Hardeight Posted March 11, 2009 Posted March 11, 2009 I have a list, and I am trying to loop trough the list, change each string in the list and add the new string to a new list. I cant get the result to the bottom or the top of the list. It seems like whatever I try it creates a 2 item list, the first item is the last edited string, and the last item is a string of every other previously altered string. How do I get it to put a new line on the string? I have tried append, multiple variations of cons and everything else I can find. I know this is really simple but for some reason, I seem to get hung up on the easy things. Quote
Lee Mac Posted March 11, 2009 Posted March 11, 2009 Not sure exactly what you are trying to do (a piece of sample code would help), but I would just use "cons" to put the new string in a list: (setq strlst (cons *newstring* strlst)) Quote
Hardeight Posted March 11, 2009 Author Posted March 11, 2009 Thanks for the help Lee. I had been trying this and all sorts of variations with CONS but it still isnt creating my list in the desired format. Here is a sample (setq user (dos_username)) (cond ((= user "BLockhart") (setq userp "Ben")) ((= user "CBearden") (setq userp "Chris")) ((= user "LBrown") (setq userp "Lavon")) ((= user "RChambers") (setq userp "Ronnie")) ((= user "JMitchell") (setq userp "Justin")) ((= user "JPrice") (setq userp "Joe")) ((= user "LCooper") (setq userp "Lonny")) (setq userp (getstring "\n Please enter your first name: ")) );cond end (setq maindir (dos_getdir "Select directory you wish to print:" (strcat "W:\\"userp"\\New Projects"))) (setq sublist (dos_subdir maindir)) (setq subnum (length sublist)) (setq cnt 0) (setq dwglist "") (while ( (setq fldr (nth cnt sublist)) (setq dwglist (cons (strcat maindir fldr) dwglist)) (setq cnt (+ cnt 1)) ) ) This somewhat works, but my list comes out looking like this. LOG ("W:\\Ben\\New Projects\\Solvay\\test\\109487" "W:\\Ben\\New Projects\\Solvay\\test\\109478" "W:\\Ben\\New Projects\\Solvay\\test\\109476" "W:\\Ben\\New Projects\\Solvay\\test\\109455" "W:\\Ben\\New Projects\\Solvay\\test\\109452" "W:\\Ben\\New Project...[car] "W:\\Ben\\New Projects\\Solvay\\test\\109487" [cdr] ("W:\\Ben\\New Projects\\Solvay\\test\\109478" "W:\\Ben\\New Projects\\Solvay\\test\\109476" "W:\\Ben\\New Projects\\Solvay\\test\\109455" "W:\\Ben\\New Projects\\Solvay\\test\\109452" "W:\\Ben\\New Projects\\Solvay\\test\\109438" "W:\\Ben\\New Project... Like I said, I know there is something amazingly simple I am missing, but it's driving me batty:? Quote
Lee Mac Posted March 11, 2009 Posted March 11, 2009 I can't really test it because it uses those "dos" functions... but give this a shot: (setq user (dos_username)) (cond ((= user "BLockhart") (setq userp "Ben")) ((= user "CBearden") (setq userp "Chris")) ((= user "LBrown") (setq userp "Lavon")) ((= user "RChambers") (setq userp "Ronnie")) ((= user "JMitchell") (setq userp "Justin")) ((= user "JPrice") (setq userp "Joe")) ((= user "LCooper") (setq userp "Lonny")) (setq userp (getstring "\n Please enter your first name: ")) );cond end (setq maindir (dos_getdir "Select directory you wish to print:" (strcat "W:\\"userp"\\New Projects"))) (setq sublist (dos_subdir maindir) subnum (length sublist) cnt 0) (while (< cnt subnum) (setq fldr (nth cnt sublist)) (setq dwglist (cons (strcat maindir fldr) dwglist) cnt (+ cnt 1)) ) ) Quote
CAB Posted March 12, 2009 Posted March 12, 2009 Another variation, untested. (setq user (dos_username)) (setq userp (cadr (assoc user '(("BLockhart" "Ben") ("CBearden" "Chris") ("LBrown" "Lavon") ("RChambers" "Ronnie") ("JMitchell" "Justin") ("JPrice" "Joe") ("LCooper" "Lonny") ) ) ) ) (if (null userp) (setq userp (getstring "\n Please enter your first name: ")) ) (if (and (/= userp "") (setq maindir (dos_getdir "Select directory you wish to print:" (strcat "W:\\" userp "\\New Projects"))) (setq sublist (dos_subdir maindir)) (setq subnum (length sublist)) (setq cnt -1) ) (while (< (setq cnt (+ cnt 1)) subnum) (setq fldr (nth cnt sublist)) (setq dwglist (cons (strcat maindir fldr) dwglist)) ) ) Quote
Lee Mac Posted March 13, 2009 Posted March 13, 2009 Ahh nice one CAB, good use of associative lists - I should have looked at this one a bit more. Quote
Hardeight Posted March 13, 2009 Author Posted March 13, 2009 Thanks for the help guys, This is what I finally got to work. (while ( (setq fldr (nth cnt sublist)) (setq dwglist (append dwglist (list (strcat maindir fldr)))) (setq cnt (+ cnt 1)) ) Everything else made my list look funny. and I was dreading having to pull info from it. In case you're curious, I am working on a Batchplot lisp that searches a directory for files that match a certain criteria, writes a script with the info and plots all of them. So basically, all the user has to do to plot off a job, is select a directory with all the part folders in it and it goes through the folders and pulls out the relevant files, (ignoring files used for xrefs and reference drawings) and plots them based on Border size. Let you know how it comes along.... Quote
