Where I work, we have LISP file that was used in Autocad R12..
It's used to name a closed polyline, and insert text within that polyline.
I'm trying to use it in AutoCAD 2007, but can't seem to make it work. I keep getting "lentityp nil" error towards the end...
Here's the code:
;AL_NAMER.LSP
;Program BY: Chris Thompson
;Description: This program oversees the placement of a text
;        description on a 2-D Polyline pattern.
;          The Program prompts for:
;            Entity        - The entity the text
;                       will attach to.
;            Piece Code     - a 3 ltr code
;            Module Code     - a 2 ltr code
;            Direction Code     - a 1 ltr code
;            Material Code     - a 1 ltr code
;            Description     - a ?? ltr code
(defun C:NAMER()
(princ "\n Select an Entity to Name:")
(setq ASet (entsel))
(princ "\n")
(setq ESList (entget(car ASet)))
(setq TYPE1 (cdr(assoc 0 ESList)))
(if (= TYPE1 "LWPOLYLINE")
; Get The Area
  (Command "_.Area" "_E" ASet)
  (setq Bset (getvar "Area"))
  (setq Ftg (/ Bset 144))
  (setq Ftg (+ Ftg 0.005))
  (setq AreaText1 (rtos Ftg 2))
; Find The Decimal Place
  (setq AreaText2 (substr AreaText1 2 1))
  (if (= AreaText2 ".")
     (setq AreaText2 (substr AreaText1 1 4))
     (setq AreaText2 (substr AreaText1 1 5))
  (setq AreaText2 (strcat AreaText2 " "))
;Get the Text For all the Text Sections
;Also Makes sure that input is valid
  (PieceCode)
  (ModuleCode)
  (DirectionCode)
  (MaterialCode)
  (DescriptionCode)
;Put the Text Line Together
  (setq TextLine (strcat PieceText  ModuleText))
  (setq TextLine (strcat TextLine  DirectionText))
  (setq TextLine (strcat TextLine  MaterialText))
  (setq TextLine (strcat TextLine  AreaText2))
  (setq TextLine (strcat TextLine  DescriptionText))
  (setq TextLine (strcase TextLine))
;Find the Text Start Point
;Then Place the Text
  (TextStart)
  (PlaceText)
 (princ "\n Selection Not A PolyLine")
(defun TextStart()
; Get Point Between First and Last  Points Picked ?
(setq BSet (entget(entnext(cdr(assoc -1 ESList)))))
(setq FirstPoint (cdr (assoc 10 BSet)))
(while (/=(cdr(assoc 0 Bset)) "SEQEND")
 (setq PrevPoint LastPoint)
 (setq LastPoint (cdr (assoc 10 BSet)))
 (setq Bset(entget(entnext(cdr(assoc -1 BSet)))))
(setq X1 (car FirstPoint))
(setq Y1 (cadr FirstPoint))
(if (AND (= (car FirstPoint) (car LastPoint))(= (cadr FirstPoint) (cadr LastPoint)))
  (setq X2 (car PrevPoint))
  (setq Y2 (cadr PrevPoint))
  (setq X2 (car LastPoint))
  (setq Y2 (cadr LastPoint))
(setq X (- X2 X1))
(setq Y (- Y2 Y1))
(setq X (/ X 2))
(setq Y (/ Y 2))
(setq X (+ X X1))
(setq Y (+ Y Y1))
(setq Position (list X Y 0))
(defun PlaceText()
; Place The Text
(setq CrntLyr (getvar "clayer"))
(princ "\n")
(princ CrntLyr)
(command "layer" "s" "NAME" "")
(command "Text" Position ".5" "0" TextLine)
(command "layer" "s" CrntLyr "")
(defun PieceCode()
; Get The Piece Text
  (setq PieceText "")
  (while (= (substr PieceText 3 1) "")
   (setq PieceText (getstring "\n Input Piece Code:"))
  (setq PieceText (substr PieceText 1 3))
  (setq PieceText (strcat PieceText " "))
(defun ModuleCode()
; Get The Module Text
  (setq TheEnd 0)
  (setq ModuleText "")
  (while (= TheEnd 0)
   (setq ModuleText (getstring "\n Input Module Code:"))
   (setq ModuleText (strcase ModuleText))
   (if (= ModuleText "BK") (setq TheEnd 1))
   (if (= ModuleText "DK") (setq TheEnd 1))
   (if (= ModuleText "SC") (setq TheEnd 1))
   (if (= ModuleText "BC") (setq TheEnd 1))
   (if (= ModuleText "AR") (setq TheEnd 1))
   (if (= ModuleText "AC") (setq TheEnd 1))
   (if (= TheEnd 0 ) (alert "          NOT A VALID INPUT \nValid Inputs: BK DK SC BC AR AC"))
  (setq ModuleText (substr ModuleText 1 2))
  (setq ModuleText (strcat ModuleText " "))
(defun DirectionCode()
; Get The Direction Text
  (setq TheEnd 0)
  (setq DirectionText "")
  (while (= TheEnd 0)
   (setq DirectionText (getstring "\n Input Direction Code:"))
   (setq DirectionText (strcase DirectionText))
   (if (= DirectionText "R") (setq TheEnd 1))
   (if (= DirectionText "L") (setq TheEnd 1))
   (if (= DirectionText "S") (setq TheEnd 1))
   (if (= TheEnd 0 ) (alert "NOT A VALID INPUT \n  Valid Inputs: R L S"))
  (setq DirectionText (substr DirectionText 1 1))
  (setq DirectionText (strcat DirectionText " "))
(defun MaterialCode()
; Get The Material Text
  (setq TheEnd 0)
  (setq MaterialText "")
  (while (= TheEnd 0)
   (setq MaterialText (getstring "\n Input Material Code:"))
   (setq MaterialText (strcase MaterialText))
   (if (= MaterialText "L") (setq TheEnd 1))
   (if (= MaterialText "S") (setq TheEnd 1))
   (if (= MaterialText "P") (setq TheEnd 1))
   (if (= MaterialText "D") (setq TheEnd 1))
   (if (= MaterialText "Q") (setq TheEnd 1))
   (if (= MaterialText "E") (setq TheEnd 1))
   (if (= TheEnd 0 ) (alert " NOT A VALID INPUT \nValid Inputs:  L B S P"))
  (setq MaterialText (substr MaterialText 1 1))
  (setq MaterialText (strcat MaterialText " "))
(defun DescriptionCode()
; Get The Description Text
  (setq DescriptionText "")
  (while (= (substr DescriptionText 1 1) "")
   (setq DescriptionText (getstring 1 "\n Input Description:"))
  (setq DescriptionText (substr DescriptionText 1 20))
Can anyone help?
  • Replies 20
  • Lee Mac
    12
  • x3ro
    8
  • uddfl
    1
Just quickly looking at it, I think the creator meant it for use with POLYLINES and not LWPOLYLINES - as it contains "entnext" to get the vertices.
I could probably re-write it for use with LWPOLYLINES, but haven't the time at present :(
Lee
Lee
Hmmm.
What would it take to work with LWPOLYLINES?
Hmmm.
I think the whole LISP needs a bit of re-writing tbh, there is not much in the way of error trapping - and the LISP seems a bit unstable.
Will see what I can do :)
OK, give this a shot - wasn't sure exactly what you wanted, but if you need anything modified, let me know :)
;;;    =============  Namer.lsp =============
;;;  FUNCTION:
;;;  Will label a Curve with Piece Code,
;;;  Module, Direction, Material, and Description
;;;  PLATFORMS:
;;;  No Restrictions, only tested on ACAD 2004
;;;  CURVE COMPATABILITY:
;;;  Arcs, Circles, Ellipses, *Polylines,
;;;  Regions & Splines.
;;;  AUTHOR:
;;;  Copyright (c) 04.2009 Lee McDonnell
;;;   (contact Lee Mac, CADTutor.net)
;;;  VERSION:
;;;  1.0  02.04.09
(defun c:namer (/ *error* ptxt detxt cEnt cObj Area motxt dtxt mtxt tStr
         tBox tWid tHgt ClsPt btPt tpPt pt1 pt2 pt3 pt4 tAngl tObj)
 (vl-load-com)
 (defun *error* (msg)
   (redraw)
   (if tObj (entdel tObj))
   (if ovar (mapcar 'setvar vlst ovar))
   (if (not (member msg '("Function cancelled" "quit / exit abort")))
     (princ (strcat "\nError: " (strcase msg))))
   (princ))
 (setq vlst '("CLAYER" "OSMODE" "CMDECHO")
   ovar (mapcar 'getvar vlst))
 (mapcar 'setvar (cdr vlst) '(0 0))
 (if (not (tblsearch "LAYER" "NAME"))
   (command "_-layer" "_M" "NAME" "_C" "2" "NAME" ""))
 (or mo:def (setq mo:def "BK"))
 (or d:def (setq d:def "R"))
 (or m:def (setq m:def "L"))
 (setq ptxt "" detxt "")
 (if (and (setq cEnt (car (entsel "\nSelect Curve to Label: ")))
      (member (cdr (assoc 0 (entget cEnt)))
          '("ARC" "CIRCLE" "ELLIPSE" "*POLYLINE" "REGION" "SPLINE")))
     (setq cObj (vlax-ename->vla-object cEnt)
       Area (rtos (vla-get-area cObj) 2 0))
     (while (= ptxt "")
   (setq ptxt (getstring "\nInput Piece Code: ")))
     (setq ptxt (substr ptxt 1 3))
     (while (not (member motxt '("BK" "DK" "SC" "BC" "AR" "AC")))
   (setq motxt (strcase
             (getstring
           (strcat "\nInput Module [bK/DK/SC/BC/AR/AC] <" mo:def ">: "))))
   (or (and (eq motxt "") (setq motxt mo:def)) (setq mo:def motxt)))
     (while (not (member dtxt '("R" "L" "S")))
   (setq dtxt (strcase
            (getstring
              (strcat "\nInput Direction [R/L/S] <" d:def ">: "))))
   (or (and (eq dtxt "") (setq dtxt d:def)) (setq d:def dtxt)))
     (while (not (member mtxt '("L" "S" "P" "D" "Q" "E")))
   (setq mtxt (strcase
            (getstring
              (strcat "\nInput Material [L/S/P/D/Q/E] <" m:def ">: "))))
   (or (and (eq mtxt "") (setq mtxt m:def)) (setq m:def mtxt)))
     (while (= detxt "")
   (setq detxt (getstring t "\nInput Description: ")))
     (setq detxt (substr detxt 1 20)
       tStr (strcat ptxt (chr 45) motxt (chr 45) dtxt (chr 45)
            mtxt (chr 45) Area (chr 45) detxt)
       tBox (textbox (list (cons 1 tStr)))
       tWid (- (caadr tBox) (caar tBox))
       tHgt (- (cadadr tBox) (cadar tBox)))
     (while (= 5 (car (setq grdat (grread t 1))))
   (redraw)
   (if (= 'list (type (setq sPt (cadr grdat))))
       (setq ClsPt (vlax-curve-getClosestPointto cObj sPt)
         cAngl (angle ClsPt sPt)
         btPt (polar ClsPt cAngl (/ (getvar "TEXTSIZE") 2.0))
         tpPt (polar ClsPt cAngl (+ (/ (getvar "TEXTSIZE") 2.0) tHgt))
         midPt (polar btPt cAngl (/ (distance btPt tpPt) 2.0))
         pt1 (polar btPt (+ cAngl (/ pi 2)) (/ tWid 2.0))
         pt2 (polar btPt (- cAngl (/ pi 2)) (/ tWid 2.0))
         pt3 (polar tpPt (+ cAngl (/ pi 2)) (/ tWid 2.0))
         pt4 (polar tpPt (- cAngl (/ pi 2)) (/ tWid 2.0)))
       (grvecs (list 51 pt1 pt2 51 pt2 pt4 51 pt1 pt3 51 pt3 pt4)))))
     (setq tAngl (- cAngl (/ pi 2)))
     (if (and (> tAngl 0) (<= tAngl (/ pi 2)))
   nil
   (setq tAngl (+ tAngl pi)))
     (setq tObj (Make_Text midPt tStr tAngl)))
   (princ "\n<!> Object is not a Curve <!>"))
 (redraw)
 (princ))
 (defun Make_Text  (pt val rot)
 (entmake (list '(0 . "TEXT")
        '(8 . "NAME")
        (cons 10 pt)
        (cons 40 (getvar "TEXTSIZE"))
        (cons 1 val)
        (cons 50 rot)
        '(7 . "STANDARD")
        '(71 . 0)
        '(72 . 1)
        '(73 . 2)
        (cons 11 pt))))
 (princ "\n** Namer.lsp Successfully Loaded, Type \"namer\" to invoke **")
Thanks for your work man.
I tried it, and it stopped saying the object was not a curve. Here's the copy and paste where it stopped:
** Namer.lsp Successfully Loaded, Type "namer" to invoke **
Command:
Command: pn PEDIT Select polyline or [Multiple]:
Object selected is not a polyline
Do you want to turn it into one? <Y>
Enter an option [Close/Join/Width/Edit vertex/Fit/Spline/Decurve/Ltype
gen/Undo]: j
Select objects: Specify opposite corner: 24 found
Select objects:
23 segments added to polyline
Enter an option [Open/Join/Width/Edit vertex/Fit/Spline/Decurve/Ltype
gen/Undo]: x
Command: rr REGEN Regenerating model.
Command: n
One thing I noticed, is that you set it to check that it's a polyline. All the parts will always be polylines, that we're trying to do. I don't really think you need the check and make polyline thing.
Any ideas why it stopped?
My apologies dude - stupid mistake of mine :oops:
;;;  FUNCTION:
;;;  PLATFORMS:
;;;  AUTHOR:
;;;  VERSION:
;;;  1.0  02.04.09
 (vl-load-com)
   (redraw)
   (princ))
          '("ARC" "CIRCLE" "ELLIPSE" "LWPOLYLINE" "POLYLINE" "REGION" "SPLINE")))
     (while (= ptxt "")
             (getstring
   (setq dtxt (strcase
            (getstring
   (setq mtxt (strcase
            (getstring
     (while (= detxt "")
   (redraw)
   nil
 (redraw)
 (princ))
        '(8 . "NAME")
        (cons 10 pt)
        (cons 1 val)
        (cons 50 rot)
        '(7 . "STANDARD")
        '(71 . 0)
        '(72 . 1)
        '(73 . 2)
        (cons 11 pt))))
Wow!
That works great. That's awesome.
Only had a question about a few things:
1. Can we put the text together without using any hyphens?
2. Can we make is so that instead of sq inches, it puts sq footage on the text line?
3. Can we make it so that it's just regular text rather than mtext?
Thanks so much for your work! It's really going to help out a lot. I tried to look at the code for what you did to modify it for the things I need, but it's lost on me. LOL. I know very very little about LISP code. In the past, I've been able to get some things to work in newer versions of CAD, but I'm no expert at it.
Wow!
Sorted in new version - spaces are now used.
Sorted, area is adjusted for sqft.
The text that is created should be single-line DTEXT, not MTEXT :huh:
New Version:
;;;  FUNCTION:
;;;  PLATFORMS:
;;;  AUTHOR:
;;;  VERSION:
;;;  1.0  02.04.09
;;;  2.0  03.04.09
 (vl-load-com)
   (redraw)
   (princ))
       Area (rtos (/ (vla-get-area cObj) 144.0) 2 0))
     (while (= ptxt "")
             (getstring
   (setq dtxt (strcase
            (getstring
   (setq mtxt (strcase
            (getstring
     (while (= detxt "")
       tStr (strcat ptxt (chr 32) motxt (chr 32) dtxt (chr 32)
            mtxt (chr 32) Area (chr 32) detxt)
     (prompt "\nPlace Text... ")
   (redraw)
   nil
 (redraw)
 (princ))
        '(8 . "NAME")
        (cons 10 pt)
        (cons 1 val)
        (cons 50 rot)
        '(7 . "STANDARD")
        '(71 . 0)
        '(72 . 1)
        '(73 . 2)
        (cons 11 pt))))
Man you're quick!
Everything works great!
I had a brainfart on the mtext thing. :glare: It is in fact already what I need!
I hate to impose, but is there any way we can make it so the sq ftg is always two places after the decimal, even if it's a whole number? For example, 1 would be 1.00? Is that hard to do? Or something I could change myself?
Holy smokes, Lee.
That's what I would call overhauling and old LISP. Very nice.
Edit: Not to be a spelling Nazi, but it's 'compatIbility", not 'compatAbility'
Not a problem at all - I shall include an *adjustment menu* for your benefit :)
Haha, if anything I am much of a spelling Nazi myself - can't believe I didn't look that up before I posted it :oops:
Ok, Please find adjustment menu at the top :)
;;;  FUNCTION:
;;;  PLATFORMS:
;;;  CURVE COMPATIBILITY:
;;;  AUTHOR:
;;;  VERSION:
;;;  1.0  02.04.09
;;;  2.0  03.04.09
;;;  3.0  03.04.09
(defun c:namer (/ *error* APrec VCol tStyl ptxt detxt
 (vl-load-com)
 ;; ===== Adjustments =====
 (setq APrec 2)   ; Area Precision, integer >= 0
 (setq VCol 3)    ; Vector Colour, integer (0-255)
 (setq tStyl "STANDARD")  ; TextStyle, if non-existent, Standard.
 ; === Error Prevention ===
 (or (and (eq 'INT (type APrec)) (>= APrec 0)) (setq APrec 2))
 (or (and (eq 'INT (type VCol)) (<= 0 VCol 255)) (setq VCol 3))
 (or (tblsearch "STYLE" tStyl) (setq tStyl "STANDARD"))
   (redraw)
   (princ))
       Area (rtos (/ (vla-get-area cObj) 144.0) 2 APrec))
     (while (= ptxt "")
             (getstring
   (setq dtxt (strcase
            (getstring
   (setq mtxt (strcase
            (getstring
     (while (= detxt "")
   (redraw)
       (grvecs (list VCol pt1 pt2 VCol pt2 pt4 VCol pt1 pt3 VCol pt3 pt4)))))
   nil
 (redraw)
 (princ))
        '(8 . "NAME")
        (cons 10 pt)
        (cons 1 val)
        (cons 50 rot)
        (cons 7 tStyl)
        '(71 . 0)
        '(72 . 1)
        '(73 . 2)
        (cons 11 pt))))
You, sir, are awesome!
Works perfectly, and thanks for the adjustment menu.
Is there anyway to control the text size? What I'm seeing right now through my testing, it's dependent upon where you place the text. I'd prefer it to be a single size. How can I adjust that in the code?
Thanks :) I've had fun making this one tbh :P
The textsize is retrieved from the "TEXTSIZE" variable, which will be dependent on your text style. But I shall add a manual override for you :)
Try this:
;;;  FUNCTION:
;;;  PLATFORMS:
;;;  AUTHOR:
;;;  VERSION:
;;;  1.0  02.04.09
;;;  2.0  03.04.09
;;;  3.0  03.04.09
(defun c:namer (/ *error* APrec VCol tStyl tSze ptxt
         tStr tBox tWid tHgt ClsPt btPt tpPt
 (vl-load-com)
 (setq tSze 2.5)  ; TextSize, real > 0, if nil, will be Textstyle dependent.
 (or (and tSze (> tSze 0)) (setq tSze (getvar "TEXTSIZE")))
   (redraw)
   (princ))
     (while (= ptxt "")
             (getstring
   (setq dtxt (strcase
            (getstring
   (setq mtxt (strcase
            (getstring
     (while (= detxt "")
   (redraw)
   nil
 (redraw)
 (princ))
        '(8 . "NAME")
        (cons 10 pt)
        (cons 40 tSze)
        (cons 1 val)
        (cons 50 rot)
        (cons 7 tStyl)
        '(71 . 0)
        '(72 . 1)
        '(73 . 2)
        (cons 11 pt))))
Perfect Lee!
I really appreciate all your hard work!
This will save us a ton of time, and I definitely couldn't have done it on my own!
Actually, this is better (more options :) )
;;;  FUNCTION:
;;;  PLATFORMS:
;;;  AUTHOR:
;;;  VERSION:
;;;  1.0  02.04.09
;;;  2.0  03.04.09
;;;  3.0  03.04.09
(defun c:namer (/ *error* APrec VCol tStyl tSze tLay
         tCol ptxt detxt cEnt cObj Area motxt
         dtxt mtxt tStr tBox tWid tHgt ClsPt
 (vl-load-com)
 (setq tLay "NAME")  ; Layer for Text, layer will be created if non-existent
 (setq tCol 255)  ; Text Colour, (255 = ByLayer)
 (or tLay (setq tLay "NAME"))
 (or (and (eq 'INT (type tCol)) (<= 0 tCol 255)) (setq tCol 255))
   (redraw)
   (princ))
 (if (not (tblsearch "LAYER" tLay))
   (command "_-layer" "_M" tLay "_C" "2" tLay ""))
     (while (= ptxt "")
             (getstring
   (setq dtxt (strcase
            (getstring
   (setq mtxt (strcase
            (getstring
     (while (= detxt "")
   (redraw)
   nil
 (redraw)
 (princ))
        (cons 8 tLay)
        (cons 10 pt)
        (cons 40 tSze)
        (cons 1 val)
        (cons 50 rot)
        (cons 7 tStyl)
        (cons 62 tCol)
        '(71 . 0)
        '(72 . 1)
        '(73 . 2)
        (cons 11 pt))))
Wow! That's awesome Lee!
I can't thank you enough man! This is pure greatness!
