JoeC Posted July 9, 2009 Share Posted July 9, 2009 We make plant layouts for customers with metric templates and imperial templates. I have network tool palettes created for our department, and all of the "blocks" are created in metric. When using the imperial template, the blocks scale by .0394 to assume the imperial scale. (all in model space). The last blocks I have added to the palette, however, are not scaling down. They remain very large when inserted into the imperial template. When I check the properties of the problem blocks in the palette, it is the same as the blocks that work correctly! (scale = 1, auxillary scale = none). What am I doing wrong?? Thanks for your input! Quote Link to comment Share on other sites More sharing options...
JoeC Posted July 10, 2009 Author Share Posted July 10, 2009 Well, I knew my question was odd, and I seemed to have "fixed" the issue. I copied the problem blocks into a new template, and saved it in place of the initial block. It is working correctly now. I'd still like to know why this happened! Quote Link to comment Share on other sites More sharing options...
