error: bad argument type: point: nil
au-s
Hello,
I have a lisp which writes MTEXT in different scales.
It looks like this
(defun C:MTEXT5 (/ oldlay)
 (setq oldlay (getvar "clayer"))
 (vl-load-com)
 (setvar "cmdecho" 0)
 (if (not (tblsearch "LAYER" "A-------T2-------B"))
           (command "-layer" "M" "A-------T2-------B" "C" "red" "A-------T2-------B" "")
           (setvar "clayer" "A-------T2-------B")
           ) ; end if
   (Describe)
(load "K:\\CAD\\AIX-meny-2008\\Lisp\\text\\TextVariables.lsp")
(RegularText)
(text5)
(setvar "cmdecho" 1)
(setq PT1 (getpoint "\n First Point :"))
(setq PT2 (getcorner PT1 "\n Second Point :"))
 (initdia)
(command "mtext" PT1 PT2)
(setvar "clayer" oldlay)
 ); end
In the same file you have 20 such copies of those rows.
The difference is (text5). I get the variable from another lisp and load only the textsize.
Now...
Every single (textX) works except for one.
The command MTEXT10 which have (text10) function.
If I executeit via my mnu-file (my menu) it returns this:
When I type the command in the command: prompt it works...
Really strange .. why is that so?
(defun RegularText ()
 (if (not (tblsearch "style" "AIX_ISO"))
   (C:AIXTXT)
(defun text5 ()
(command ".style" "" "" "15" "" "" "" "")
(defun text10 ()
(command ".style" "" "" "30" "" "" "" "")
It all worked before ..
Suddenly it stopped :)
And only for the mtext10 command.
mtext1 to mtext200 is working alltight.
mtext10 works only from the command: not from the menu.
Hmmm... that is weird.. if it works for text5 and not text10 - they look almost identical (apart from the 30 obviously).
Well, its hard to tell what can be going wrong, but I would recommend localising your variables.
The error thats occurring indicates to me that one of your point selections is nil when using the mtext, so I would localise the pt1 pt2 so that no other values are carried over when the function is repeated.
But I can't really see what else could go wrong... :(
