Data Extraction ?? Help??
I am using AutoCad 2008.
I have just began experimenting in Data Extraction and I have a few questions.
1) When I export to an Excel Spreadsheet all my numbers come through with ' before them?? why is this?
2) Is there a way to import this data into a template exel spreadsheet and have it put the data into the correct cells.?
Basically I am extracting data from a block that contains qty's, feet and inches among a few other tidbits of information like a mark and location.
If you can over any insight or tips/tricks to this data extraction I would be really greatful
Thanks Guys you are wonderful as always..
Sorry WCCSAM,
I've no clue on your problem, but am intrested in the answer if any. I extract info from attributes all the time and have no idea how to set up a template, if possible at all.
Regards,
DECHAL.
