't know what "Civil 3D Land Desktop Companion 2009" is. But it sounds promising. After teaching myself Blocks, I will refer back to this. Quote Link to comment Share on other sites More sharing options...
TimZilla Posted January 18, 2011 Share Posted January 18, 2011 Newbie here, I'm making a ceramic floor tile design. Thanks to people on this forum I can perform the scale command on a single object. I now want to scale multiple objects all at once. My drawing is a chess board, simple grid of 1" squares on layer "CHESS". At every intersection of each four squares, where their corners meet up, i.e., the lines cross, I have one small decorative hexagon of 1/4" on the side. The center of each of these small 1/4" hexagons is exactly on the intersections of the big 1" squares. All and only these small decorative hexagons are on their own layer "HEXA". I want to scale the small decorative hexagons from 1/4" on the side down to 1/8" on the side. I was able to QSELECT all the objects in layer HEXA. I was then able to scale down all at once to the correctly desired new size of 1/8" on the side BUT! (you knew this was coming) The centers of each hexagon moved. Each moved closer to the particular hexagon object that I performed the SCALE command on. It was as if the position of the selected hexagons got scaled too. I know I can perform SCALE command on each object by itself and get to where I want to be. I just want to know if I can do this on multiple selected objects at once and have the scaled objects maintain their center point after scaled. Thank you. I have one that will let you select a block. then you can either scale all blocks in the drawing in place, or highlight a part of the drawing without isolating and it will scale only that block you want. but, without it being a block, this lisp routine would somehow have to determine the center point of all the objects you selected. I just don't see that happening. I pray that someone is smart enough to make this, because I have needed it a few times. Always remember to make blocks! I have been burned a few times by not doing so! Quote Link to comment Share on other sites More sharing options...
TJKawaguchi Posted April 11, 2016 Share Posted April 11, 2016 To fix this, I edited the block and moved the center of the block to 0,0. Originally the first attribute (of 4) was at 0,0. Then when I scaled them from 192 to 96 they were all in the right place. Quote Link to comment Share on other sites More sharing options...
BIGAL Posted April 12, 2016 Share Posted April 12, 2016 Another method delete all items except 1 at bottom left, rescale then just use ARRAY all done no need for a lisp. Quote Link to comment Share on other sites More sharing options...
