tomg Posted February 12, 2009 Share Posted February 12, 2009 I never have given up, but after weeks of trying to figure out how to get them back, I have not been able and now I ask, HOW DO I GET THIS BACk? It is the menu bar with the tabs above the command line which you turn on and off and reference line weight. Quote Link to comment Share on other sites More sharing options...
rkmcswain Posted February 12, 2009 Share Posted February 12, 2009 The Drawing status bar is above the command line, and the application status bar is below the command line (by default). The application status bar contains the SNAP, GRID, ORTHO, etc. buttons. Do you have CLEANSCREEN enabled? This will hide these buttons. They can also be turned on/off individually using this menu in the lower right corner. Quote Link to comment Share on other sites More sharing options...
tomg Posted February 12, 2009 Author Share Posted February 12, 2009 The Drawing status bar is above the command line, and the application status bar is below the command line (by default). The application status bar contains the SNAP, GRID, ORTHO, etc. buttons. Do you have CLEANSCREEN enabled? This will hide these buttons. They can also be turned on/off individually using this menu in the lower right corner. [ATTACH]10115[/ATTACH] No I understand clean screen. I do not have the blue icon to right of pull down arrow in right lower corner Quote Link to comment Share on other sites More sharing options...
rkmcswain Posted February 12, 2009 Share Posted February 12, 2009 I do not have the blue icon to right of pull down arrow in right lower corner It's not the blue icon, it's the tiny black triangle. The blue icon is CLEANSCREEN. Quote Link to comment Share on other sites More sharing options...
tomg Posted February 12, 2009 Author Share Posted February 12, 2009 The Drawing status bar is above the command line, and the application status bar is below the command line (by default). The application status bar contains the SNAP, GRID, ORTHO, etc. buttons. Do you have CLEANSCREEN enabled? This will hide these buttons. They can also be turned on/off individually using this menu in the lower right corner. [ATTACH]10115[/ATTACH] I believe my proble is in the registry. I have had a lot of problems since computer was reformatted Quote Link to comment Share on other sites More sharing options...
tomg Posted February 12, 2009 Author Share Posted February 12, 2009 It's not the blue icon, it's the tiny black triangle.The blue icon is CLEANSCREEN. the triangle only gives me three choices auotscaling visible annotation & annotatiopn scale Quote Link to comment Share on other sites More sharing options...
rkmcswain Posted February 12, 2009 Share Posted February 12, 2009 the triangle only gives me three choices auotscaling visible annotation & annotatiopn scale LT must be different then, and I don't have a copy of LT at the moment at which to look. Quote Link to comment Share on other sites More sharing options...
jhhsbcglobal Posted May 10, 2010 Share Posted May 10, 2010 Hello! I too have autocad Lt and my osnap, ortho, etc option keys have gone missing from my application status bar! The only thing that displays there now is annotation scale. If I click on the black arrow, I only get three options - all dealing with scale. Has anyone figured out how to get them back? FYI, I am running it on windows 7. It was working for a while and then vanished all of a sudden. If I am unable to get these buttons back, how can I enable ortho and osnap? Is there another shortcut? I cannot seem to find ortho anywhere. I don't know how to turn it off. Many thanks! Quote Link to comment Share on other sites More sharing options...
Ryder76 Posted May 10, 2010 Share Posted May 10, 2010 ortho toggle is F8 osnap F3 on off toggle - Tools menu to for settings Quote Link to comment Share on other sites More sharing options...
Ryder76 Posted May 10, 2010 Share Posted May 10, 2010 From the help file: ALT+F11 Displays the Visual Basic Editor ALT+F8 Displays the Macros dialog box CTRL+0 Toggles Clean Screen CTRL+1 Toggles Properties palette CTRL+2 Toggles DesignCenter CTRL+3 Toggles the Tool Palettes Window CTRL+4 Toggles Sheet Set Manager CTRL+6 Toggles dbConnect Manager CTRL+7 Toggles Markup Set Manager CTRL+8 Toggles the QuickCalc calculator palette CTRL+9 Toggles the command window CTRL+A Selects objects in drawing CTRL+****F+A Toggles Groups CTRL+B Toggles Snap CTRL+C Copies objects to Clipboard CTRL+SHIFT+C Copies objects to Clipboard with Base Point CTRL+D Toggles Dynamic UCS CTRL+E Cycles through isometric planes CTRL+F Toggles running object snaps CTRL+G Toggles Grid CTRL+H Toggles PICKSTYLE CTRL+I Toggles COORDS CTRL+J Repeats last command CTRL+L Toggles Ortho mode CTRL+M Repeats last command CTRL+N Creates a new drawing CTRL+O Opens existing drawing CTRL+P Prints current drawing CTRL+R Cycles layout viewports CTRL+S Saves current drawing CTRL+SHIFT+S Brings up the Save As dialog box CTRL+T Toggles Tablet mode CTRL+V Pastes data from Clipboard CTRL+SHIFT+V Pastes data from Clipboard as a Block CTRL+X Cuts objects to Clipboard CTRL+Y Cancels the preceding Undo action CTRL+Z Reverses last action CTRL+[ Cancels current command CTRL+\ Cancels current command CTRL+PAGE UP Moves to the next layout tab to the left of the current tab CTRL+PAGE DOWN Moves to the next layout tab to the right of the current tab F1 Displays Help F2 Toggles Text Window F3 Toggles OSNAP F4 Toggles TABMODE F5 Toggles ISOPLANE F6 Toggles UCSDETECT F7 Toggles GRIDMODE F8 Toggles ORTHOMODE F9 Toggles SNAPMODE F10 Toggles Polar Tracking F11 Toggles Object Snap Tracking F12 Toggles Dynamic Input Quote Link to comment Share on other sites More sharing options...
jhhsbcglobal Posted May 10, 2010 Share Posted May 10, 2010 Thanks for your response. Now I have an even dumber question. Because I am working on a laptop, when I hit F3, my computer displays my battery life. Do you know how to disable that to get ortho/osnap to work? Many thanks again! Quote Link to comment Share on other sites More sharing options...
bick421 Posted October 18, 2010 Share Posted October 18, 2010 I never have given up, but after weeks of trying to figure out how to get them back, I have not been able and now I ask, HOW DO I GET THIS BACk? It is the menu bar with the tabs above the command line which you turn on and off and reference line weight. set variable "STATUSBAR" = 1 Quote Link to comment Share on other sites More sharing options...
