Trying to use COND
woodman78
Hi, I am writing program for services for our office. I have written a DCL file with radio buttons and four options which is fine. I now want to have a lisp load depending on which of the 4 radio buttons is selected. This is what I have but I would really appreciate some help. I am try to use the COND but not sure if I am calling the follows routines right. When I run the lisp I get no function definition :T.
ESS1500, ESS1350, ESS1200, ESS1050 are the functions I want to call.
(defun C:samp4 () ;define function
(vl-load-com)
(setq dcl_id (load_dialog "samp3.dcl")) ;load dialog
(setq T TB2); ?????Not sure if i need this
(if (not (new_dialog "samp3" dcl_id) ;test for dialog
);not
(exit) ;exit if no dialog
);if
(action_tile "T1" "(setq hole \"TB1\")") ;*store hole type
(action_tile "T2" "(setq hole \"TB2\")") ;*store hole type
(action_tile "T3" "(setq hole \"TB3\")") ;*store hole type
(action_tile "T4" "(setq hole \"TB4\")") ;*store hole type
(action_tile
"cancel" ;if cancel button pressed
"(done_dialog) (setq userclick nil)" ;close dialog, set flag
);action_tile
(action_tile
"accept" ;if O.K. pressed
" (done_dialog)(setq userclick T))" ;??? Is this standard code.
(cond (=(T "TB1")ESS1500)
(=(T "TB2")ESS1350)
(=(T "TB3")ESS1200)
(=(T "TB4")ESS1050)
('t
(princ "\nNothing changed.")
) ;_ end of optional else condition
) ;_ end of cond statement
);action tile
(start_dialog) ;start dialog
(unload_dialog dcl_id) ;unload
);defun C:samp
mate if you could provide the dcl file, it would make it alot easyer to work out what you are doing,
i assume you are using radio_button's
Regards flower
please excuse me if i make any mistakes, i am quite blind,
But
(=(T "TB2")ESS1350)
(=(T "TB3")ESS1200)
(=(T "TB4")ESS1050)
('t
should be
(cond (=(hole "TB1")ESS1500)
(=(hole "TB2")ESS1350)
(=(hole "TB3")ESS1200)
(=(hole "TB4")ESS1050)
('t
Hi Flower,
Here is the DCL:
samp3 : dialog { //dialog name
label = "Structural Holes" ; //give it a label
:boxed_radio_column { //*define radio column
label = "Choose a Type" ; //*give it a label
: radio_button { //*define radion button
key = "T1" ; //*give it a name
label = "Type &1" ; //*give it a label
value = "1" ; //*switch it on
} //*end definition
: radio_button { //*define radio button
key = "T2" ; //*give it a name
label = "Type &2" ; //*give it a label
} //*end definition
key = "T3" ; //*give it a name
label = "Type &3" ; //*give it a label
} //*end definition
key = "T4" ; //*give it a name
label = "Type &4" ; //*give it a label
} //*end definition
} //*end radio column
ok_cancel ; //predifined OK/Cancel
: row { //define row
: paragraph { //define paragraph
: text_part { //define text
label = "Designed by BD"; //give it some text
} //end text
: text_part { //define more text
label = "for CCC NNRDO"; //some more text
} //end text
} //end paragraph
} //end row
} //end dialog
Mate, had a look, didnt run it, should be fine in princaple
Not alot of changes really, If you want me to explane why i changed things im happy to explain
just one note
When posting code please put in the code tages it the # key in with all the format **** on the top of the reply box.
it just keeps formats and easyer on the eyes
(vl-load-com)
; (setq T TB2); ?????Not sure if i need this
;not sure what you want from this, but i belive its not needed, but i do not know your varibles
  );not
      (alert "Can not find you dcl file")
);if
(action_tile
);action_tile
(action_tile
"(done_dialog)(setq userclick T))" ;??? Is this standard code.
);action tile
(if userclick
 (cond
  (t (princ "\nNothing changed.")
);defun C:samp
(princ "\nThis loaded fine")
and dcl, it is unchanged
 } //*end definition
 } //*end definition
 } //*end definition
 } //*end definition
  } //end text
  } //end text
 } //end paragraph
} //end row
} //end dialog
sorry my pasting format turns out quite **** for some reason.
Thanks for that Flower,
It has gotten rid of the errors but it still doesn't run any of the ESS routines. I have them in the same .lsp file. Do i need to call them in a different way or something.
I ran one of the ESS routines from the command line and it runs fine.
I would appreciate any ideas..
Do you have them set as functions in the same file?
If so, you could do this:
(cond (=(hole "TB1") (C:ESS1500))
(=(hole "TB2") (C:ESS1350))
(=(hole "TB3") (C:ESS1200))
(=(hole "TB4") (C:ESS1050))
('t
Since you said that you can run the routines from the command line you could also simply do this:
(cond (=(hole "TB1") (command "ESS1500"))
(=(hole "TB2") (command "ESS1350")
(=(hole "TB3") (command "ESS1200"))
(=(hole "TB4") (command "ESS1050"))
('t
Sorry mate i missed that lastnight
(cond
  (=(hole "TB1")(ESS1500))
  (=(hole "TB2")(ESS1350))
  (=(hole "TB3")(ESS1200))
  (=(hole "TB4")(ESS1050))
  (t (princ "\nNothing changed.")) ;_ end of optional else condition
Aswell
Do you call the routenes up from the command line all the time?
Or just for the testing faze.As i would ride the "c:" part.
then the above should work
(defun ESS1350 ()
"the code here"
Or do as PHPGator
('t
Thanks guys, Just into the office now and tried your solution but no joy. I am getting an error ; error: bad function: "TB3" depending on which radio button I choose. Any ideas, this is the full code. Thanks again.
(vl-load-com)
  );not
);if
(action_tile
);action_tile
(action_tile
);action tile
(if userclick
 (cond
  (=(hole "TB2")  (command "ESS1350"))
);defun C:samp
(defun c:ESS1500()
(setq a "CCC_DR_1500")
 (if (= (tblsearch "ltype" a) nil)
      (command "-linetype" "l" a "acadiso.lin" "")
            (princ))
(graphscr)
(command "._-layer"   "N"   "CCC_SERVICES_EXISTING_Drainage_Storm_Sewer_1500"   "M"   "CCC_SERVICES_EXISTING_Drainage_Storm_Sewer_1500"   "L"
"CCC_DR_1500"  "CCC_SERVICES_EXISTING_Drainage_Storm_Sewer_1500"   "C"   "84"   "CCC_SERVICES_EXISTING_Drainage_Storm_Sewer_1500"   "LW"
"0.3"   "CCC_SERVICES_EXISTING_Drainage_Storm_Sewer_1500"    "" )
(command "pline" pause "width" "0.0" "0.0" pause "width" "0.0" "0.0")
(setvar "cmdecho" 1)
;;;;;;;;;;Existing Storm_Sewer 1500mm;;;;;;;;;; End
;;;;;;;;;;Existing Storm_Sewer 1350mm;;;;;;;;;; Start
(defun c:ESS1350()
(setq a "CCC_DR_1350")
            (princ))
(graphscr)
(command "._-layer"   "N"   "CCC_SERVICES_EXISTING_Drainage_Storm_Sewer_1350"   "M"   "CCC_SERVICES_EXISTING_Drainage_Storm_Sewer_1350"   "L"
"CCC_DR_1350"  "CCC_SERVICES_EXISTING_Drainage_Storm_Sewer_1350"   "C"   "84"   "CCC_SERVICES_EXISTING_Drainage_Storm_Sewer_1350"   "LW"
"0.3"   "CCC_SERVICES_EXISTING_Drainage_Storm_Sewer_1350"    "" )
;;;;;;;;;;Existing Storm_Sewer 1350mm;;;;;;;;;; End
;;;;;;;;;;Existing Storm_Sewer 1200mm;;;;;;;;;; Start
(defun c:ESS1200()
(setq a "CCC_DR_1200")
            (princ))
(graphscr)
(command "._-layer"   "N"   "CCC_SERVICES_EXISTING_Drainage_Storm_Sewer_1200"   "M"   "CCC_SERVICES_EXISTING_Drainage_Storm_Sewer_1200"   "L"
"CCC_DR_1200"  "CCC_SERVICES_EXISTING_Drainage_Storm_Sewer_1200"   "C"   "84"   "CCC_SERVICES_EXISTING_Drainage_Storm_Sewer_1200"   "LW"
"0.3"   "CCC_SERVICES_EXISTING_Drainage_Storm_Sewer_1200"    "" )
(command "pline" pause "width" "0.0" "0.0")
;;;;;;;;;;Existing Storm_Sewer 1200mm;;;;;;;;;; End
;;;;;;;;;;Existing Storm_Sewer 1050mm;;;;;;;;;; Start
(defun c:ESS1050()
(setq a "CCC_DR_1050")
            (princ))
(graphscr)
(command "._-layer"   "N"   "CCC_SERVICES_EXISTING_Drainage_Storm_Sewer_1050"   "M"   "CCC_SERVICES_EXISTING_Drainage_Storm_Sewer_1050"   "L"
"CCC_DR_1050"  "CCC_SERVICES_EXISTING_Drainage_Storm_Sewer_1050"   "C"   "84"   "CCC_SERVICES_EXISTING_Drainage_Storm_Sewer_1050"   "LW"
"0.3"   "CCC_SERVICES_EXISTING_Drainage_Storm_Sewer_1050"    "" )
;;;;;;;;;;Existing Storm_Sewer 1050mm;;;;;;;;;; End
Sorry mate, Didnt pick up, was drunk or hung ova
try with
(cond
  (= hole "TB1")  (command "ESS1500"))
  (= hole "TB2")  (command "ESS1350"))
  (= hole "TB3")  (command "ESS1200"))
  (= hole "TB4")  (command "ESS1050"))
Please note that if you dont pick any thing, it will return nothing change.
But, defult for radio buttons is to have one enabbled, Either go with toggle buttons , and extra option as "none" or some thing , or not have that option
Does this mean I can't use the radio buttons at all?? I can get the dialog box to load with none pre-selected. After I load and run the lsp i am still getting the BAD Function error when i select one of the buttons. None of the ESS commands will run but they will run when typed into the command line directly just as a test. I must be missing something here!
Bro like i said before
(cond
  (= hole "TB1")  (ESS1500))
  (= hole "TB2")  (ESS1350))
  (= hole "TB3")  (ESS1200))
  (= hole "TB4")  (ESS1050))
with the other ones as. this formatt should work
(defun ESS1350 ()
"the code here"
or purhaps some thing like this
(defun C:samp4 (/ hole)
(vl-load-com)
(setvar "cmdecho" 0)
(defun MkLay (Nme Col lTyp lWgt Plt / lays lay) ;thank lee for this one
 (setq lays
  (vla-get-layers
   (vla-get-ActiveDocument
    (vlax-get-acad-object)
 lay
  (cond
   ((tblsearch "LAYER" Nme)
    (vla-item lays Nme)
   (t (vla-add lays Nme))
 (and Col (vla-put-Color lay Col))
 (and lTyp (lTload lTyp) (vla-put-Linetype lay lTyp))
 (and lWgt  (vla-put-LineWeight lay (eval (read (strcat "acLnWt" lWgt)))))
 (and (not Plt) (vla-put-Plottable lay :vlax-false))
(defun lTload (lTyp)
 (or (tblsearch "LTYPE" lTyp)
  (vla-load
   (vla-get-Linetypes
   lTyp "acad.lin"
(defun drawingstuff(a layername /)
 (if (not(tblsearch "layer" layername))
  (MkLay layername 84 a 030 nil)
 (setvar "clayer" layername)
 (command "pline" '(0 0 0) "width" "0.0" "0.0" //)
 (command "pline")
(if (not (new_dialog "samp3" dcl_id) )
    (exit)
(action_tile "T1" "(setq hole \"TB1\")(set_tile \"T2\" \"0\")(set_tile \"T3\" \"0\")(set_tile \"T4\" \"0\")(if (= (get_tile \"T1\") \"0\")(setq hole nil)))")
(action_tile "T2" "(setq hole \"TB2\")(set_tile \"T1\" \"0\")(set_tile \"T3\" \"0\")(set_tile \"T4\" \"0\")(if (= (get_tile \"T2\") \"0\")(setq hole nil)))")
(action_tile "T3" "(setq hole \"TB3\")(set_tile \"T1\" \"0\")(set_tile \"T2\" \"0\")(set_tile \"T4\" \"0\")(if (= (get_tile \"T3\") \"0\")(setq hole nil)))")
(action_tile "T4" "(setq hole \"TB4\")(set_tile \"T1\" \"0\")(set_tile \"T2\" \"0\")(set_tile \"T3\" \"0\")(if (= (get_tile \"T4\") \"0\")(setq hole nil)))")
(action_tile "cancel" "(done_dialog)(setq userclick nil)")
(action_tile "accept" "(done_dialog)(setq userclick T))")
(start_dialog)
(if userclick
 (cond
  ((= hole "TB1") (drawingstuff "CCC_DR_1500""CCC_SERVICES_EXISTING_Drainage_Storm_Sewer_1500"))
  ((= hole "TB2") (drawingstuff "CCC_DR_1350" "CCC_SERVICES_EXISTING_Drainage_Storm_Sewer_1350"))
  ((= hole "TB3") (drawingstuff "CCC_DR_1200" "CCC_SERVICES_EXISTING_Drainage_Storm_Sewer_1200"))
  ((= hole "TB4") (drawingstuff "CCC_DR_1050" "CCC_SERVICES_EXISTING_Drainage_Storm_Sewer_1050"))
woops
here's the dcl aswell
 :toggle {key = "T1" ; label = "Type &1"; }
 :toggle {key = "T2" ; label = "Type &2"; }
 :toggle {key = "T3" ; label = "Type &3"; }
 :toggle {key = "T4" ; label = "Type &4"; }
  : text_part {
  } //end text
  } //end text
 } //end paragraph
} //end row
} //end dialog
That did the job alright. Thanks for that. Was there a fundamental problem with what i did or is it just that the visual lisp is better coding??
Thanks
If you hadnt the need for the option of nothing, you would of almost been on the mark.
Except with the cond
That wasnt quite correct, not far off tho.
All i did was change it to a toggle, that accepts nil.
Used a different way to create a layer
Used a different way to load the linetype.
And I simplfied the multiple commands into one.
with a cond to pass the values on to it.
Thanks for that but the problem is that I don't understand what is going on there. I can't follow the code in order to modify it for other routines I want to run. I understand the one I have but not why it won't load the other ESS routines.
Mate hope this helps
let me know if note, here are some notes
(vl-load-com)
;this creates the layer, Give it, name , colour , lintype. lineweight eg 030 and plot (t or nil)
 (setq lays
  (vla-get-layers
 lay
  (cond
    (vla-item lays Nme)
;this just searchs for line type, adds it if needed
  (vla-load
   (vla-get-Linetypes
   lTyp "acad.lin"
;this is your draw function
;because your codes where all the similar except layer & linetype
;This searchs for layer
;this changes the layer
;this sets up the width then exits it
;returns cmdecho back, so it has promps for commands
;runs pline & lets user do what they want with it
(command "pline")
;loadinc dcl
    (exit)
;will set the the flag to respected vale, and will set all the tiles to bank
;because there toggle boxes, they can be on all at once, so it stops it,
;it will the cheack if current tile is nil or not
;if it is set the flag nil
(start_dialog)
;if accepted
;search which flag is done, will the pass the line type value and layer  name to the funtion
(if userclick
 (cond
