bagulhodoido Posted January 29, 2009 Posted January 29, 2009 Is there any way to undo a whole lisp in a single command? I usually use lisps which do major changes on the drawing and undoing them sometimes takes a long time since each step of the lisp needs to be undone at a time. I wish I could undo all the lisp actions in a single command. Also, another request, probably not regarding lisps, but, I usually need to make tables with materials list and stuff, related to the projects. Is there any way to fix a view of the model, like, I place the view over the table, call it TABLEVIEW. And everytime I need to see it I just call it like, GO-TABLEVIEW and it automatically goes back to that saved view... That would really speed my work up. Specially when the tables are complex and full of data which always slow down the pan and zoom process. Thanks for your attention Quote
TimSpangler Posted January 29, 2009 Posted January 29, 2009 for your first question use these, one at the begin and one at the end. (command "-undo" "BEGIN") (command "-undo" "END) Quote
bagulhodoido Posted January 29, 2009 Author Posted January 29, 2009 right after the DEFUN line? and right before the last ")" ??? btw, I copied this code from this thread: http://www.cadtutor.net/forum/showthread.php?t=29445&highlight=Lot+area (defun c:LA () ;(/ cl txtst txtsz oldecho oldsnap B ac sf kw) (command "-undo" "BEGIN") (setq temperr *error*);store *error* (setq *error* errortrap);reassign *error* (setq cl (getvar "clayer") txtst (getvar "textstyle") txtsz (getvar "textsize") oldecho (getvar "cmdecho") oldsnap (getvar "osmode") );setq (setvar "cmdecho" 0) (command "-style" "SIMPLEX" "simplex.shx" "0" "0.9" "0" "n" "n" "n") (setq ip (getpoint "\nPick internal point: ")) (command "-layer" "m" "calc" "c" "63" "calc" "p" "n" "calc" "") (command "-boundary" ip "") (command "region" (entlast) "") (setq b (entlast)) (command "area" "o" b) (setq ac (strcat (rtos (/ (getvar "area") 10.76) 2 3) " Sq.m.")) (setq sf (strcat (rtos (getvar "area") 2 2) " m²")) (setq per (strcat (rtos (getvar "perimeter") 2 2) " m")) (command "-layer" "m" "LOT-AREA" "c" "53" "" "") (command "text" "s" "simplex" "c" ip (* 3 (getvar "dimscale")) "0" sf ) (command "text" "" per) (initget "Yes No") (setq kw (getkword "\nErase boundary Yes/No? ")) (if (= kw nil) (command "erase" b "") ) ;if (command "textstyle" txtst) (setvar "clayer" cl) (setvar "textsize" txtsz) (setvar "cmdecho" oldecho) (setvar "osmode" oldsnap) (setq *error* temperr) (princ) (command "undo" "END") );defun c: ;==========ERROR TRAP================= (defun errortrap (msg) ;define function (setvar "textstyle" txtst) (setvar "textsize" txtsz) (setvar "clayer" cl) (setvar "cmdecho" oldecho) ;restore variables (setvar "osmode" oldsnap) (setq *error* temperr) ;restore *error* (prompt "\nResetting System Variables ") ;inform user (princ) );defun ;==========ERROR TRAP================= (prompt "\nLotArea.lsp loaded, type LA to run") (princ) Quote
Lee Mac Posted January 29, 2009 Posted January 29, 2009 You can use the undo "begin" and "end" to envelope sections in which objects are modified - so not necessarily at beginning and end, but experiment with them and use them to best suit your needs. Quote
lpseifert Posted January 29, 2009 Posted January 29, 2009 right after the DEFUN line? and right before the last ")" ??? That code sure looks familiar... http://www.cadtutor.net/forum/showthread.php?t=29445&highlight=Lot+area Quote
Lee Mac Posted January 29, 2009 Posted January 29, 2009 You seem to remember the code a lot more when you work on them yourself Quote
bagulhodoido Posted February 3, 2009 Author Posted February 3, 2009 Oh I'm sorry for that. That's not my job, I took that code from the forums, and I didn't knew who did it.. My bad... really sorry... btw, no code I post here will be mine, I suck at it, it would be all wrong anyway. Quote
bagulhodoido Posted February 3, 2009 Author Posted February 3, 2009 I just can't get it right... If my needs would be just hitting ctrl + z once after the command LA, the whole thing got undone, where should I put the UNDO BEGIN and END? I keep swaping them from place to place and It simply doensn't make any difference. Quote
