At my last job they had a command or a lisp that took the exact shape of your view port and moved that same shape to the model space. This way you knew your drawing limits, so you got everything to show up in your view port.
Any suggestions?
Thank you!!
Draw a rectangle (or polyline) over your viewport, then use Chspace.
Lsp,
that's what I'm doing now. at my last job.. all i had to do is select the view port and it would do that for me. It does it so you don't have to draw a rect. and then chspace. Type " whatever it was" and select the vp.
I would love to be able to write it myself. I just have no clue how to create a lisp. I do want to learn, just really busy at work. I'm working in New Orleans rebuilding the levees and pump stations. 60 to 70 hour weeks. I was hoping someone had it available already.
Did this up real quick. Won't let you select the viewport, only works for the first viewport on the layout tab. If you only have one viewport on your layout, it should work just fine.
It basically does what you're doing, only automatically.
(defun c:vex()
 (setq osnapz (getvar "osmode"))
 (setvar "osmode" 0)
 (command "rectang" (cadr (cadr (vports))) (caddr (cadr (vports))))
 (command "chspace" (entlast) "")
 (command "pspace")
 (setvar "osmode" osnapz)
Just buildin on that:
(defun c:vex  (/ osnapz vp vpID)
 (if (and (setq vp (car (entsel "\nSelect Viewport: ")))
          (eq "VIEWPORT" (cdadr (entget vp))))
     (setq vpID (cdr (assoc (cdr (assoc 69 (entget vp))) (vports))))
     (setvar "osmode" 0)
     (command "rectang" (car vpID) (cadr vpID))
     (command "pspace")))
 (princ))
     (setvar "osmode" 0)
 (princ))
Nicely done, Lee. I was going to do something like that, but became daunted at the prospect of selection, checking to see if the selection was a viewport, and getting the limits from assoc 10, 40 and 41 and a bit of math. Should have known you'd come up with a slicker solution. ^^
