Does anyone know where autocad hides the block description field? I can't find it using VLISP or regular LISP?? I looked in XDATA and didn't find anything there either.. ??
thanks.
Something like this?
(defun getDesc (blk / Com)
 (cond
   ((not
      (vl-catch-all-error-p
        (vl-catch-all-apply
          (function
            (lambda ( )
              (setq com
                (vla-get-Comments
                  (vla-item
                    (vla-get-Blocks
                      (vla-get-ActiveDocument
                        (vlax-get-acad-object))) blk))))))))
    Com)
   (t nil)))
(defun c:test (/ ent)
 (if (and (setq ent (car (entsel "\nSelect Block: ")))
          (eq "INSERT" (cdadr (entget ent))))
   (if (setq Com (getDesc (cdr (assoc 2 (entget ent)))))
     (alert Com)))
 (princ))
(vl-load-com)
 (cond
   ((not
        (vl-catch-all-apply
          (function
            (lambda ( )
              (setq com
                (vla-get-Comments
                  (vla-item
                    (vla-get-Blocks
    Com)
   (t nil)))
     (alert Com)))
 (princ))
(vl-load-com)
Yes thanks. I didn't know about the vla-get-comments command, and apparently never tried finding it. ?? :)
thank you.
thank you.
No problem - I had never tried looking for Descriptions before today, so I just did a bit of experiementing and found it there :)
yeah, I could swear I had tried looking up "comment" in the apropos window.
Anyways, now the bonus question is, how do you ADD comments to a block. From what I've read, you can add comments inside the summaryinfo object, but I haven't been able to add comments to a block.... ??
Thanks, Lee. :)
This seems to work for me:
(defun PutDesc (blk Desc)
 (cond
   ((not
        (vl-catch-all-apply
          (function
            (lambda ( )
              (vla-put-Comments
                (vla-item
                  (vla-get-Blocks
                      (vlax-get-acad-object))) blk) Desc))))))
    Desc)
   (t nil)))
(defun c:test (/ ent Com)
          (setq Com (getstring t "\nSpecify Comments: ")))
   (PutDesc (cdr (assoc 2 (entget ent))) Com))
 (princ))
 (cond
   ((not
        (vl-catch-all-apply
          (function
            (lambda ( )
              (vla-put-Comments
                (vla-item
                  (vla-get-Blocks
    Desc)
   (t nil)))
 (princ))
alrighty then.. I tried a more direct approach and it didn't seem to work, but maybe I missed something. thanks!
Cool, anything else, just ask :)
  • 3 years later...
Hi Lee-Mac,
Can you enhance further this lisp so i can get the description of a Block or Layer description and use the info in Labeling/tagging?
regards,
richard
