I wrote this a while back - will extract from a txt file. Assumes points are comma delimited.
(defun c:ptpoly (/ doc spc file nl ptlst)
 (vl-load-com)
 (setq doc (vla-get-ActiveDocument
             (vlax-get-Acad-Object))
       spc (if (zerop (vla-get-activespace doc))
             (if (= (vla-get-mspace doc) :vlax-true)
               (vla-get-modelspace doc)
               (vla-get-paperspace doc))
             (vla-get-modelspace doc)))
 (if (setq file (getfiled "Select File" "" "txt" )
     (setq file (open file "r"))
     (while (setq nl (read-line file))
       (setq ptlst (cons (StrBrk nl 44) ptlst)))
     (close file)
     (if ptlst
         (setq ptlst
                (apply 'append
                       (mapcar
                         (function
                           (lambda (x)
                             (list (car x) (cadr x))))
                         (reverse
                           (mapcar
                             (function
                               (lambda (x)
                                 (mapcar 'distof x))) ptlst)))))
         (vla-addLightweightpolyline spc
           (vlax-make-variant
             (vlax-safearray-fill
               (vlax-make-safearray
                 vlax-vbdouble
                 (cons 0 (1- (length ptlst)))) ptlst))))
       (princ "\n<< No Points Found in File >>")))
   (princ "\n<< No File Selected >>"))
 (princ))
(defun StrBrk (str chrc / pos lst)
 (while (setq pos (vl-string-position chrc str))
   (setq lst (cons (substr str 1 pos) lst)
         str (substr str (+ pos 2))))
 (reverse (cons str lst)))
I have an Excel file can do what u want, but cant upload. I dont know why
Please send me an email
hasancad@gmail.com
I think you need to Zip Excel files, as they are not a supported file upload type. :thumbsup:
I ziped as RAR in 2 files (as forum capacity) but cant uplod
If you would I'll email to you,
Don't zip it with RAR because that is not a commonly (for free) available format. Try saving your Excel file as a CSV file, and copy ten lines or so into your post.
Can you help me??. Thanks.
Try this one, just select the diapazone with numbers only
Tested on A2008, Excel 2003
(vl-load-com)
(defun C:PX (/ acapp acsp adoc aexc cel col cols coords csht
       item nwb points poly rang result row rows sht tmp wbks)
(setq aexc (vlax-get-or-create-object "Excel.Application")
     wbks (vlax-get-property aexc "Workbooks")
     nwb  (vlax-invoke-method wbks "Open" "C:\\File excel.xls");;<--change file name here
     sht  (vlax-get-property nwb "Sheets")
     csht (vlax-get-property sht "Item" 1)
(vla-put-visible aexc :vlax-true)
(setq rang (vlax-invoke-method
     (vlax-get-property aexc "Application")
     "InputBox"
     "Select Diapazone To Get Coordinates"
     "Let you get a points"
     nil
     nil
     nil
     nil
     nil
     (vlax-make-variant 8 3))
(setq rang (vlax-variant-value rang)
(setq coords (vlax-get-property rang "Value2")
(setq rows (vlax-get-property (vlax-get-property rang "Rows") "Count")
(setq cols (vlax-get-property
     (vlax-get-property rang "Columns")
     "Count")
(setq row 1)
(repeat	rows
 (setq col 1)
 (repeat cols
   (setq cel (vlax-variant-value
	(vlax-get-property
	  (vlax-get-property rang "Cells")
	  "Item"
	  (vlax-make-variant row vlax-vbLong)
	  (vlax-make-variant col vlax-vbLong))))
   (setq item (vlax-variant-value
	 (vlax-get-property cel "Value2"))
   (setq tmp (cons item tmp)
   (setq col (1+ col)
 (setq	points (cons (reverse tmp) points)
tmp    nil
row    (1+ row)
(setq points (reverse points)
     points (apply 'append points)
(vl-catch-all-apply
 (function (lambda ()
      (vlax-invoke-method
	nwb
	"Close" :vlax-false)))
(vl-catch-all-apply
      (vlax-invoke-method
	aexc
	"Quit")))
(mapcar	(function (lambda (x)
	    (vl-catch-all-apply
			    (vlax-release-object x)
			    (setq x nil)))))))
(list rang csht nwb wbks aexc)
(setq
 adoc (vla-get-activedocument
 (setq acapp (vlax-get-acad-object))
(if (= 1 (vlax-get-property adoc "Activespace"))
 (setq acsp (vla-get-modelspace adoc))
 (setq acsp (vla-get-paperspace adoc))
(setq poly (vlax-invoke acsp "Add3DPoly" points)
(vla-eval
 acapp
 (strcat
   "ThisDrawing.SetVariable \"USERI1\","
   "MsgBox (\"Close Polyline?\","
   "vbYesNo"
   "Answer this question:"
(if (= 6 (setq result (getvar "USERI1")))
 (vlax-put-property poly "Closed" :vlax-true)
(vla-zoomextents acapp)
(gc)
(gc)
(prompt "\t\t***\t\nType PX to run program\t***")
(prin1)
~'J'~
Fixo, I could learn a lot from your code - I like the way you merge VBA and VL :thumbsup: - didn't know you could do that like that.
Lee
download this file
http://www.4shared.com/file/115732876/5917bc3/Excel2Autocad-03.html
I downloaded the file, and saved it in csv format, deleted some columns and a row, and saved it in csv format again so that it looked like this:-
0,0,0
0.05,0.002,0.05
0.1,0.01,0.1
0.148,0.022,0.15
0.196,0.04,0.2
0.242,0.062,0.25
0.287,0.089,0.3
0.329,0.12,0.35
0.368,0.156,0.4
Then I opened the text file, selected all and copied, went to AutoCAD, started the 3D polyline command, and when it wanted a startpoint, I clicked on the command line and pasted, and here is what I got (without using Lisp).
Lee
Thanks for the flowers Lee :))
I was just grabbing all these things from Excel VBA Help
and partially from my old experiences
Regards,
Oleg
~'J'~
eldon
Fill in the point coordenate in the Excel file, then select the yellow cells next to the points you entered then copy (Ctrl+C) the selected area then paste in AutoCAD command line.
eldon
I am not quite sure why you are telling me this, because I have already plotted your points as shown in the picture. I did not in fact use the yellow cells, but saved the file as a csv format, and worked from there. :)
Why did you save the file as csv?
Use the file as it is.
I used it my way, and it worked. Why should I change?
I am used to ASCII text data, and see no reason to complicate matters with further formatting.
