CRPPIPER Posted April 15, 2009 Share Posted April 15, 2009 i now have windows vista, i need to know how to get my autocad 2008 32-bit to work on windos vista 64-bit! any suggestions!!?? Quote Link to comment Share on other sites More sharing options...
lpseifert Posted April 15, 2009 Share Posted April 15, 2009 AFAIK you need a version of 64 bit Autocad. My installation disc for Civil 3D 2008 states for 'Windows Vista (32 bit)'. Attempts at installing on a 64 bit system have failed. I don't know if this holds true for vanilla Autocad. Your reseller should be able to supply you with the correct version. Quote Link to comment Share on other sites More sharing options...
ReMark Posted April 15, 2009 Share Posted April 15, 2009 The installation DVD should have both versions and recognize whether you are running a 32 or 64-bit system. Quote Link to comment Share on other sites More sharing options...
CRPPIPER Posted April 15, 2009 Author Share Posted April 15, 2009 lol.. ok.. well i tried to install it and it stoped and said i had 32-bit autocad that doesnt work on 64-bit system... ill just have to keep using my autocad on the old computer! the new computer is a nice touch screen 22" HP was looking forward to it! no worries Quote Link to comment Share on other sites More sharing options...
rkent Posted April 15, 2009 Share Posted April 15, 2009 Your reseller should be able to supply you with the correct version. Did you contact your reseller? Are you on subscription? Did you try contacting Autodesk? Quote Link to comment Share on other sites More sharing options...
ReMark Posted April 16, 2009 Share Posted April 16, 2009 If you have a DVD it should have both the 32-bit and the 64-bit version of AutoCAD 2008 on it. Mine does. However, if you have a CD there is not enough room on it to store both versions therefore you have to request the version you are missing from your authorized reseller or contact AutoDesk directly. Quote Link to comment Share on other sites More sharing options...
dewain0606 Posted June 27, 2009 Share Posted June 27, 2009 it doesnt work well u need 2009 for it 2 work Quote Link to comment Share on other sites More sharing options...
