comcu Posted April 25, 2009 Share Posted April 25, 2009 Hi, i have the folllowing code to save values to excel Public strTitleBlockName As String Public MyTxtStr(0 To 7) As String Public Cnt, WorkbookOpen, RowCnt As Integer Public Excel As Excel.Application Public ExcelSheet, ExcelWorkbook As Object Public CurrRange As Range Public myvaratt As Variant Sub SaveCurrValues() If WorkbookOpen = 1 Then GoTo SkipCreatingWorkbook ' Launch Excel. Set Excel = New Excel.Application ' Create a new workbook and find the active sheet. Set ExcelWorkbook = Excel.Workbooks.Add Set ExcelSheet = Excel.ActiveWorkbook.ActiveSheet ExcelWorkbook.SaveAs "AutoGlassCalcStoredValues.xls", True Excel.Visible = False RowCnt = 1 With Worksheets("Sheet1") .Select .Range("a1").Activate End With MyTxtStr(0) = XOffset MyTxtStr(1) = YOffset MyTxtStr(2) = ScrRef MyTxtStr(3) = GlassSpec MyTxtStr(4) = GlassColRef MyTxtStr(5) = GlassRef MyTxtStr(6) = TextHeight MyTxtStr(7) = VPScale SkipCreatingWorkbook: Cnt = 3 For I = 0 To Cnt Set CurrRange = ActiveCell CurrRange.Value = MyTxtStr(I) CurrRange.Offset(0, 1).Select Next RowCnt = RowCnt + 1 With Worksheets("Sheet1") .Select .Range("a" & RowCnt).Activate End With WorkbookOpen = 1 'tell the sub that excel has already been opened ExcelWorkbook.Save ExcelWorkbook.Close ' Excel.Application.Quit 'Excel.Application. End Sub which works fine its getting the values back into the acad vba form i hvae tried the following but it retuns a error of object required?????? Sub LoadCurrValues() Dim oExcel As Excel.Application Dim oWB As Workbook Set oExcel = New Excel.Application Set oWB = oExcel.Workbooks.Open("AutoGlassCalcStoredValues") Set ExcelSheet = Excel.ActiveWorkbook.ActiveSheet TxBxXOffset.Value = oWB.Range("a1").Value TxBxYOffset.Value = Range("b1") TxBxScrRef.Value = Range("c1") TxBxSpec.Value = Range("d1") CboGlsSpcCol.Value = Range("e1") TxBxRef.Value = Range("f1") TxBxTHght.Value = Range("g1") TxBxVPScale.Value = Range("h1") ExcelWorkbook.Save ExcelWorkbook.Close ' Excel.Application.Quit 'Excel.Application. End Sub cheers for any help! col Quote Link to comment Share on other sites More sharing options...
bsamc2000 Posted April 28, 2009 Share Posted April 28, 2009 I played around with it a bit. I am using AutoCAD 2008 & 2010 with Excel 2007. I hope this helps. Sub LoadCurrValues() Dim oExcel As Excel.Application Dim oWB As Workbook Set oExcel = New Excel.Application Set oWB = oExcel.Workbooks.Open("c:\Testing.xls") Set Excelsheet = Excel.ActiveWorkbook.ActiveSheet TxBxXOffset.Value = Excelsheet.Range("a1").Value TxBxYOffset.Value = Excelsheet.Range("b1").Value TxBxScrRef.Value = Excelsheet.Range("c1").Value TxBxSpec.Value = Excelsheet.Range("d1").Value CboGlsSpcCol.Value = Excelsheet.Range("e1").Value TxBxRef.Value = Excelsheet.Range("f1").Value TxBxTHght.Value = Excelsheet.Range("g1").Value TxBxVPScale.Value = Excelsheet.Range("h1").Value oWB.Save oExcel.Quit End Sub Quote Link to comment Share on other sites More sharing options...
comcu Posted April 29, 2009 Author Share Posted April 29, 2009 Brian, thank you for your reply. i have got the following code working fine on Acad2009 with excel 2007 but on acad 2008 excel 2003 it returns the error invalid use of the New Keyword??? Sub LoadCurrValues() Dim oExcel As Excel.Application Dim oWB As Workbook Dim ExcelSheet As Object Dim ExcelWorkbook As Object On Error Resume Next Set oExcel = New Excel.Application Set oWB = oExcel.Workbooks.Open("AutoGlassCalcStoredValues") oExcel.Visible = False 'Set ExcelSheet = Excel.ActiveSheet 'set oExcel.Range(a1).Value UFcreateGlassAtt.TxBxXOffset.Value = oWB.ActiveSheet.Range("A1").Value UFcreateGlassAtt.TxBxYOffset.Value = oWB.ActiveSheet.Range("B1").Value UFcreateGlassAtt.TxBxScrRef.Value = oWB.ActiveSheet.Range("C1").Value UFcreateGlassAtt.TxBxSpec.Value = oWB.ActiveSheet.Range("D1").Value UFcreateGlassAtt.CboGlsSpcCol.Value = oWB.ActiveSheet.Range("E1").Value UFcreateGlassAtt.TxBxRef.Value = oWB.ActiveSheet.Range("F1").Value UFcreateGlassAtt.TxBxTHght.Value = oWB.ActiveSheet.Range("G1").Value UFcreateGlassAtt.TxBxVPScale.Value = oWB.ActiveSheet.Range("H1").Value oWB.Save oWB.Close If Err Then Err.Clear ' Excel.Application.Quit 'Excel.Application. End Sub Quote Link to comment Share on other sites More sharing options...
bsamc2000 Posted April 29, 2009 Share Posted April 29, 2009 From my experience, the reference between Excel 2003 and 2007 are different. I think that if you use CreateObject(“Excel.Application”) it will work with both, but I’m not intirely sure as I no longer have 2003 installed. I did run into this before but I don’t remember how I handled it. If no one else comes up with an answer before long I will try to dig though some of my older code to find it. Dim excelObj As Object Set excelObj = CreateObject("excel.Application") excelObj.Visible = True excelObj.workbooks.Open ("c:\testing.xls") Quote Link to comment Share on other sites More sharing options...
comcu Posted April 29, 2009 Author Share Posted April 29, 2009 thanks Brian, i will look thru some of my other codes as i am sure i have done this before with excel and it worked on both 2009 and 2009 acad so im not sure if it is something else that is causing it? i will have to look it out and compare. cheers, col Quote Link to comment Share on other sites More sharing options...
comcu Posted April 29, 2009 Author Share Posted April 29, 2009 Hi, i managed to find this example online for excel 2003 Sub BringToLife() On Error Resume Next Dim e As Excel.Application Set e = New Excel.Application e.Visible = True e.Workbooks.Add e.Worksheets(“Sheet1”).Cells(4, 4).Value = 256 If Err Then MsgBox Error$ End Sub an to me it looks as tho i am doing it correctly? their must be something else causing the error but for some reason is coming back an error on the "New Excel.Application" part of the code...? cheers, col Quote Link to comment Share on other sites More sharing options...
