dsibbo Posted April 9, 2009 Share Posted April 9, 2009 Hi, We have recently updated to AutoCAD 2010 from 2009. A problem i'm having is whenever i complete a command i am used to right clicking and seeing a dropdown menu with repeat command, copy, paste etc on. However now when i right click it automatically repeats the command, does anyone know how to get back the original dropdown menu? Thankyou Quote Link to comment Share on other sites More sharing options...
Dipali Posted April 9, 2009 Share Posted April 9, 2009 go to tools>user preference>rightclick customisation & than choose 'shortcut menu' under 'edit mode' Quote Link to comment Share on other sites More sharing options...
GE13579 Posted April 9, 2009 Share Posted April 9, 2009 If it's just the repeat command you're wanting, you can run with the current settings and just right click to end the command and then right click to restart the command. Effectively the right click works as the would. Furthermore, if you get used to this method, you can set a time sensitive right click (set up where Dipali has directed you) so you can also hold the right mouse button to bring up the menu or just short click for the above. Quote Link to comment Share on other sites More sharing options...
