Would you be so kind as to tell me where im stuffing up.
I can not work it out for the life of me.
I can not get one cell to update, "description"
it needs to have a radio button on for it to work, but it refuses to update
and "des" which is the same as the other 15 does not work either,
(feel free to suggest better coding methods aswell)
the .dcl file
rev3 : dialog {
   label = "Revisions" ;
 :column  {
 key = "revbox" ;
 :row {
  :column {
     : edit_box {
       label = "&Drawn by";
       key = "Doneby";
       edit_width = 4;
     : edit_box {
         label = "&Revised by";
         key = "revisedby";
         edit_width = 4;
  :column {
     : edit_box {
         label = "&Dwg Checked by";
         key = "ckd";
         edit_width = 4;
     : edit_box {
         label = "&Rev Checked by";
         key = "ckd2";
         edit_width = 4;
  :column {
     : edit_box {
         label = "&Designedby";
         key = "des";
         edit_width = 4;
     : edit_box {
         label = "&Approved by";
         key = "app";
         edit_width = 4;
  :column {
     spacer;
      :row { spacer;
      : text_part { label = "Rev A";}
      : edit_box {
         label = "&Date";
         key = "Date";
         edit_width = 4;
  :boxed_radio_row {
      : radio_button {key = "ifc" ; label = "Issued For Construction"; is_default = true; }
      : radio_button {key = "ifi" ; label = "Issued For Information"; }
      : radio_button {key = "ifp" ; label = "Issued For Percurament"; }
      : radio_button {key = "Other" ; label = "other"; }
  : edit_box {
        label = "&Revision Notes";
        key = "Description";
         edit_width = 90;
  :row{
    ok_cancel;
   spacer;spacer;spacer;
    : button { key = "reveep" ; label = "Rev up" ; is_default = true; width = true;  alignment = center; }
  :row {
    spacer;
    spacer;
    spacer;
    spacer;
    spacer;
    spacer;
    spacer;
    spacer;
    spacer;
    spacer;
    : text { label = "by Seth Ruhan  Rev 1.00";}
   (action_tile "des" "(setq attribute57 (get_tile \"des\"))")
  (action_tile "Description" "(setq attribute18 (get_tile \"Description\"))")
revoptions.LSP
The dialog did not appear. I made changes in both files and it appears now. I placed comments next to the changes. You got some work to do.
rev3 : dialog {
      : column  {
//         key = "revbox" ;                     //  Problem on this line
        : row {
          : column {
            : edit_box {
              key = "Doneby";
              edit_width = 4;
            : edit_box {
              key = "revisedby";
              edit_width = 4;
          : column {
            : edit_box {
              key = "ckd";
              edit_width = 4;
            : edit_box {
              key = "ckd2";
              edit_width = 4;
          : column {
            : edit_box {
              key = "des";
              edit_width = 4;
            : edit_box {
              key = "app";
              edit_width = 4;
          : column {
            spacer;
            : row {
              spacer;
              : text_part {
                label = "Rev A";
            : edit_box {
              label = "&Date";
              key = "Date";
              edit_width = 4;
        : boxed_radio_row {
          : radio_button {
            key = "ifc" ;
            is_default = true;
          : radio_button {
            key = "ifi" ;
          : radio_button {
            key = "ifp" ;
          : radio_button {
            key = "Other" ;
            label = "other";
        : edit_box {
          edit_width = 90;
        : row {
          ok_cancel;
          : button {
            key = "reveep" ;
            label = "Rev up" ;
            is_default = true;
            width = true;
            alignment = center;
        : row {
          spacer;
          spacer;
          spacer;
          spacer;
          spacer;
          spacer;
          spacer;
          spacer;
          spacer;
          spacer;
          : text {
Good Luck,
The Buzzard
Rev up.LSP
I just noticed you edited your post before I could get back to you on the original. I will wait for your feed back.
thank so much buzzard, will revise in the morning,
thanks again
Just a few pointers for ya - save you all that typing!
Instead of:
     (setq en (ssname ss1 0))
     (setq ed (entget en))
     (setq edata (entget en))
     (setq edata (entget (entnext (cdr (assoc -1 edata)))))
     (setq attribute1 (cdr (assoc 1 edata)))
     (setq attribute2 (cdr (assoc 1 edata)))
     (setq attribute3 (cdr (assoc 1 edata)))
     (setq attribute4 (cdr (assoc 1 edata)))
     (setq attribute5 (cdr (assoc 1 edata)))
     (setq attribute6 (cdr (assoc 1 edata)))
     (setq attribute7 (cdr (assoc 1 edata)))
     (setq attribute8 (cdr (assoc 1 edata)))
     (setq attribute9 (cdr (assoc 1 edata)))
     (setq attribute10 (cdr (assoc 1 edata)))
     (setq attribute11 (cdr (assoc 1 edata)))
     (setq attribute12 (cdr (assoc 1 edata)))
     (setq attribute13 (cdr (assoc 1 edata)))
     (setq attribute14 (cdr (assoc 1 edata)))
     (setq attribute15 (cdr (assoc 1 edata)))
     (setq attribute16 (cdr (assoc 1 edata)))
     (setq attribute17 (cdr (assoc 1 edata)))
     (setq attribute18 (cdr (assoc 1 edata)))
     (setq attribute19 (cdr (assoc 1 edata)))
     (setq attribute20 (cdr (assoc 1 edata)))
     (setq attribute21 (cdr (assoc 1 edata)))
     (setq attribute22 (cdr (assoc 1 edata)))
     (setq attribute23 (cdr (assoc 1 edata)))
     (setq attribute25 (cdr (assoc 1 edata)))
     (setq attribute26 (cdr (assoc 1 edata)))
     (setq attribute27 (cdr (assoc 1 edata)))
     (setq attribute28 (cdr (assoc 1 edata)))
     (setq attribute29 (cdr (assoc 1 edata)))
     (setq attribute30 (cdr (assoc 1 edata)))
     (setq attribute31 (cdr (assoc 1 edata)))
     (setq attribute33 (cdr (assoc 1 edata)))
     (setq attribute34 (cdr (assoc 1 edata)))
     (setq attribute35 (cdr (assoc 1 edata)))
     (setq attribute36 (cdr (assoc 1 edata)))
     (setq attribute37 (cdr (assoc 1 edata)))
     (setq attribute38 (cdr (assoc 1 edata)))
     (setq attribute39 (cdr (assoc 1 edata)))
     (setq attribute40 (cdr (assoc 1 edata)))
     (setq attribute41 (cdr (assoc 1 edata)))
     (setq attribute42 (cdr (assoc 1 edata)))
     (setq attribute43 (cdr (assoc 1 edata)))
     (setq attribute44 (cdr (assoc 1 edata)))
     (setq attribute45 (cdr (assoc 1 edata)))
     (setq attribute46 (cdr (assoc 1 edata)))
     (setq attribute47 (cdr (assoc 1 edata)))
     (setq attribute48 (cdr (assoc 1 edata)))
     (setq attribute49 (cdr (assoc 1 edata)))
     (setq attribute50 (cdr (assoc 1 edata)))
     (setq attribute51 (cdr (assoc 1 edata)))
     (setq attribute52 (cdr (assoc 1 edata)))
     (setq attribute53 (cdr (assoc 1 edata)))
     (setq attribute54 (cdr (assoc 1 edata)))
     (setq attribute56 (cdr (assoc 1 edata)))
     (setq attribute57 (cdr (assoc 1 edata)))
     (setq attribute58 (cdr (assoc 1 edata)))
Why not make a list of attribute values using:
 (setq att (entnext (ssname ss1 0)))
 (while (not (eq "SEQEND" (cdadr (entget att))))
   (setq attLst (cons (cdr (assoc 1 (entget att))) attLst)
         att    (entnext att)))
Just make sure that you localise the "attLst" variable, otherwise you will get duplicates :thumbsup:
lee, with that list, wouldnt i still need to assign each one their own entity, to update them and put them back?? or am i being ignorant?
Sorry buzzard, i thought i fixed it, so i updated it, then i relised then two others wouldnt update,
The above will create a list of all the attribute values, If I were you I would create an associative list of attribute tags and strings, making the updating part much easier, and less error prone.
Make the list like this:
 (setq attLst (cons (cons (cdr (assoc 2 (entget att)))
                          (cdr (assoc 1 (entget att)))) attLst)
       att    (entnext att)))
Thanks for that, i can see you point i think,
i extract the thing i want with
(setq test (CDR (assoc "DWGNUM" ATTLST)))
and it show me "x" for instance,
how do i replace that?
I was thinking "subst" what if their is another "x" their?
Thank you for your suggestions, greatly appricatied
I would test for its existence and replace like this:
(if (setq att (assoc <tag> attLst))
 (entmod (subst (cons 1 (cdr att)) att attLst)))
