The Buzzard Posted March 3, 2009 Share Posted March 3, 2009 Hello everyone, I need some help with this. I have a popup list in a dialog. I want to change the contents of the popup list from one list to another list depending on the selection thru a radio button. Another words, When a different selection of a radio button is made the contents of the popup list change dynamically. I would appreciate any offer of help with this. Thanks in advance, The Buzzard Quote Link to comment Share on other sites More sharing options...
JohnM Posted March 3, 2009 Share Posted March 3, 2009 There are a couple of ways to achieve this depending on how you have the dialog box set up. If you could post the file it would help. You could use the action tile of the radio button to populate the list again depending on how everything is set up. Quote Link to comment Share on other sites More sharing options...
The Buzzard Posted March 3, 2009 Author Share Posted March 3, 2009 Thanks JohnM for your quick responce. As of the moment I have the code somewhat out of commision. But here was how I was trying to do it. In the dcl file: : popup_list { key = "dthk"; width = 10.0; fixed_width = true; alignment = centered; value = 0; } The radio buttons in the lisp code: (action_tile "dT1" ;When radio_button Exterior is selected "(setq DTYP \"EXT\")") ;Set variable DTYP to Exterior (action_tile "dT2" ;When radio_button Interior is selected "(setq DTYP \"INT\")") ;Set variable DTYP to Interior (action_tile "dT3" ;When radio_button Cabinet is selected "(setq DTYP \"CAB\")") ;Set variable DTYP to Cabinet The action tile for the popup list: (IDS_DTS DTYP) (action_tile "dthk" ;When radio_button Exterior is selected "(IDS_DTS DTYP)") ;Set variable DTYP to Exterior And finally a separate function to cause the change: (defun IDS_DTS (DTYP) ;Define function (cond ((= DTYP "EXT") (setq dthk_list '("2-1/4\"" "2\""))) ((= DTYP "INT") (setq dthk_list '("1-3/4\"" "1-3/8\""))) ((= DTYP "CAB") (setq dthk_list '("1\"" "3/4\""))) ) (setq TYP DTYP) (setq LIST-No dthk_list) (start_list "dthk") ;Start list (cond ((= TYP "EXT") (mapcar 'add_list LIST-No)) ((= TYP "INT") (mapcar 'add_list LIST-No)) ((= TYP "CAB") (mapcar 'add_list LIST-No)) ) (end_list) ) ;End define function At this stage, the code will not change the list unless a cancel and start the dialog again. Wish I had this somewhat in order for you to see, But I can post the complete code later. The Buzzard Quote Link to comment Share on other sites More sharing options...
The Buzzard Posted March 3, 2009 Author Share Posted March 3, 2009 JohnM The attached files are the complete program. The output section of the code has not been completed as yet. Parts of the input are also not completed. The dialog will appear to give you an idea of what I am trying to do. Thanks again The Buzzard Quote Link to comment Share on other sites More sharing options...
JohnM Posted March 3, 2009 Share Posted March 3, 2009 you need to make a loop in the lisp that controls the dcl file. i call it the in/out file. there is another post here explaining in detail how to do ithttp://www.cadtutor.net/forum/showthread.php?t=32929 let me know if you need help Quote Link to comment Share on other sites More sharing options...
The Buzzard Posted March 3, 2009 Author Share Posted March 3, 2009 Thank you for looking John, I will check it out. The Buzzard Quote Link to comment Share on other sites More sharing options...
The Buzzard Posted March 3, 2009 Author Share Posted March 3, 2009 John, Checked out the link and it has nothing to do with what I am trying to do. Please realize I have a loop function in my program and it also works. The version I posted is in pieces, So the program will not completely function as I have stated. Thats why I did not want to post the code in the first place. I already know what the other issues are. My question was: I have a popup list in a dialog. I want to change the contents of the popup list from one list to another list depending on the selection thru a radio button. Another words, When a different selection of a radio button is made the contents of the popup list change dynamically. That all I want to do. Quote Link to comment Share on other sites More sharing options...
JohnM Posted March 3, 2009 Share Posted March 3, 2009 The part of the program that populates the dialog box needs the loop in it so when the user clicks the option button the dialog box is re-initialized and displays the new list. The code below is what I wanted you to see on that other post You can see how it calls the dialog box then populates it and there is a what_next loop for re populating the dialog box when the user pick a button In this example when the user clicks the accept button, the dialog is hidden, (look at the code (done dialog 4)then the program drops down to the cond function (=what_next 4) then performs a task then loops back to the topt of the file at the start of the while loop then re-initializes the dialog box and populates the results. If I understand correctly this is kind of what you want to accomplish. The user clicks an option button then the dialog is re-initialized with the correct list displayed. (defun picket:DialogInput (/ dcl_id dialogloaded dialogshow userclick what_next rtvls dstx pipx barx ) (setq dialogLoaded T dialogShow T) (if (= -1 (setq dcl_id (load_dialog "pickets.DCL")));_looks for and loads the dcl file (progn (princ "\nERROR: Cannot load pickets.DCL");_error trapping (setq dialogLoaded nil) ) ;_ end of progn ) ;_ end of if (setq what_next 2);_this is a variable for the loop (while (>= what_next 2);_this is the loop (if (and (not (new_dialog "PICKETS" dcl_id));_if everything is found let the program proceed dialogLoaded ) ;_ end of and (progn (princ "\nERROR: Cannot show dialog PICKETS");_error trap if there is a problem (setq dialogShow nil) ) ;_ end of progn ) ;_ end of if (if (and dialogLoaded dialogShow) (progn ;;; below is where you assign values to tiles and other stuff (if rtvls (progn (set_tile "end1" (rtos(nth 0 rtvls)2 3)) (set_tile "sp" (rtos(nth 1 rtvls)2 3)) (set_tile "sp2" (rtos(nth 2 rtvls)2 3)) (set_tile "end2" (rtos(nth 3 rtvls)2 3)) );_progn (progn (set_tile "end1" "") (set_tile "sp" "") (set_tile "sp2" "") (set_tile "end2" "") );_progn );_if (if dstx (set_tile "x" dstx)(set_tile "x" "")) (if pipx (set_tile "y" pipx)(set_tile "y" "")) (if barx (set_tile "z" barx)(set_tile "z" "")) (action_tile "cancel" "(done_dialog)(setq UserClick nil) ");_if user click the cancle button make dlg go bye-bye ;;; if user clicks ok button assign tile values to variables (action_tile "accept" (strcat "(progn" "(setq dstx (get_tile \"x\"))" "(setq pipx (get_tile \"y\"))" "(setq barx (get_tile \"z\"))" "(if (not (member \"\" (list dstx pipx barx)))" "(progn" "(done_dialog 4)" ")" ;_progn "(alert \"Please enter values\")" ")" ;_if ")" ;_progn ) ;_end strcat ) ;_ end of action_tile (setq what_next (start_dialog)) ) ;_ end of progn ) ;_ end of if (cond ((= what_next 4) (setq rtvls (picket (atof dstx)(atof pipx)(atof barx))));_do this if user clicks the button named qdx_wld );_end cond );_end while (unload_dialog dcl_id) ) Quote Link to comment Share on other sites More sharing options...
The Buzzard Posted March 4, 2009 Author Share Posted March 4, 2009 John, Sorry I did not get back to you sooner. I will try to digest this, Although it will not be easy. I briefly looked over the code and there seems to be alot going on in it. There is probably more in going on in that code then what I actually need. So it looks very confusing. I have a style that I am acustom to, So I will also need to adjust it in a manner that I can understand. I will get back to you and let you know how its going. Again Thank You, The Buzzard Quote Link to comment Share on other sites More sharing options...
The Buzzard Posted March 4, 2009 Author Share Posted March 4, 2009 Hey John, I looked over the program and tested it. Its not what I was looking for. It is a nice program, But I have programs that do similar tasks, And use slightly different methods. I am just going to take a different route now. Thank you for taking the time to help. The Buzzard Quote Link to comment Share on other sites More sharing options...
