c.roberts Posted March 25, 2009 Share Posted March 25, 2009 Can anyone please help,my annotate has gone from the top of screen? therefore i cant put symbols or leading arrows etc.Dont know what ive dont only being using autocad for about 2 weeks so i am a total novice Quote Link to comment Share on other sites More sharing options...
ReMark Posted March 25, 2009 Share Posted March 25, 2009 Are you referring to a Toolbar by any chance? Quote Link to comment Share on other sites More sharing options...
c.roberts Posted March 25, 2009 Author Share Posted March 25, 2009 No the differnet options along the top i.e file,edit,view,insert,modify,content,window,help,3d cad max Quote Link to comment Share on other sites More sharing options...
ReMark Posted March 25, 2009 Share Posted March 25, 2009 So you lost ALL your pull-down menus? Quote Link to comment Share on other sites More sharing options...
c.roberts Posted March 25, 2009 Author Share Posted March 25, 2009 no just the annotate Quote Link to comment Share on other sites More sharing options...
ReMark Posted March 25, 2009 Share Posted March 25, 2009 You lost only one pull-down menu out of all the ones at the top of your screen? Seems a bit implausible but I guess anything is possible. Have you tried resetting your profile? You weren't mucking around with customizing your cui were you previous to losing annotate? Quote Link to comment Share on other sites More sharing options...
c.roberts Posted March 25, 2009 Author Share Posted March 25, 2009 also when i go into options all the AM's are gone Quote Link to comment Share on other sites More sharing options...
Tiger Posted March 25, 2009 Share Posted March 25, 2009 I'm not aware there is a Annotate-pulldown menu? Is this something that your company has as a customization? Do you know where that customization file is located? You can use the command MENULOAD to load a missing menu, if you know where it's saved. AMs? Quote Link to comment Share on other sites More sharing options...
ReMark Posted March 25, 2009 Share Posted March 25, 2009 Tools > Options > Profiles. Click on the Reset button. "Resets the values in the selected profile to the system default settings." Quote Link to comment Share on other sites More sharing options...
ReMark Posted March 25, 2009 Share Posted March 25, 2009 Nomenclature: "a system of words used to name things in a particular discipline." Those "different options" along the top of your screen are called pull-down menus. Below them reside your various toolbars. What are "AM's"? Annotation menus? Just guessing here. Enlighten us please so we're all using the same nomenclature and referring to the same thing. Quote Link to comment Share on other sites More sharing options...
c.roberts Posted March 25, 2009 Author Share Posted March 25, 2009 assist>options then a new window pops up showing you the different options available i.e plot&publish,system,user pref,selection etc Anyway mine now only goes upto profile,whereas before i had various 'AM's i.e AM:standards,AM:standard parts,AM:drawing.they have disappered also Quote Link to comment Share on other sites More sharing options...
Tiger Posted March 25, 2009 Share Posted March 25, 2009 Ah, those AMs are customizations of some sort... Have you tried to re-load your profile? Remove the old one, and Import it again at the Profile tab in Options. btw - does your profile tell the truth, are you useing AutoCAD LT? Quote Link to comment Share on other sites More sharing options...
titashtalukdar Posted March 25, 2009 Share Posted March 25, 2009 Hey another way is Type MENULOAD presee enter, a Window opens, On the Upper Box click such that a line Highlights, and then press Unload, and do it till all the rest of the Lines dissappear. After this on the Bottom Right Corner, there is a Browse Button, Click on it it will go to a Autocad Support Dialog box. Search the acad.CUI file and click LOAD. Also Load the Express.CUI, acadSampleWorkspaces.CUI, & Cutom.CUI files. Enjoy Quote Link to comment Share on other sites More sharing options...
Krztoff Posted March 25, 2009 Share Posted March 25, 2009 By any chance could you be using autocad 2009? If I remember correctly, autocad 2009 had a tab called "annotate" or something. It contained buttons to various dimension options. http://www.sbytes.info/wp/wp-content/uploads/2008/03/acad2009-new-user-interface-3.jpg top left in pic, gray button, are you missing that? Quote Link to comment Share on other sites More sharing options...
