M_Simons Posted March 16, 2009 Share Posted March 16, 2009 Does anyone know if it is possible to add multiple installation codes to a single block? For instance if I had a connector with two different types of pins and I was using the installation codes to designate how to terminate the wires into the pins. Quote Link to comment Share on other sites More sharing options...
MFish Posted March 16, 2009 Share Posted March 16, 2009 Does anyone know if it is possible to add multiple installation codes to a single block? For instance if I had a connector with two different types of pins and I was using the installation codes to designate how to terminate the wires into the pins. I tried assembling a similar block to achieve what you are going for, but unfotunately it does not give a second INST opstion. Usually the only time I have been able to use a second of the same attribute is when I have created a FOOTPRINT. But even when I tried creating a sample FOOTPRINT it did not give me the option. Quote Link to comment Share on other sites More sharing options...
