reyems Posted March 18, 2009 Share Posted March 18, 2009 I love the layer merge command for cleaning up drawings. Thanks to this forum for explaining this one. My problem: Sometimes, although the command completes with no error, the layers do not merge together. Most times it works well, but occasionally I cannot get the items to move to the target layer. I have checked and I am not trying to target an xref'd layer. Are there other parameters, other than xref, that will not allow a layer to be a target? Thanks! Quote Link to comment Share on other sites More sharing options...
ReMark Posted March 18, 2009 Share Posted March 18, 2009 Locked layers cannot be merged. Any of yours locked? Quote Link to comment Share on other sites More sharing options...
reyems Posted March 18, 2009 Author Share Posted March 18, 2009 No, I have every layer unlocked Quote Link to comment Share on other sites More sharing options...
ReMark Posted March 18, 2009 Share Posted March 18, 2009 Have you tried purging the drawing before attempting a layer merge? Are you using any content from a vertical product like AutoCAD Architecture? Quote Link to comment Share on other sites More sharing options...
lpseifert Posted March 18, 2009 Share Posted March 18, 2009 No help but you're not alone... I encounter this all too often, I select the layers to merge then select the layer to merge to, regenerates and nothing happens. It's sporadic with certain dwgs; if I copy/paste into a new dwg it works. Go figure... I guess I should contact Ade$k support about it. Quote Link to comment Share on other sites More sharing options...
reyems Posted March 18, 2009 Author Share Posted March 18, 2009 no vertical product. I have tried the purge command and no luck. I did save the drawing, close it out, reopened and tried again. I was able to merge 2 of the layers I did not have luck with earlier, but not all of them yet. Thanks Quote Link to comment Share on other sites More sharing options...
ReMark Posted March 18, 2009 Share Posted March 18, 2009 Sorry I could not offer a definitive answer. Quote Link to comment Share on other sites More sharing options...
alanjt Posted March 18, 2009 Share Posted March 18, 2009 you don't have one of the layers set as current, do you? Quote Link to comment Share on other sites More sharing options...
ReMark Posted March 18, 2009 Share Posted March 18, 2009 Are all entities within blocks on layer 0? Do the layers that refuse to merge have blocks on them with entities on a layer other than 0? Quote Link to comment Share on other sites More sharing options...
reyems Posted March 18, 2009 Author Share Posted March 18, 2009 I do not have any of the layers I am trying to merge set to current. How do I determine if all entities within blocks are on layer 0? Quote Link to comment Share on other sites More sharing options...
ReMark Posted March 18, 2009 Share Posted March 18, 2009 "How do I determine if all entities within blocks are on layer 0?" You can use the Block Editor command (Bedit). Refer to AutoCAD Help for further information. Quote Link to comment Share on other sites More sharing options...
JoeC Posted March 18, 2009 Share Posted March 18, 2009 Try LAYWALK command, then select layer 0. It will show any block entities that are on layer 0 within the block. Quote Link to comment Share on other sites More sharing options...
Locis Posted July 29, 2018 Share Posted July 29, 2018 I unlocked all the layers and the merg worked. With any layers locked i got a dialog saying "y" was an unrecognized command Quote Link to comment Share on other sites More sharing options...
