Hello again,
When having multiple dwg's with multiple layouts per dwg: how can I create a drawing list? Each layout has a stamp called "title" that has several attributes like date, name and so on.
I wonder if it is possible since all layouts use the same block for stamp, so all the same attributes will be present several times.
This must be around but the search engines don't show me ....
Thanks for all the help.
Hello
A example
(defun c:lstdwg(/ dirbox Ouvrir_dessin_dbx rep lst fic dbx lay)
 (defun dirbox(/ cdl rep)
   (if (setq cdl (vlax-create-object "Shell.Application"))
   (and (setq rep (vlax-invoke cdl 'browseforfolder 0 "Choose a directory" 512 ""))
        (setq rep (vlax-get-property (vlax-get-property rep 'self) 'path))
   (vlax-release-object cdl)
   rep
 (defun Ouvrir_dessin_dbx(dwg / dbx doc lan)
   (vl-load-com)
   (setq dwg (findfile dwg))
   (vlax-for doc (vla-get-documents (vlax-get-acad-object))
     (and (eq (strcase (vla-get-fullname doc)) (strcase dwg))
   (setq dbx doc lan T)
   (or dbx
   (if (< (atoi (substr (getvar "ACADVER") 1 2)) 16)
     (setq dbx (vlax-create-object "ObjectDBX.AxDbDocument"))
     (setq dbx (vlax-create-object (strcat "ObjectDBX.AxDbDocument." (substr (getvar "ACADVER") 1 2))))
   (vla-open dbx dwg)
   (list dbx lan)
 (vl-load-com)
 (if (setq rep (dirbox))
   (if (setq lst (vl-directory-files rep "*.dwg" 1))
     (foreach fic lst
   (if (setq dbx (ouvrir_dessin_dbx (strcat rep "/" fic)))
       (princ (strcat "\n Working in " fic))(princ)
       (vlax-for lay (vla-get-layouts (car dbx))
         (princ (strcat "\n\t\tLayout : " (vla-get-name lay)))(princ)
       (or (cadr dbx)(vlax-release-object (car dbx)))
     (princ (strcat "\n Can't read file " fic))
     (alert "No dwg's File")
Hi Patrick,
Thank you for your reply.
When executing the command it shows me the drawing names with its layoutnames. I wanted to go further, read out the stamps attributes.
I might try it myself (to add some functions) but I'm not that brilliant in lisp as you guys.
Gr.,
Marco.
Hi
It might be well to focus research
one can search for all attributes in a drawing with the example given, but it risks taking some time and a massive amount of information to be processed.
You have an example that looks for attributes of a drawing.
