Hi again,
Different question this time:
I noticed in the help files about Dynamic Blocks that apparently the Custom Properties that are present can be exported out using the Attribute Extraction, but it doesn't work when I use Attout.
Any ideas?
(Section from the help files: You can specify whether or not these custom properties are displayed for the block reference when it is selected in a drawing. These properties can also be extracted using the Attribute Extraction wizard.)
