Complete VBA rookie here:
I was going through an autodesk tutorial on connecting to Access. Part of the tutorial is the following code:
Public wksObj As Workspace
Public dbsObj As Database
Public tblObj As TableDef
Public fldObj As Field
Public rstObj As Recordset
Private Sub CommandButton1_Click()
On Error Resume Next
Set wksObj = DBEngine.Workspaces(0)
Set dbsObj = wksObj!CreateDatabase("mydbase.mdb", dbLangGeneral)
Set tblObj = dbsObj!CreateTableDef("mytable")
With tblObj
.Fields.Append .CreateField("text", dbText)
.Fields.Append .CreateField("integer", dbInteger)
.Fields.Append .CreateField("long", dbLong)
.Fields.Append .CreateField("double", dbDouble)
.Fields.Append .CreateField("boolean", dbBoolean)
.Fields.Append .CreateField("memo", dbMemo)
.Fields.Append .CreateField("currency", dbCurrency)
.Fields.Append .CreateField("date", dbDate)
End With
dbsObj.TableDefs.Append tblObj
dbsObj.TableDefs.Refresh
End Sub
Private Sub CommandButton2_Click()
Set dbsObj = DBEngine.Workspaces(0).OpenDatabase("mydbase.mdb")
Set rstObj = dbsObj.OpenRecordset("mytable", dbOpenTable)
rstObj.AddNew
rstObj!Text = "a text value"
rstObj!integer = 1
rstObj!double = 3.1415926
rstObj!Boolean = True
rstObj!currency = "$4,240.54"
rstObj!Date = "2/10/00"
rstObj.Update
rstObj.Close Set dbsObj = Nothing
End Sub
Private Sub CommandButton3_Click()
Unload Me
End Sub
I'm getting a syntax error on the last code line for command button 2 (Highlighted in red bold)
The error I'm getting is: Compile error / Syntax error.
Can anyone enlighten me on what the syntax error is? I'm assuming that it has something to do with closing dbsObj and setting it to nil.
Thanks...
AJS
It may be as simple as:
rstObj.Close
in other words, put each statements on a separate line.
