Page 1 of 4 1 2 3 ... LastLast
Results 1 to 10 of 38
    Senior Member Fire Alarm's Avatar
    Fire Alarm's Computer Details
    Windows Vista
    Dell XPS XPS710
    MEP 2008
    May 2008
    Wilmington, DE
    111
    Default Lines Auto Dimensioning
    I have looked for a lisp routine or command, for having the lines that I draw automatically show their lenght. I do not know how lisp routines work. I am currently studying them, but cannot figure out how to create one. Any help would be greatly appreciated. It would help me save time when I try to figure out voltage drop calculations for my notification circuits.
    Thanks
    Super Moderator Tiger's Avatar
    Tiger's Computer Details
    Windows 7 Enterprise 64 bit
    Dell Precision M4500
    Intel Core i5 2.40GHz
    8GB
    NVIDIA Quadro FX 880M
    280 GB
    2 x Samsung SyncMaster 2443 24''
    AutoCAD 2012
    Nov 2006
    Sthlm, Sweden
    4,595
    Do you mean get an proper dimension as soon as you have completed the line? That would be tricky, but probably not impossible.
    If you mean see the lenght of the line while you are drawing it, you can turn on Dynamic Input (click the DYN button at the bottom of the screen) - right-click on the DYN-button to get to Settings for it and set it up as you want it.
    Life doesn't suck, although we all go through periods when it may be easier to think that, than to discern the solution to whatever problem is the most formidable
    at the moment in one's personal UCS.
    Go to PLAN view instead. - Dadgad
    Windows Vista
    Dell XPS XPS710
    MEP 2008
    May 2008
    Wilmington, DE
    111
    What I usually do is draw a pline from device to device and then select the line and go to properties to see the length. I would like to see the lenght of the line once it is drawn. Not while I am drawing it.
    8GB
    280 GB
    AutoCAD 2012
    Nov 2006
    Sthlm, Sweden
    4,595
    Aha. I'll move your thread to the Lisp forum and hope someone there can help you
  5. #5
    Full Member
    Civil 3D 2008
    May 2009
    79
    You want to figure it alone? a few tips if yes, you can take 2 points, do the pline command and then, add this
    Code:
    (command "dist" p1 p2);if p1 and p2 is the points.
    (setq di (getvar "Distance"))
    This will show the distance from points.
  6. #6
    Senior Member
    JohnM's Computer Details
    xp pro
    AutoCAD 2006
    Feb 2009
    houston, texas
    380
    when you draw you line is it a line or pline?
    is it always straight or is the curves involved?
    is it from point a to point b or many points?
    do you want a autocad dimension or just a text with the length?
  7. #7
    Windows Vista
    Dell XPS XPS710
    MEP 2008
    May 2008
    Wilmington, DE
    111
    JohnM
    1) They are plines
    2 & 3) there are 90 deg turns (I try not to go point to point so I have a distance safety factor)
    4) just show text length is fine
    BlackAlnet
    Don't know enough to do alone.
    Thanks
  8. #8
    Super Member chelsea1307's Avatar
    chelsea1307's Computer Details
    windows xp
    AutoCAD 2011
    Sep 2008
    Sacramento, Ca USA
    1,109
    lee mac wrote me a lisp a while back that after the plines are drawn you start the lisp and select your pline and the text is placed next to it, would that get you closer to what you want?
    "The problem is stupidity. I am not saying there should be capital punishment for stupidity, but, why don't we just take the safety labels off of everything and let the problem solve itself? "
  9. #9
    Lee Mac's Computer Details
    Windows 7 Ultimate (32-bit)
    Multi-disciplinary
    Lee Mac's Discipline Details
    Multi-disciplinary
    AutoCAD 2013
    Aug 2008
    London, England
    15,707
    Something like this?
    Code:
    (defun c:leng (/ ent Obj)
      (vl-load-com)
      (while
          (setq ent (car (entsel "\nSelect Object: ")))
          (cond ((eq 'ENAME (type ent))
                 (setq Obj (vlax-ename->vla-object ent))
                 (if (vlax-property-available-p Obj 'length)
                   (not (print (vla-get-length Obj)))
                   (princ "\n** Invalid Object Selected **")))
                (t (princ "\n** Nothing Selected **")))))
      (princ))
    Lee Mac Programming
    Just another Swamper
  10. #10
    Multi-disciplinary
    Multi-disciplinary
    AutoCAD 2013
    Aug 2008
    London, England
    15,707
    Quote Originally Posted by chelsea1307 View Post
    This one I believe:
    http://www.cadtutor.net/forum/showthread.php?t=36659
    Lee Mac Programming
  1. Lisp for auto-dimensioning tons of lines.
    By Zykl0 in forum AutoLISP, Visual LISP & DCL
    Last Post: 20th Apr 2012, 03:28 pm
  2. What is key TERRA FIRMA in auto cad & how we use it in auto cad
    By tariq mahmood in forum AutoCAD General
    Last Post: 9th Jan 2009, 12:39 pm
  3. Auto Dimensioning in autocad
    By Anil.S in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 20th Jun 2008, 11:02 am
  4. Auto dimensioning
    By bjasa in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 19th Jun 2008, 07:24 am
  5. Dimensioning curved lines
    By DirtylittleCAD in forum AutoCAD Beginners' Area
    Last Post: 7th Apr 2005, 01:27 pm
