Results 1 to 8 of 8
    Forum Newbie
    Architecture 2009
    Mar 2009
    3
    Default Menu Bar Options Missing
    My menu bar has almost vanished. All I can see is "File, Window and Help" all the others have dissapeared. I looked up what to do and CAD help told me to go to Window and then click on Pulldowns but this isn't an option that I can see when I click on Window. Can anyone help me?
    Super Moderator rkmcswain's Avatar
    rkmcswain's Computer Details
    Windows 7 Pro x64
    Intel DZ77RE-75K
    i7-3770K 3.50GHz
    32GB
    Nvidia Quadro 2000
    125GB SSD
    500GB SATA
    ASUS 27" / ASUS 24"
    Civil
    Civil 3D 2013
    Sep 2005
    Houston
    3,633
    It sounds like your menu was either unloaded, or became corrupt.
    Type in MENUNAME. What does it say?
    Forum Newbie
    Architecture 2009
    Mar 2009
    3
    it says: MENUNAME = "C:\Users\Amazing Lora\AppData\Roaming\Autodesk\ACD-A
    2009\enu\Support\ACA" (read only)
    Forum Newbie
    Architecture 2009
    Mar 2009
    3
    Smile
    I think I have sorted it - I restored an earlier version of the file from last week and restored it and everything seems to be OK. Thank you so much though - we reassuring to know someone could help when I was panicking! Thank you x
  5. #5
    Windows 7 Pro x64
    Intel DZ77RE-75K
    i7-3770K 3.50GHz
    32GB
    Nvidia Quadro 2000
    125GB SSD
    500GB SATA
    ASUS 27" / ASUS 24"
    Civil
    Civil 3D 2013
    Sep 2005
    Houston
    3,633
    CUI files are known to sort of "self-destruct" (i.e.: become corrupt)... so restoring a backup copy or the original is usually a good solution.
    FYI: You can restore a backup or original CUI file from inside the CUI dialog. Just right-click on the menu name to see the options.
  6. #6
    Super Member Organic's Avatar
    Civil
    Civil 3D 2013
    Feb 2009
    1,641
    Quote Originally Posted by rkmcswain View Post
    This happened to me yesterday! I didn't have a backup. Restored it from another users CUI files although then had to reset everything how I like it
  7. #7
    Windows 7 Pro x64
    Intel DZ77RE-75K
    i7-3770K 3.50GHz
    32GB
    Nvidia Quadro 2000
    125GB SSD
    500GB SATA
    ASUS 27" / ASUS 24"
    Civil
    Civil 3D 2013
    Sep 2005
    Houston
    3,633
    Quote Originally Posted by Dink87522 View Post
    Did you try going into the CUI and restoring the backup that it creates?
  8. #8
    Forum Newbie
    Revit Structure 2012
    Mar 2013
    1
    This problem fix: http://hakanarslan.net/autodesk-revi...bar-sikintisi/
    Unitsall .Net framework 4.5 and Intsall 4.0
  1. Missing menu bar
    By bolton78 in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 8th Nov 2010, 03:10 am
  2. osnap ortho dyn lwt etc.,menu bar missing
    By tomg in forum AutoCAD Beginners' Area
    Last Post: 18th Oct 2010, 05:06 pm
  3. Changing options in LDD via menu
    By BIGAL in forum Civil 3D & LDD
    Last Post: 29th Jul 2008, 01:23 pm
  4. Menu Missing
    By disbanded in forum AutoCAD General
    Last Post: 20th May 2008, 10:07 pm
  5. Missing Properties menu info
    By zemoe1 in forum AutoCAD Drawing Management & Output
    Last Post: 25th Apr 2006, 04:31 am
