mien Posted April 15, 2009 Share Posted April 15, 2009 can someone help me with this code. this code stop at read file...it think it was a logic error, but i cant solve it...thanks.. Public Sub Plot_Click() Me.Hide Dim strFileName As String Dim myFile As Integer Dim strTextLine As String Dim arrText As Variant Dim dblX As Variant Dim dblY As Variant Dim dblZ As Variant strFileName = mstrinpfile If Dir(strFileName) = "" Then Call MsgBox(strFileName & " not found", vbExclamation, "Import XYZ Coordinates") End If 'add parameter ThisDrawing.SendCommand "PDMODE" & vbCr ThisDrawing.SendCommand "0" & vbCr ThisDrawing.SendCommand "PDsize" & vbCr ThisDrawing.SendCommand "0" & vbCr ThisDrawing.SendCommand "CMDECHO" & vbCr ThisDrawing.SendCommand "0" & vbCr ThisDrawing.SendCommand "-Style" & vbCr ThisDrawing.SendCommand "WMH" & vbCr ThisDrawing.SendCommand "Romans" & vbCr ThisDrawing.SendCommand "0" & vbCr ThisDrawing.SendCommand "0.75" & vbCr ThisDrawing.SendCommand "15" & vbCr ThisDrawing.SendCommand "N" & vbCr ThisDrawing.SendCommand "N" & vbCr ThisDrawing.SendCommand "N" & vbCr ThisDrawing.SendCommand "-Units" & vbCr ThisDrawing.SendCommand "2" & vbCr ThisDrawing.SendCommand "3" & vbCr ThisDrawing.SendCommand "2" & vbCr ThisDrawing.SendCommand "4" & vbCr ThisDrawing.SendCommand "90" & vbCr ThisDrawing.SendCommand "Y" & vbCr ThisDrawing.SendCommand "-Layer" & vbCr ThisDrawing.SendCommand "Make" & vbCr ThisDrawing.SendCommand "WMH_PDEPTH" & vbCr myFile = FreeFile Open mstrinpfile For Input As #myFile Do While Not EOF(myFile) Line Input #myFile, strTextLine arrText = Split(strTextLine, ",") dblX = arrText(0) dblY = arrText(1) dblZ = arrText(2) If (Val(dblZ) >= Val(mintlv1)) Then ThisDrawing.SendCommand "-color" & vbCr ThisDrawing.SendCommand "BYLAYER" & vbCr ThisDrawing.SendCommand "point" & vbCr ThisDrawing.SendCommand dblY & "," & dblX & "," & dblZ & vbCr ThisDrawing.SendCommand "-Layer" & vbCr ThisDrawing.SendCommand "Make" & vbCr ThisDrawing.SendCommand "WMH_BDEPTH" & vbCr ThisDrawing.SendCommand "" & vbCr ThisDrawing.SendCommand "-color" & vbCr ThisDrawing.SendCommand Val(cl1) & vbCr ThisDrawing.SendCommand "-Text" & vbCr ThisDrawing.SendCommand "R" & vbCr ThisDrawing.SendCommand dblY & "," & dblX & "," & dblZ & vbCr ThisDrawing.SendCommand "2.0" & vbCr ThisDrawing.SendCommand "90" & vbCr ThisDrawing.SendCommand Left(dblZ, 2) & vbCr ThisDrawing.SendCommand "-Layer" & vbCr ThisDrawing.SendCommand "Make" & vbCr ThisDrawing.SendCommand "WMH_SDEPTH" & vbCr ThisDrawing.SendCommand "" & vbCr ThisDrawing.SendCommand "-Text" & vbCr ThisDrawing.SendCommand "ML" & vbCr ThisDrawing.SendCommand dblY & "," & dblX & "," & dblZ & vbCr ThisDrawing.SendCommand "1.5" & vbCr ThisDrawing.SendCommand "90" & vbCr ThisDrawing.SendCommand Right(dblZ, 1) & vbCr ThisDrawing.SendCommand "zoom" & vbCr ThisDrawing.SendCommand "extents" & vbCr ElseIf (Val(dblZ) >= Val(mintlv2)) Then ThisDrawing.SendCommand "-color" & vbCr ThisDrawing.SendCommand "BYLAYER" & vbCr ThisDrawing.SendCommand "point" & vbCr ThisDrawing.SendCommand dblY & "," & dblX & "," & dblZ & vbCr ThisDrawing.SendCommand "-Layer" & vbCr ThisDrawing.SendCommand "Make" & vbCr ThisDrawing.SendCommand "WMH_BDEPTH" & vbCr ThisDrawing.SendCommand "" & vbCr ThisDrawing.SendCommand "-color" & vbCr ThisDrawing.SendCommand Val(cl1) & vbCr ThisDrawing.SendCommand "-Text" & vbCr ThisDrawing.SendCommand "R" & vbCr ThisDrawing.SendCommand dblY & "," & dblX & "," & dblZ & vbCr ThisDrawing.SendCommand "2.0" & vbCr ThisDrawing.SendCommand "90" & vbCr ThisDrawing.SendCommand Left(dblZ, 2) & vbCr ThisDrawing.SendCommand "-Layer" & vbCr ThisDrawing.SendCommand "Make" & vbCr ThisDrawing.SendCommand "WMH_SDEPTH" & vbCr ThisDrawing.SendCommand "" & vbCr ThisDrawing.SendCommand "-Text" & vbCr ThisDrawing.SendCommand "ML" & vbCr ThisDrawing.SendCommand dblY & "," & dblX & "," & dblZ & vbCr ThisDrawing.SendCommand "1.5" & vbCr ThisDrawing.SendCommand "90" & vbCr ThisDrawing.SendCommand Right(dblZ, 1) & vbCr ThisDrawing.SendCommand "zoom" & vbCr ThisDrawing.SendCommand "extents" & vbCr Else MsgBox "Error!!!!! Fail to Plot", 48, "HydroLab" End End If Loop ThisDrawing.SendCommand "zoom" & vbCr ThisDrawing.SendCommand "extents" & vbCr Close #myFile 'close file MsgBox "Plot Coordinates Completed" Me.Show End Sub Quote Link to comment Share on other sites More sharing options...
CmdrDuh Posted April 15, 2009 Share Posted April 15, 2009 for starters, I would get rid of all those send commands, as that is probably the problem. Send command doesn't wait for Autocad to finish what its doing before moving on to the next step, so you are probably out of synch Quote Link to comment Share on other sites More sharing options...
mien Posted April 15, 2009 Author Share Posted April 15, 2009 i already tried it, but it not working...can you help me with this.. Quote Link to comment Share on other sites More sharing options...
CmdrDuh Posted April 15, 2009 Share Posted April 15, 2009 start by looking at ThisDrawing.SetVariable Quote Link to comment Share on other sites More sharing options...
mien Posted April 15, 2009 Author Share Posted April 15, 2009 thanks CmdrDuh.... Quote Link to comment Share on other sites More sharing options...
CmdrDuh Posted April 15, 2009 Share Posted April 15, 2009 the other thing I see wrong is it doesn't look lilke you have declared your file other than here strFileName = mstrinpfile Quote Link to comment Share on other sites More sharing options...
mien Posted April 15, 2009 Author Share Posted April 15, 2009 i already declare it below option explicit..but it seem dont execute the if...elseif control structure,how can i overcome this problem CmdrDuh..thanks... Quote Link to comment Share on other sites More sharing options...
SEANT Posted April 16, 2009 Share Posted April 16, 2009 This is a method using direct VBA interaction with the drawing database. Warning: The example modifies, and only deals with a part of your process requirements. You will have to modify the routine to your desired specifications. As mentioned by CmdrDuh, investigate ThisDrawing.SetVariable, Get back to us if you have any problems with those modifications. Option Explicit Const pi As Double = 3.14159265 Sub CommandButton20_Click() Dim strFileName As String Dim myFile As Integer Dim outfile As String Dim strTextLine As String Dim arrText As Variant Dim point As AcadPoint Dim cllyr As AcadLayer Dim strName As String Dim acText As AcadText Dim dblPt(2) As Double Dim mintlv1 As Double Dim mintlv2 As Double Dim strTemp As String mintlv1 = -8# 'temp assignment mintlv2 = -10# 'temp assignment Set cllyr = ThisDrawing.Layers.Add("WMH_PDEPTH") cllyr.color = acGreen Set cllyr = ThisDrawing.Layers.Add("WMH_BDEPTH") cllyr.color = acBlue Set cllyr = ThisDrawing.Layers.Add("WMH_SDEPTH") cllyr.color = acRed With ThisDrawing.Utility strFileName = "C:\Hydro.txt" 'temp assignment 'On Error GoTo ErrorHandlerPoint If Dir(strFileName) = "" Then Call MsgBox(strFileName & " not found", vbExclamation, "Import XYZ Coordinates") Exit Sub 'GoTo TidyUpAndExit End If myFile = FreeFile Open strFileName For Input As #myFile Do While Not EOF(myFile) Line Input #myFile, strTextLine arrText = Split(strTextLine, ",") dblPt(0) = .DistanceToReal(arrText(0), acDecimal) dblPt(1) = .DistanceToReal(arrText(1), acDecimal) dblPt(2) = .DistanceToReal(arrText(2), acDecimal) Select Case dblPt(2) Case Is <= mintlv1 > mintlv2 Set point = ThisDrawing.ModelSpace.AddPoint(dblPt) point.Layer = "WMH_PDEPTH" strTemp = Left(arrText(2), 2) Set acText = ThisDrawing.ModelSpace.AddText(Left(arrText(2), 2), dblPt, 2#) acText.Alignment = acAlignmentRight acText.Rotation = pi / 2 acText.Layer = "WMH_BDEPTH" acText.TextAlignmentPoint = dblPt acText.Update strTemp = Right(arrText(2), 2) Set acText = ThisDrawing.ModelSpace.AddText(Right(arrText(2), 2), dblPt, 1.5) acText.Alignment = acAlignmentMiddleLeft acText.Rotation = pi / 2 acText.Layer = "WMH_SDEPTH" acText.TextAlignmentPoint = dblPt acText.Update Case Is <= mintlv2 Case Else End Select Loop ZoomExtents End With End Sub Quote Link to comment Share on other sites More sharing options...
mien Posted April 16, 2009 Author Share Posted April 16, 2009 im tried to classify the layer according to the colour...i make a modification but it not working. Public Sub Plot_Click() Me.Hide Dim strFileName As String Dim myFile As Integer Dim strTextLine As String Dim dblX As Double Dim dblY As Double Dim dblZ As Double Dim arrText As Variant Dim point As AcadPoint Dim cllyr As AcadLayer Dim strName As String Dim acText As AcadText Dim dblPt(0 To 2) As Double Dim strTemp As String With ThisDrawing.Utility strFileName = mstrinpfile 'On Error GoTo ErrorHandlerPoint If Dir(strFileName) = "" Then Call MsgBox(strFileName & " not found", vbExclamation, "Import XYZ Coordinates") 'GoTo TidyUpAndExit End If myFile = FreeFile Open strFileName For Input As #myFile Do While Not EOF(myFile) Line Input #myFile, strTextLine arrText = Split(strTextLine, ",") dblPt(0) = .DistanceToReal(arrText(0), acDecimal) dblPt(1) = .DistanceToReal(arrText(1), acDecimal) dblPt(2) = .DistanceToReal(arrText(2), acDecimal) Select Case dblPt(2) Case Is <= Val(mintlv1) Set point = ThisDrawing.ModelSpace.AddPoint(dblPt) point.Layer = "WMH_PDEPTH" Set cllyr = ThisDrawing.Layers.Add("WMH_PDEPTH") cllyr.color = Val(cl1) strTemp = Left(arrText(2), 3) Set acText = ThisDrawing.ModelSpace.AddText(Left(arrText(2), 3), dblPt, 2) acText.Alignment = acAlignmentRight acText.Rotation = 2 * pi acText.Layer = "WMH_BDEPTH" Set cllyr = ThisDrawing.Layers.Add("WMH_BDEPTH") cllyr.color = Val(cl1) acText.TextAlignmentPoint = dblPt acText.Update strTemp = Right(arrText(2), 1) Set acText = ThisDrawing.ModelSpace.AddText(Right(arrText(2), 1), dblPt, 1.5) acText.Alignment = acAlignmentMiddleLeft acText.Rotation = 2 * pi acText.Layer = "WMH_SDEPTH" Set cllyr = ThisDrawing.Layers.Add("WMH_SDEPTH") cllyr.color = Val(cl1) acText.TextAlignmentPoint = dblPt acText.Update Case Val(mintlv2) To Val(mintlv2a) Set point = ThisDrawing.ModelSpace.AddPoint(dblPt) point.Layer = "WMH_PDEPTH" Set cllyr = ThisDrawing.Layers.Add("WMH_PDEPTH") cllyr.color = Val(cl2) strTemp = Left(arrText(2), 3) Set acText = ThisDrawing.ModelSpace.AddText(Left(arrText(2), 3), dblPt, 2) acText.Alignment = acAlignmentRight acText.Rotation = 2 * pi acText.Layer = "WMH_BDEPTH" Set cllyr = ThisDrawing.Layers.Add("WMH_BDEPTH") cllyr.color = Val(cl2) acText.TextAlignmentPoint = dblPt acText.Update strTemp = Right(arrText(2), 1) Set acText = ThisDrawing.ModelSpace.AddText(Right(arrText(2), 1), dblPt, 1.5) acText.Alignment = acAlignmentMiddleLeft acText.Rotation = 2 * pi acText.Layer = "WMH_SDEPTH" Set cllyr = ThisDrawing.Layers.Add("WMH_SDEPTH") cllyr.color = Val(cl2) acText.TextAlignmentPoint = dblPt acText.Update Case Val(mintlv3) To Val(mintlv3a) Set point = ThisDrawing.ModelSpace.AddPoint(dblPt) point.Layer = "WMH_PDEPTH" Set cllyr = ThisDrawing.Layers.Add("WMH_PDEPTH") cllyr.color = Val(cl3) strTemp = Left(arrText(2), 3) Set acText = ThisDrawing.ModelSpace.AddText(Left(arrText(2), 3), dblPt, 2) acText.Alignment = acAlignmentRight acText.Rotation = 2 * pi acText.Layer = "WMH_BDEPTH" Set cllyr = ThisDrawing.Layers.Add("WMH_BDEPTH") cllyr.color = Val(cl3) acText.TextAlignmentPoint = dblPt acText.Update strTemp = Right(arrText(2), 1) Set acText = ThisDrawing.ModelSpace.AddText(Right(arrText(2), 1), dblPt, 1.5) acText.Alignment = acAlignmentMiddleLeft acText.Rotation = 2 * pi acText.Layer = "WMH_SDEPTH" Set cllyr = ThisDrawing.Layers.Add("WMH_SDEPTH") cllyr.color = Val(cl3) acText.TextAlignmentPoint = dblPt acText.Update Case Else MsgBox "Error!!!!! Plot Fail", 44, "HydroLab" End Select Loop ZoomExtents Close #myFile MsgBox "Plot Coordinates Completed" Me.Show End With End Sub Quote Link to comment Share on other sites More sharing options...
hontis Posted April 16, 2009 Share Posted April 16, 2009 where can you learn VB Quote Link to comment Share on other sites More sharing options...
BIGAL Posted April 17, 2009 Share Posted April 17, 2009 Mein just a suggestion rather than write lines and lines of code once you have a dwg set up save it as a DWT drawing template then it can be used all the time. We have a number of templates that are used for specific proceedures that have everything in them and then actually copy the drawing out into another working template (civ3d v's Acad) When creating your template I would use a script its much easier to do things like make numerous layers the layer script would be -Layer n MHOLE1 C 1 LT dashed n MHOLE2 C 2 LT dashed2 etc its easy to copy and paste and edit also the same for setting text styles etc just remember a script is like a recording of the commands you enter on the keyboard. You can type "setvar" "*" so you can easily cut and paste them into a script knowing which ones can take a little while to learn. some examples "osmode" snap values units setvars with settings SETVAR "LUNITS" 2 SETVAR "ANGBASE" 0.0 SETVAR "ANGDIR" 0 SETVAR "LUPREC" 0 SETVAR "AUNITS" 0 SETVAR "AUPREC" 0 I read you other code as well I would have thought you could type 1 line in a send.command with all the options rather than repeating with individual VbCr makes copying lines easier. Quote Link to comment Share on other sites More sharing options...
mien Posted April 17, 2009 Author Share Posted April 17, 2009 Thanks BIGAL....i will take ur advice... Quote Link to comment Share on other sites More sharing options...
SEANT Posted April 17, 2009 Share Posted April 17, 2009 Setting up a template is a sensible first step. With regard to the PM and run-time error '-2145386476(80200014), that was due to setting an object to a layer that had yet to be created. Flipping these lines would solve that. Quote Link to comment Share on other sites More sharing options...
mien Posted April 17, 2009 Author Share Posted April 17, 2009 thanks seant...... Quote Link to comment Share on other sites More sharing options...
