Lisp for filtering certain blocks and delete them
MarcoW
I am looking for a lisp file that can do following:
After giving command "fildel" it should scan the drawing for blocks of a certain name ie. "titleblock". When it has done so it should prompt "Drawing contains x blocks called "titleblock" - What to do: or ?"
A + enter will delete all those titleblocks.
S + enter will propmt user for crossing to select part of drawing to do so.
I have been messing a few hours with codes out of
http://www.cadtutor.net/forum/showthread.php?t=34972
but I can't manage to do so without additional commands in my diesle strings, like ^C^C^fildel;titleblock;????
Anyway, I guess I can't figure it out, so please help me. (Not only by prviding the code but how to do so.)
Also went to:
http://afralisp.net/lispa/lisp19.htm
Gives me headache :-)
  • Replies 52
  • Lee Mac
    15
  • Patrick_35
    7
  • Bobzy20
    7
  • vernonlee
    7
Try this mate:
[b][color=RED]([/color][/b][b][color=BLUE]defun[/color][/b] c:fildel [b][color=RED]([/color][/b][b][color=BLUE]/[/color][/b] bdef blk ss tmp uss[b][color=RED])[/color][/b]
 [b][color=RED]([/color][/b][b][color=BLUE]vl-load-com[/color][/b][b][color=RED])[/color][/b]
 [b][color=RED]([/color][/b][b][color=BLUE]or[/color][/b] *fil:del* [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] *fil:del* [b][color=#ff00ff]"All"[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
 [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] bdef [b][color=RED]([/color][/b][b][color=BLUE]getvar[/color][/b] [b][color=#ff00ff]"INSNAME"[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
 [b][color=RED]([/color][/b][b][color=BLUE]while[/color][/b]
   [b][color=RED]([/color][/b][b][color=BLUE]progn[/color][/b]
     [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] blk
       [b][color=RED]([/color][/b][b][color=BLUE]getstring[/color][/b] t
         [b][color=RED]([/color][/b][b][color=BLUE]strcat[/color][/b] [b][color=#ff00ff]"\nSpecify Block Name <"[/color][/b] bdef [b][color=#ff00ff]">: "[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
     [b][color=RED]([/color][/b][b][color=BLUE]cond[/color][/b] [b][color=RED]([/color][/b][b][color=RED]([/color][/b][b][color=BLUE]eq[/color][/b] [b][color=#ff00ff]""[/color][/b] blk[b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] blk bdef[b][color=RED])[/color][/b] [b][color=BLUE]nil[/color][/b][b][color=RED])[/color][/b]
           [b][color=RED]([/color][/b][b][color=RED]([/color][/b][b][color=BLUE]not[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]snvalid[/color][/b] blk[b][color=RED])[/color][/b][b][color=RED])[/color][/b]
            [b][color=RED]([/color][/b][b][color=BLUE]princ[/color][/b] [b][color=#ff00ff]"\n** Invalid Block Name **"[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
           [b][color=RED]([/color][/b][b][color=RED]([/color][/b][b][color=BLUE]not[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]tblsearch[/color][/b] [b][color=#ff00ff]"BLOCK"[/color][/b] blk[b][color=RED])[/color][/b][b][color=RED])[/color][/b]
            [b][color=RED]([/color][/b][b][color=BLUE]princ[/color][/b] [b][color=#ff00ff]"\n** Block Not Found in Drawing **"[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
           [b][color=RED]([/color][/b][b][color=BLUE]t[/color][/b] [b][color=BLUE]nil[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [i][color=#990099]; Exit Loop[/color][/i]
 [b][color=RED]([/color][/b][b][color=BLUE]if[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] ss [b][color=RED]([/color][/b][b][color=BLUE]ssget[/color][/b] [b][color=#ff00ff]"_X"[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]list[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]cons[/color][/b] [b][color=#009900]0[/color][/b] [b][color=#ff00ff]"INSERT"[/color][/b][b][color=RED])[/color][/b]
                                [b][color=RED]([/color][/b][b][color=BLUE]cons[/color][/b] [b][color=#009900]2[/color][/b] blk[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
     [b][color=RED]([/color][/b][b][color=BLUE]princ[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]strcat[/color][/b] [b][color=#ff00ff]"\nDrawing Contains "[/color][/b]
                    [b][color=RED]([/color][/b][b][color=BLUE]rtos[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]sslength[/color][/b] ss[b][color=RED])[/color][/b] [b][color=#009900]2[/color][/b] [b][color=#009900]0[/color][/b][b][color=RED])[/color][/b] [b][color=#ff00ff]" Blocks with Name: "[/color][/b] blk[b][color=RED])[/color][/b][b][color=RED])[/color][/b]
     [b][color=RED]([/color][/b][b][color=BLUE]initget[/color][/b] [b][color=#ff00ff]"All Selection"[/color][/b][b][color=RED])[/color][/b]
     [b][color=RED]([/color][/b][b][color=BLUE]or[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]not[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] tmp
                [b][color=RED]([/color][/b][b][color=BLUE]getkword[/color][/b]
                  [b][color=RED]([/color][/b][b][color=BLUE]strcat[/color][/b] [b][color=#ff00ff]"\nDelete [A]ll or [s]election? <"[/color][/b] *fil:del* [b][color=#ff00ff]"> : "[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
         [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] *fil:del* tmp[b][color=RED])[/color][/b][b][color=RED])[/color][/b]
     [b][color=RED]([/color][/b][b][color=BLUE]cond[/color][/b] [b][color=RED]([/color][/b][b][color=RED]([/color][/b][b][color=BLUE]eq[/color][/b] *fil:del* [b][color=#ff00ff]"Selection"[/color][/b][b][color=RED])[/color][/b]
            [b][color=RED]([/color][/b][b][color=BLUE]while[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]not[/color][/b] uss[b][color=RED])[/color][/b]
              [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] uss [b][color=RED]([/color][/b][b][color=BLUE]ssget[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]list[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]cons[/color][/b] [b][color=#009900]0[/color][/b] [b][color=#ff00ff]"INSERT"[/color][/b][b][color=RED])[/color][/b]
                                     [b][color=RED]([/color][/b][b][color=BLUE]cons[/color][/b] [b][color=#009900]2[/color][/b] blk[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
            [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] ss uss[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
     [b][color=RED]([/color][/b][b][color=BLUE]mapcar[/color][/b] [b][color=DARKRED]'[/color][/b][b][color=BLUE]entdel[/color][/b]
       [b][color=RED]([/color][/b][b][color=BLUE]vl-remove-if[/color][/b] [b][color=DARKRED]'[/color][/b][b][color=BLUE]listp[/color][/b]
         [b][color=RED]([/color][/b][b][color=BLUE]mapcar[/color][/b] [b][color=DARKRED]'[/color][/b][b][color=BLUE]cadr[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]ssnamex[/color][/b] ss[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
 [b][color=RED]([/color][/b][b][color=BLUE]princ[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
:shock: OMG :?
This is like "wonderful", I mean great, you know, perfectly.
Lee you allways seem to know all the solutions allthough I know you are doing lisp for like 10 months or so.
Thank you very much for your routine. It works great and I will use it.
:shock: OMG :?
I'm glad you like it :D
Thanks Marco
  • 1 month later...
Hi,
above routine doesn't delete blocks in multiple layouts.
It deletes only blocks in current active layout.
If you can update above routine, it will be great help.
Thanks,
Ashish
So it would be to me but hey, can't have it all I thought.
I'm not capable of doing so, sorry mate.
Maybe Lee has a solution...
Try this mate:
[b][color=red]([/color][/b][b][color=blue]defun[/color][/b] c:fildel [b][color=red]([/color][/b][b][color=blue]/[/color][/b] bdef blk ss tmp uss[b][color=red])[/color][/b]
 [b][color=red]([/color][/b][b][color=blue]vl-load-com[/color][/b][b][color=red])[/color][/b]
 [b][color=red]([/color][/b][b][color=blue]or[/color][/b] *fil:del* [b][color=red]([/color][/b][b][color=blue]setq[/color][/b] *fil:del* [b][color=#ff00ff]"All"[/color][/b][b][color=red])[/color][/b][b][color=red])[/color][/b]
 [b][color=red]([/color][/b][b][color=blue]setq[/color][/b] bdef [b][color=red]([/color][/b][b][color=blue]getvar[/color][/b] [b][color=#ff00ff]"INSNAME"[/color][/b][b][color=red])[/color][/b][b][color=red])[/color][/b]
 [b][color=red]([/color][/b][b][color=blue]while[/color][/b]
   [b][color=red]([/color][/b][b][color=blue]progn[/color][/b]
     [b][color=red]([/color][/b][b][color=blue]setq[/color][/b] blk
       [b][color=red]([/color][/b][b][color=blue]getstring[/color][/b] t
         [b][color=red]([/color][/b][b][color=blue]strcat[/color][/b] [b][color=#ff00ff]"\nSpecify Block Name <"[/color][/b] bdef [b][color=#ff00ff]">: "[/color][/b][b][color=red])[/color][/b][b][color=red])[/color][/b][b][color=red])[/color][/b]
     [b][color=red]([/color][/b][b][color=blue]cond[/color][/b] [b][color=red]([/color][/b][b][color=red]([/color][/b][b][color=blue]eq[/color][/b] [b][color=#ff00ff]""[/color][/b] blk[b][color=red])[/color][/b] [b][color=red]([/color][/b][b][color=blue]setq[/color][/b] blk bdef[b][color=red])[/color][/b] [b][color=blue]nil[/color][/b][b][color=red])[/color][/b]
           [b][color=red]([/color][/b][b][color=red]([/color][/b][b][color=blue]not[/color][/b] [b][color=red]([/color][/b][b][color=blue]snvalid[/color][/b] blk[b][color=red])[/color][/b][b][color=red])[/color][/b]
            [b][color=red]([/color][/b][b][color=blue]princ[/color][/b] [b][color=#ff00ff]"\n** Invalid Block Name **"[/color][/b][b][color=red])[/color][/b][b][color=red])[/color][/b]
           [b][color=red]([/color][/b][b][color=red]([/color][/b][b][color=blue]not[/color][/b] [b][color=red]([/color][/b][b][color=blue]tblsearch[/color][/b] [b][color=#ff00ff]"BLOCK"[/color][/b] blk[b][color=red])[/color][/b][b][color=red])[/color][/b]
            [b][color=red]([/color][/b][b][color=blue]princ[/color][/b] [b][color=#ff00ff]"\n** Block Not Found in Drawing **"[/color][/b][b][color=red])[/color][/b][b][color=red])[/color][/b]
           [b][color=red]([/color][/b][b][color=blue]t[/color][/b] [b][color=blue]nil[/color][/b][b][color=red])[/color][/b][b][color=red])[/color][/b][b][color=red])[/color][/b][b][color=red])[/color][/b] [i][color=#990099]; Exit Loop[/color][/i]
 [b][color=red]([/color][/b][b][color=blue]if[/color][/b] [b][color=red]([/color][/b][b][color=blue]setq[/color][/b] ss [b][color=red]([/color][/b][b][color=blue]ssget[/color][/b] [b][color=#ff00ff]"_X"[/color][/b] [b][color=red]([/color][/b][b][color=blue]list[/color][/b] [b][color=red]([/color][/b][b][color=blue]cons[/color][/b] [b][color=#009900]0[/color][/b] [b][color=#ff00ff]"INSERT"[/color][/b][b][color=red])[/color][/b]
                                [b][color=red]([/color][/b][b][color=blue]cons[/color][/b] [b][color=#009900]2[/color][/b] blk[b][color=red])[/color][/b][b][color=red])[/color][/b][b][color=red])[/color][/b][b][color=red])[/color][/b]
     [b][color=red]([/color][/b][b][color=blue]princ[/color][/b] [b][color=red]([/color][/b][b][color=blue]strcat[/color][/b] [b][color=#ff00ff]"\nDrawing Contains "[/color][/b]
                    [b][color=red]([/color][/b][b][color=blue]rtos[/color][/b] [b][color=red]([/color][/b][b][color=blue]sslength[/color][/b] ss[b][color=red])[/color][/b] [b][color=#009900]2[/color][/b] [b][color=#009900]0[/color][/b][b][color=red])[/color][/b] [b][color=#ff00ff]" Blocks with Name: "[/color][/b] blk[b][color=red])[/color][/b][b][color=red])[/color][/b]
     [b][color=red]([/color][/b][b][color=blue]initget[/color][/b] [b][color=#ff00ff]"All Selection"[/color][/b][b][color=red])[/color][/b]
     [b][color=red]([/color][/b][b][color=blue]or[/color][/b] [b][color=red]([/color][/b][b][color=blue]not[/color][/b] [b][color=red]([/color][/b][b][color=blue]setq[/color][/b] tmp
                [b][color=red]([/color][/b][b][color=blue]getkword[/color][/b]
                  [b][color=red]([/color][/b][b][color=blue]strcat[/color][/b] [b][color=#ff00ff]"\nDelete [A]ll or [s]election? <"[/color][/b] *fil:del* [b][color=#ff00ff]"> : "[/color][/b][b][color=red])[/color][/b][b][color=red])[/color][/b][b][color=red])[/color][/b][b][color=red])[/color][/b]
         [b][color=red]([/color][/b][b][color=blue]setq[/color][/b] *fil:del* tmp[b][color=red])[/color][/b][b][color=red])[/color][/b]
     [b][color=red]([/color][/b][b][color=blue]cond[/color][/b] [b][color=red]([/color][/b][b][color=red]([/color][/b][b][color=blue]eq[/color][/b] *fil:del* [b][color=#ff00ff]"Selection"[/color][/b][b][color=red])[/color][/b]
            [b][color=red]([/color][/b][b][color=blue]while[/color][/b] [b][color=red]([/color][/b][b][color=blue]not[/color][/b] uss[b][color=red])[/color][/b]
              [b][color=red]([/color][/b][b][color=blue]setq[/color][/b] uss [b][color=red]([/color][/b][b][color=blue]ssget[/color][/b] [b][color=red]([/color][/b][b][color=blue]list[/color][/b] [b][color=red]([/color][/b][b][color=blue]cons[/color][/b] [b][color=#009900]0[/color][/b] [b][color=#ff00ff]"INSERT"[/color][/b][b][color=red])[/color][/b]
                                     [b][color=red]([/color][/b][b][color=blue]cons[/color][/b] [b][color=#009900]2[/color][/b] blk[b][color=red])[/color][/b][b][color=red])[/color][/b][b][color=red])[/color][/b][b][color=red])[/color][/b][b][color=red])[/color][/b]
            [b][color=red]([/color][/b][b][color=blue]setq[/color][/b] ss uss[b][color=red])[/color][/b][b][color=red])[/color][/b][b][color=red])[/color][/b]
     [b][color=red]([/color][/b][b][color=blue]mapcar[/color][/b] [b][color=darkred]'[/color][/b][b][color=blue]entdel[/color][/b]
       [b][color=red]([/color][/b][b][color=blue]vl-remove-if[/color][/b] [b][color=darkred]'[/color][/b][b][color=blue]listp[/color][/b]
         [b][color=red]([/color][/b][b][color=blue]mapcar[/color][/b] [b][color=darkred]'[/color][/b][b][color=blue]cadr[/color][/b] [b][color=red]([/color][/b][b][color=blue]ssnamex[/color][/b] ss[b][color=red])[/color][/b][b][color=red])[/color][/b][b][color=red])[/color][/b][b][color=red])[/color][/b][b][color=red])[/color][/b][b][color=red])[/color][/b]
 [b][color=red]([/color][/b][b][color=blue]princ[/color][/b][b][color=red])[/color][/b][b][color=red])[/color][/b]
Hi,
above routine is really great but it doesn't delete blocks in multiple layouts.
Thanks,
Ashish
Replace the following code and it should delete all:
OLD
     (mapcar 'entdel
       (vl-remove-if 'listp
         (mapcar 'cadr (ssnamex ss))))))
NEW
(mapcar    'vla-delete
   (mapcar 'vlax-ename->vla-object (vl-remove-if 'listp (mapcar 'cadr (ssnamex ss))))
OLD
     (mapcar 'entdel
NEW
(mapcar    'vla-delete
Hi
There is faster using
(vla-erase (vla-get-activeselectionset (vla-get-activedocument (vlax-get-acad-object))))
instead of 5 loops proposed
Thanks Ronjon & Patrick,
Now this works perfectly.
Only need to add 2 brackets )) at the end of function.
Thanks for your efforts. :)
is it possible to add count result at the end something like-
"XX blocks with name "blockname" deleted"?
Hi
(vla-get-count (vla-get-activeselectionset (vla-get-activedocument (vlax-get-acad-object))))
Hi
Hi Patrick,
I added this before (princ)), gives follow. error
Command: delblk
Specify Block Name : rev.
Drawing Contains 81 Blocks with Name: rev.
Delete [A]ll or election? :
; error: Automation Error. Calling method AddItems of interface
IAcadSelectionSet failed
Pls advice.
You can put your lisp online.
(defun c: DELBLK (/ bdef blk ss tmp uss)
 (vl-load-com)
 (or *fil:del* (setq *fil:del* "All"))
 (setq bdef (getvar "INSNAME"))
 (while
     (setq blk
       (getstring t
         (strcat "\nSpecify Block Name <" bdef ">: ")))
     (cond ((eq "" blk) (setq blk bdef) nil)
           ((not (snvalid blk))
            (princ "\n** Invalid Block Name **"))
           ((not (tblsearch "BLOCK" blk))
            (princ "\n** Block Not Found in Drawing **"))
           (t nil)))) ; Exit Loop
 (if (setq ss (ssget "_X" (list (cons 0 "INSERT")
                                (cons 2 blk))))
     (princ (strcat "\nDrawing Contains "
                    (rtos (sslength ss) 2 0) " Blocks with Name: " blk))
     (initget "All Selection")
     (or (not (setq tmp
                (getkword
                  (strcat "\nDelete [A]ll or [s]election? <" *fil:del* "> : "))))
         (setq *fil:del* tmp))
     (cond ((eq *fil:del* "Selection")
            (while (not uss)
              (setq uss (ssget (list (cons 0 "INSERT")
                                     (cons 2 blk)))))
            (setq ss uss)))
(mapcar    'vla-delete
 (princ))
Edited by SLW210
(defun c:DELBLK (/ bdef blk ss tmp uss [color=Blue][b]sel doc[/b][/color])
(vl-load-com)
[b][color=Blue](setq doc (vla-get-activedocument (vlax-get-acad-object)))
(vla-startundomark doc)[/color][/b]
(while
(setq blk
(getstring t
(cons 2 blk))))
(or (not (setq tmp
(getkword
(while (not uss)
(cons 2 blk)))))
(setq ss uss)))
[b][color=Red];(mapcar 'vla-delete
;(mapcar 'vlax-ename->vla-object (vl-remove-if 'listp (mapcar 'cadr (ssnamex ss))))
;(vla-get-count (vla-get-activeselectionset (vla-get-activedocument (vlax-get-acad-object))))[/color][/b]
[b][color=Blue](princ (strcat "\n" (itoa (vla-get-count (setq sel (vla-get-activeselectionset doc)))) " objects deleted."))
(vla-erase sel)
(vla-delete sel)[/color][/b]
[b][color=Blue](vla-endundomark doc)[/color][/b]
(princ))
Thanks Patrick,
This works but with some error again,
Command: DELBLK
Specify Block Name : REV.
Drawing Contains 34 Blocks with Name: REV.
34 objects deleted.; error: Automation Error. Invalid entity name
I try it and it's work
Commande: delblk
Specify Block Name : e188
Drawing Contains 42 Blocks with Name: e188
42 objects deleted.
Commande:
