Page 1 of 2 1 2 LastLast
Results 1 to 10 of 19
    Full Member
    AutoCAD 2008
    Aug 2008
    57
    Default Font file is not on the list
    When I used Style command and try to find font called OUTLINE but I didn't see that name on the list. I put that font file at the location in Support File Search Path. Anyone knows how to solve this problem? Thank you in advance.
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,838
    As a test I copied Simplex.shx and renamed it TestFont.shx then placed it in C:\Program Files\AutoCAD 2009\Fonts. I opened AutoCAD, typed in Style at the command line. This brought up the Text Style dialog box. I checked under Font Name, found the file and set it as Current. Not sure what you might be doing differently.
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,838
    Just a note. I also tested a fake font style. I opened Notepad, wrote two lines of nonsense and saved it as BogusText.shx. I followed the same steps as mentioned above. Guess what? AutoCAD apparently did not recognize it as a legitimate shx file and refused to list it.
    Full Member
    AutoCAD 2008
    Aug 2008
    57
    this problem on one computer. I tried everything and that computer still have the same problem. I even had AutoCAD reinstalled, but the problem never goes away.
  5. #5
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,838
    Have you verified the path? Are your font files stored on a network drive?
  6. #6
    Full Member
    AutoCAD 2008
    Aug 2008
    57
    Yes I have and the font files stored on a network drive. I tried your theory (copy and rename) it doesn't work for me. I will restart the computer to see if it will work or not.
  7. #7
    Super Member
    AutoCAD pre 2000
    Nov 2008
    577
    I have had similar problems with SHX type text.
    But, Iffn' you go back some in the M-S handbook it mentions to limit file names to EIGHT characters, not NINE as you have noted. Shorten up the file type name and see if it can't then be found.
    Yes, you can use long honking titles to files, but that don't mean Acad will find them either.
    Wm.
  8. #8
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,838
    Coos:
    I don't think that applies any longer. A search of the Fonts folder for 2009 lists these two files: AMDTsymbols.shx and @extfont2.shx. Both exceed the eight characters you mention. I also encountered non-AutoCAD fonts with names longer than eight characters.
  9. #9
    Full Member
    AutoCAD 2008
    Aug 2008
    57
    I tried on my computer I have no problem. Just like I said before, only that one computer. I don't know how to fix it anymore. I reinstalled AutoCAD, but it didn't solve the problem. I know the fonts file is in the search path, in document/setting support, and also in Program files/AutoCad 2008. Where else should I put that font? Should I give up?
  10. #10
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,838
    One computer can't find the file either on the network or on the hard drive? That's just weird. If the problem were confined to the network then I would say it is an error in the path statement. But the path to the hard drive is usually established by AutoCAD when the program is installed. It is pretty much a standard location.
    I'm stumped. You've put the file in all the correct "normal" locations. Short of placing the file in the working directory of the drawings themselves I cannot think of another folder that would make any sense.
    How is this computer different from all the others used in the office for CAD besides this one quirk? It's like it has a mental block when it comes to seeing this font file.
  1. Changing the font File
    By Olhado_ in forum AutoLISP, Visual LISP & DCL
    Last Post: 23rd Apr 2009, 03:29 pm
  2. Text Font File
    By happyunited in forum AutoCAD Drawing Management & Output
    Last Post: 12th Nov 2007, 01:41 pm
  3. Pen asignment & Font style file
    By remirates in forum AutoCAD Drawing Management & Output
    Last Post: 21st Jul 2005, 06:19 am
  4. Font file CVSPRO.SHX
    By JimWebster in forum AutoCAD Drawing Management & Output
    Last Post: 10th Mar 2005, 08:16 pm
  5. font list
    By megapod in forum AutoCAD Beginners' Area
    Last Post: 24th Feb 2005, 09:41 pm
