dbroada Posted May 5, 2009 Posted May 5, 2009 I have a title block with several attributes. I know how to get all the attribute values using VBA but I was hoping to jut determine the value of one of them. It is something I think I should know how to do, but if I did then I've forgotten. I have something like.... myAttibutes = myBlock.GetAttributes for i = 0 to ubound(myAttributes) debug.print myAttributes(i).TagString;myAttributes(i).TextString next i Can anybody help me determine the text value of the attibute TagString = "Title1" without stepping through them all? Quote
CmdrDuh Posted May 5, 2009 Posted May 5, 2009 I dont think you can do it unless you know the index value of the tag in the block. I have code to step through them if you want it. Quote
CmdrDuh Posted May 5, 2009 Posted May 5, 2009 I use this code to update my attributes, but you can tweak it to read the value of an attribute For Each objBlkRef In objSelSet If objBlkRef.HasAttributes Then varAtts = objBlkRef.GetAttributes For intAElems = LBound(varAtts) To UBound(varAtts) Set objAttRef = varAtts(intAElems) If objAttRef.TagString = strTagName Then strOrigTagValue = objAttRef.TextString If Len(strNewTagValue) > 0 Then objAttRef.TextString = strNewTagValue Exit For End If End If Next intAElems End If Next objBlkRef Quote
dbroada Posted May 5, 2009 Author Posted May 5, 2009 Thanks, I am looking for 4 out of 15 so its not a big problem to step through, which is what I have done but I thought I had seen a way to home in on one once you knew the TagString. Oh well, I'll stick with what I've got. Quote
CmdrDuh Posted May 5, 2009 Posted May 5, 2009 There might be a way to go directly to it, I can look if you want Quote
dbroada Posted May 5, 2009 Author Posted May 5, 2009 There might be a way to go directly to it, I can look if you want I'm not overly fussed now as what I have works well enough - however if do you find out...... Quote
BIGAL Posted May 6, 2009 Posted May 6, 2009 Hi guys not sure but have a look at my last post it searches all blocks and only picks out 1 to update I use the attrib value (x) not tagstring in the block the attrib(x) is always unique atributes are attribs(0) attribs(1) etc easier than tag strings PS missing bit of code is a function that lets the user pick text or block in the drawing as the key to find the one block with attrib(0) = key here is also a title block update routine may be usefull Public Sub issued_for_construction()' This Updates the Issued for construction and sets rev 0 Dim SS As AcadSelectionSetDim Count As IntegerDim FilterDXFCode(1) As IntegerDim FilterDXFVal(1) As VariantDim attribs As VariantDim BLOCK_NAME As StringOn Error Resume NextFilterDXFCode(0) = 0FilterDXFVal(0) = "INSERT"FilterDXFCode(1) = 2FilterDXFVal(1) = "DA1DRTXT"BLOCK_NAME = "DA1DRTXT"Set SS = ThisDrawing.SelectionSets.Add("issued")SS.Select acSelectionSetAll, , , FilterDXFCode, FilterDXFVal For Cntr = 0 To SS.Count - 1 attribs = SS.Item(Cntr).GetAttributes attribs(0).TextString = "ISSUED FOR CONSTRUCTION" attribs(3).TextString = "0" attribs(0).Update attribs(3).Update Next CntrThisDrawing.SelectionSets.Item("issued").Delete'DO AGAIN FOR REVTABLE'DATE'Dim MyDate'MyDate = DateCall DashDateFilterDXFCode(1) = 2FilterDXFVal(1) = "REVTABLE"BLOCK_NAME = "REVTABLE"Set SS = ThisDrawing.SelectionSets.Add("revs")SS.Select acSelectionSetAll, , , FilterDXFCode, FilterDXFVal For Cntr = 0 To SS.Count - 1 attribs = SS.Item(Cntr).GetAttributes attribs(0).TextString = "0" attribs(1).TextString = DashDate attribs(2).TextString = "ISSUED FOR CONSTRUCTION" attribs(0).Update attribs(1).Update attribs(2).Update Next CntrThisDrawing.SelectionSets.Item("revs").DeleteMsgBox "Drawing now changed to Issued for Construction"End Sub[code] Quote
dbroada Posted May 6, 2009 Author Posted May 6, 2009 I know that Attribute(3) will work but this routine has to work on 15 year's worth of borders of varing sizes and revisions. All have Attribute("Title1") but they won't all have Attribute(3) = "Title1", some will be Attrbute(0), some Attribute(20). I had hoped I could go directly to "Title1" as I thought I had seen it done before but it works stepping through so I'm happy. For sake of completeness here is my code. Very quick & dirty and could easilly be improved but it works so I expect it will stay. Option Explicit Private Sub cmdDown_Click() Dim myString As String Select Case Label5.Caption Case Is = "1" myString = lblTag1.Caption lblTag1.Caption = lblTag2.Caption lblTag2.Caption = myString Label5.Caption = "2" lblTag2.SpecialEffect = fmSpecialEffectEtched lblTag1.SpecialEffect = fmSpecialEffectSunken Case Is = "2" myString = lblTag2.Caption lblTag2.Caption = lblTag3.Caption lblTag3.Caption = myString Label5.Caption = "3" lblTag3.SpecialEffect = fmSpecialEffectEtched lblTag2.SpecialEffect = fmSpecialEffectSunken Case Is = "3" myString = lblTag3.Caption lblTag3.Caption = lblTag4.Caption lblTag4.Caption = myString Label5.Caption = "4" lblTag4.SpecialEffect = fmSpecialEffectEtched lblTag3.SpecialEffect = fmSpecialEffectSunken End Select End Sub Private Sub cmdExit_Click() Unload Me End Sub Private Sub cmdPopulate_Click() Dim myObject As Object Dim mySelectionSet As AcadSelectionSet Dim myAttributes As Variant Set mySelectionSet = ThisDrawing.SelectionSets.Add("Fred") Dim gpCode(0 To 1) As Integer Dim dataValue(0 To 1) As Variant Dim groupCode As Variant Dim dataCode As Variant gpCode(0) = 2 'name gpCode(1) = 0 'item groupCode = gpCode dataValue(0) = "STLA*" 'layer name dataValue(1) = "INSERT" 'item type dataCode = dataValue mySelectionSet.Select acSelectionSetAll, , , groupCode, dataCode Set myObject = mySelectionSet.Item(0) myAttributes = myObject.GetAttributes If lblTag1.Caption <> "" Then myAttributes(Label1).TextString = lblTag1.Caption Else myAttributes(Label1).TextString = "" End If If lblTag2.Caption <> "" Then myAttributes(Label2).TextString = lblTag2.Caption Else myAttributes(Label2).TextString = "" End If If lblTag3.Caption <> "" Then myAttributes(Label3).TextString = lblTag3.Caption Else myAttributes(Label3).TextString = "" End If If lblTag4.Caption <> "" Then myAttributes(Label4).TextString = lblTag4.Caption Else myAttributes(Label4).TextString = "" End If ThisDrawing.SelectionSets.Item("Fred").Delete Unload Me End Sub Private Sub cmdUp_Click() Dim myString As String Select Case Label5.Caption Case Is = "2" myString = lblTag2.Caption lblTag2.Caption = lblTag1.Caption lblTag1.Caption = myString Label5.Caption = "1" lblTag1.SpecialEffect = fmSpecialEffectEtched lblTag2.SpecialEffect = fmSpecialEffectSunken Case Is = "3" myString = lblTag3.Caption lblTag3.Caption = lblTag2.Caption lblTag2.Caption = myString Label5.Caption = "2" lblTag2.SpecialEffect = fmSpecialEffectEtched lblTag3.SpecialEffect = fmSpecialEffectSunken Case Is = "4" myString = lblTag4.Caption lblTag4.Caption = lblTag3.Caption lblTag3.Caption = myString Label5.Caption = "3" lblTag3.SpecialEffect = fmSpecialEffectEtched lblTag4.SpecialEffect = fmSpecialEffectSunken End Select End Sub Private Sub lblTag1_Click() Label5.Caption = "1" lblTag1.SpecialEffect = fmSpecialEffectEtched lblTag2.SpecialEffect = fmSpecialEffectSunken lblTag3.SpecialEffect = fmSpecialEffectSunken lblTag4.SpecialEffect = fmSpecialEffectSunken End Sub Private Sub lblTag2_Click() Label5.Caption = "2" lblTag2.SpecialEffect = fmSpecialEffectEtched lblTag1.SpecialEffect = fmSpecialEffectSunken lblTag3.SpecialEffect = fmSpecialEffectSunken lblTag4.SpecialEffect = fmSpecialEffectSunken End Sub Private Sub lblTag3_Click() Label5.Caption = "3" lblTag3.SpecialEffect = fmSpecialEffectEtched lblTag1.SpecialEffect = fmSpecialEffectSunken lblTag2.SpecialEffect = fmSpecialEffectSunken lblTag4.SpecialEffect = fmSpecialEffectSunken End Sub Private Sub lblTag4_Click() Label5.Caption = "4" lblTag4.SpecialEffect = fmSpecialEffectEtched lblTag1.SpecialEffect = fmSpecialEffectSunken lblTag2.SpecialEffect = fmSpecialEffectSunken lblTag3.SpecialEffect = fmSpecialEffectSunken End Sub Private Sub UserForm_Initialize() Dim i As Integer Dim myObject As Object Dim mySelectionSet As AcadSelectionSet Dim myAttributes As Variant Set mySelectionSet = ThisDrawing.SelectionSets.Add("Fred") Dim gpCode(0 To 1) As Integer Dim dataValue(0 To 1) As Variant Dim groupCode As Variant Dim dataCode As Variant gpCode(0) = 2 'name gpCode(1) = 0 'item groupCode = gpCode dataValue(0) = "STLA*" 'layer name dataValue(1) = "INSERT" 'item type dataCode = dataValue mySelectionSet.Select acSelectionSetAll, , , groupCode, dataCode If mySelectionSet.Count = 1 Then 'a block has been selected Set myObject = mySelectionSet.Item(0) myAttributes = myObject.GetAttributes For i = 0 To UBound(myAttributes) - 1 If myAttributes(i).TagString = "TITLE1" Then lblTag1 = myAttributes(i).TextString Label1 = i End If If myAttributes(i).TagString = "TITLE2" Then lblTag2 = myAttributes(i).TextString Label2 = i End If If myAttributes(i).TagString = "TITLE3" Then lblTag3 = myAttributes(i).TextString Label3 = i End If If myAttributes(i).TagString = "TITLE4" Then lblTag4 = myAttributes(i).TextString Label4 = i End If Next i Else MsgBox "This ONLY works with 1 Drawing Border" End If ThisDrawing.SelectionSets.Item("Fred").Delete End Sub It basically gets the 4 "title" attributes from one of our borders and displays them on a form. You can then shuffle the order of the attributes and write them back to the title block. Quote
