cadguyfrompti Posted May 20, 2009 Share Posted May 20, 2009 Well, i finally got sick of having to reselect items during modifying properties etc and got a little crazy to figure out why it acts that way. The conclusion I've made is that the system variable "DIASTAT" must be doing it. If I load Mechanical desktop normal(software doesn't deselect then), the value for this field is "1 - read only". When i load ShipContructor 2008, the value magically changes to "0 - read only". Acad help says: DIASTAT Stores the exit method of the most recently used dialog box. 0 Cancel 1 OK Now, how on earth or can I fix the software to make it so as it loads as 1 instead of 0 at this value? Quote Link to comment Share on other sites More sharing options...
GE13579 Posted May 22, 2009 Share Posted May 22, 2009 Are you sure it's related to DIASTAT? I have no idea about the command but mine is also set to 1 and I have no problem with adjusting properties. I assume you're meaning changing the properties dialogue box? Are you certain it's not related to PICKADD or PICKFIRST system variables? Quote Link to comment Share on other sites More sharing options...
