BigMikeLV Posted January 26, 2009 Share Posted January 26, 2009 When you hover over a location defined in your surface and stations you get a pop-up that states you Station, location and your spot elevation. How do I turn this back on? I lost it and I'm sure someone turned it off. Is it a Setvar or is it in a dialog box somewhere? Quote Link to comment Share on other sites More sharing options...
lpseifert Posted January 26, 2009 Share Posted January 26, 2009 In Prospector select your Alignment (or surface...) rt-clk > Properties > Information > Show Tooltips check box Quote Link to comment Share on other sites More sharing options...
BigMikeLV Posted January 26, 2009 Author Share Posted January 26, 2009 They are already checked. Quote Link to comment Share on other sites More sharing options...
rustysilo Posted January 26, 2009 Share Posted January 26, 2009 Did the alignment go bye bye? Quote Link to comment Share on other sites More sharing options...
BigMikeLV Posted January 26, 2009 Author Share Posted January 26, 2009 the alignment is still there, all 4 of them. So is the Surface. Quote Link to comment Share on other sites More sharing options...
lpseifert Posted January 26, 2009 Share Posted January 26, 2009 Maybe they're turned off globally, try this Settings > Rt-clk on drawing name > Edit drawing settings > Ambient Settings > expand General > Show Tooltips > yes Quote Link to comment Share on other sites More sharing options...
rustysilo Posted January 26, 2009 Share Posted January 26, 2009 And if that works, LOCK IT in the ON position. :wink: Quote Link to comment Share on other sites More sharing options...
