So, I understand how to re-size an array and have even done it; but I have this case (attached), where I cannot seem to re-size the array. I basically have a dynamic array that I can re-size once, by removing the first item (zero item); but I then want to re-size this array again to get rid of the empty strings. However, I have tried every possible option I know of and I cannot seem to get it. I have even tried, just for kicks to stick actually numbers in there (as opposed to calculated values) and I still have no luck.
The two methods I have tried is hard coding in the following:
ReDim intFirstBlank As Integer
I then tried to do a loop of a procedure, designed to remove items from arrays and what I used to re-size the array at the first time.
Could someone take a look at it?
I am especially confused at why I can re-size it once; but not again.
Thanks,
Chris
Test.zip
Try to change the next part of code, e.g.:
AdjustArray:
  Do While (UBound(MyArray) >= intFirstBlank)
  ArrayRemoveItem MyArray, UBound(MyArray)
  ReDim Preserve MyArray(0 To UBound(MyArray) - 1)
  Loop
Not tested though
~'J'~
too much code to sift thru at the moment, but several places id start: 1) Dimming a dynamic array as a constant 2)passing a real array off to a sub as a safearray 3) using the undimmed "File" variable to step thru the results of the reduced array 4) seeding a list box with one huge string rather than adding individual items 5) dimming the array with an LBOUND of 0, but seeding the listbox with only item 1 of the array.
Some quick code for removal of array items:
'- snip-----------snip-----------
Sub main()
Dim maxarray As Long: maxarray = 5
ReDim MyArray(0 To maxarray)
Debug.Print "Seeding array"
For i% = LBound(MyArray) To UBound(MyArray)
MyArray(i%) = String$(i% + 1, Chr$(65 + i%))
Debug.Print i%, MyArray(i%)
Next i%
For j% = 1 To 3
Debug.Print "Erasing first array item"
' erase item 0
For i% = LBound(MyArray) To UBound(MyArray) - 1
MyArray(i%) = MyArray(i% + 1)
Next i%
maxarray = maxarray - 1
ReDim Preserve MyArray(0 To maxarray)
Next j%
End Sub
