Lisp for adding number to multiple text entities?
EvilSi
Hello,
This might be a little tricky, but does anybody know of a lisp routine that can add a certain number to multiple dtext/mtext entities?
For example, I have a topographical survey in dwg format, I do not have the original survey data. I need to adjust the levels to a new datum. I therefore need to add 9.123 to all of the text values.
I would be very grateful for any assistance - I'm always telling all my CAD friends how great this site iso:)
Thanks!
(I am currently using vanilla ACAD 2006)
  • Replies 30
  • gilsoto13
    7
  • Lee Mac
    6
  • Commandobill
    4
  • EvilSi
    3
Posted Images
Ah sorry, I mean I have a set of numbers, say 6.000, 5.900 etc. and I want to add say 1.500 to each and every one of them, so in this instance I would be left with 7.500 and 7.400.
I want a lisp that edits the number by adding x amount to it.
like this?
(defun c:addn ( / ss)
 (vl-load-com)
 (if (and (setq ss (ssget "X" (list (cons 0 "*text"))))
      (setq amt (getreal "\nPlease type the amount you would like to add: ")))
     (mapcar '(lambda (z) (vla-put-textstring z (rtos (+ (atof (vla-get-textstring z)) amt) 2 3)))
         (mapcar 'vlax-ename->vla-object (vl-remove-if 'listp (mapcar 'cadr (ssnamex ss)))))
Bill, just a tip, you don't need the:
(vl-remove-if 'listp ..
When using
(ssget "_X")
:thumbsup:
Yeah i know. I didnt know if he was going to select them or have it automated so i threw that in there for good measure. Thanks though :D
  • 8 months later...
Hey, Lee... I tried to modify another lisp to increment text and mtext with a specific value... but I get the same error in this one and in the one I modified...
when I select Mtext with text strings (not just numbers) the specified increment replaces the whole mtext, so I does not work as one would wish... to increment the numerical text with the specified value... would that be possible?
;;http://www.autolisp.com/forum/showthread.php?t=347
(defun c:sum ()
(setq meu-ss(ssget '((0 . "TEXT,MTEXT"))))
 (setq value (getdist "\nValue to sum to numbers: "))
(setq cntr 0)
(while (< cntr (sslength meu-ss))
(setq en(ssname meu-ss cntr))
(setq enlist(entget en))
(setq s-tex(cdr(assoc 1 enlist)))
(setq n-tex(atof s-tex))
(setq nf-tex (+ value n-tex))
(setq nft-tex(rtos nf-tex 2 2))
(setq enlist(subst (cons 1 nft-tex)(assoc 1 enlist) enlist))
(entmod enlist)
(setq cntr(+ cntr 1))
and by the way... I have been taking small steps with selection sets.. but at this moment I can say I am only taking other existing codes to do a little more things with commands and selections.... I made something else today...
I converted a routine to Insert points at center of each selected circles.. into a routine to insert a block at every selected circle... and then into a routine to select polylines, lwpolylines and circles and do wipeouts with them... .. no error handlers nor any of that stuff.. but It works.
;BINCIRCLE.lsp 01/01/97 Jeff Foster
;OBJECTIVE***
;The purpose of this routine is to allow the user to enter
;a text item and place that same text in the center of a selection
;of circles
;TO RUN***
;At the command line, type (load "c:/lispdir/txtncirc")
;where c:/ is the drive where TXTNCIRC.lsp is contained
;where lispdir/ is the directory where TXTNCIRC.lsp is contained
;If you find this routine to be helpful, please give consideration
;to making a cash contribution of $10.00 to:
;         Jeff Foster
(DEFUN C:BINCIRCLE (/ SS EN ED AS)
 (SETQ DM (GETVAR "DIMSCALE"))
 (PRINC "SELECT CIRCLES TO PUT TEXT INTO")
 (SETQ SS (SSGET))
 (WHILE (> (SSLENGTH SS) 0)
   (PROGN
   (SETQ EN (SSNAME SS 0))
   (SETQ ED (ENTGET EN))
   (SETQ AS (CDR (ASSOC '0 ED)))
   (SETQ START (CDR (ASSOC '10 ED)))
   (IF (= AS "CIRCLE")
   (COMMAND "INSERT" "COLUMN ROW BUBBLE" START DM DM "0" "")
   (PRIN1)
   (SSDEL EN SS)
 (PRIN1)
;; C2W3.lsp BY Paulo Gil Soto - March 2010
;; draws a wipeout made of a polygon of 40 sides over each selected circle.
;; and will replace selected closed polylines and lwpolylines with a wipeout
;; Selected circles are deleted
;; Most of the code taken from  Jeff Foster --01/01/97
(DEFUN C:C2W3 (/ SS EN ED AS)
(COMMAND "undo" "begin")  ;beginning of undo group
 (AND (SETQ ss (SSGET "_:L" '((0 . "CIRCLE,*POLYLINE"))))
      (FOREACH x (VL-REMOVE-IF 'LISTP (MAPCAR 'CADR (SSNAMEX ss)))
 (COND
   ((EQ "CIRCLE" (CDR (ASSOC 0 (SETQ elist (ENTGET x)))))
   (PROGN
   (SETQ RAD (CDR (ASSOC '40 ED)))
   (IF (= AS "CIRCLE")
   (COMMAND "POLYGON" "40" START "I" RAD "WIPEOUT" "P" "L" "Y" "ERASE" EN "")
   (IF (= AS "LWPOLYLINE")
   (COMMAND "WIPEOUT" "P" EN "Y")
   (IF (= AS "POLYLINE")
   (PRIN1)
   (SSDEL EN SS)
         (ENTMOD elist)
   (T T)
 ) ;_ cond
      ) ;_ foreach
 ) ;_ and
 (COMMAND "undo" "end")  ;end of undo group
) ;_ defun
;|«Visual LISP© Format Options»
(80 2 40 2 nil "end of " 60 9 2 0 0 T T T T)
;*** DO NOT add text below the comment! ***|;
Hello everybody,
If i have a block with an attribute, ... B1, is it possible to add a number to this attribute, to be B2? Thanks!
Yours It's a great routine..
Nevertheless, I got a question. After using it, it rounds to 1 decimal... how can I change it to 3 decimals for resulting mtexts?
For 3 d.p
(defun c:Text_Inc (/ *error* ParseNumbers uFlag ss)
 (vl-load-com)
 ;; Lee Mac  ~  10.03.10
 (defun *error* (msg)
   (setvar 'NOMUTT 0)
   (and uFlag (vla-EndUndoMark *doc))
       (princ (strcat "\n** Error: " msg " **")))
   (princ))
 (defun ParseNumbers (str / lst Num Aph x rtn)
   ;; Lee Mac  ~  20.09.09
   (setq lst (vl-string->list str) Num "" Aph "")
   (while (setq x (car lst))
     (setq lst (cdr lst))
     (cond (  (and (/= "" Num) (= 46 x))
              (setq Num (strcat Num (chr x))))
           (  (< 47 x 58)
                    rtn (cons Aph rtn) Aph ""))
           (t (setq Aph (strcat Aph (chr x))
                    rtn (cons (read Num) rtn) Num ""))))
   (vl-remove nil
     (vl-remove "" (reverse (cons Aph (cons (read Num) rtn))))))
 (setq *inc* (cond (*inc*) (1.0)))
 (setq *inc* (cond ((getreal (strcat "\nSpecify Increment <"
                                     (vl-princ-to-string *inc*) "> : ")))
                   (*inc*)))
 (setq *doc (cond (*doc) ((vla-get-ActiveDocument (vlax-get-acad-object)))))
 (setvar 'NOMUTT 1)
 (princ "\nSelect Text to Increment <All> : ")
 (if (or (ssget "_:L" '((0 . "MTEXT,TEXT")))
         (ssget "_X"  '((0 . "MTEXT,TEXT"))))
     (setq uFlag (not (vla-StartUndoMark *doc)))
     (vlax-for obj (setq ss (vla-get-ActiveSelectionSet *doc))
       (vla-put-TextString obj
         (apply (function strcat)
                (mapcar
                  (function
                    (lambda (x) (if (vl-position (type x) '(INT REAL))
                                  (rtos (+ x *inc*) (getvar 'LUNITS) 3) x)))
                  (ParseNumbers (vla-get-TextString obj))))))
     (vla-delete ss)
     (setq uFlag (vla-EndUndoMark *doc))))
 (setvar 'NOMUTT 0)
 (princ))
For 3 d.p
 (vl-load-com)
   (setvar 'NOMUTT 0)
   (princ))
           (  (< 47 x 58)
   (vl-remove nil
                   (*inc*)))
 (setvar 'NOMUTT 1)
                (mapcar
                  (function
     (vla-delete ss)
 (setvar 'NOMUTT 0)
 (princ))
I think the routine should store the NOMUTT variable and reset it to its original value instead of change it to 0 when using the routine..
But anyway the decimal places thing didn´t work.. I made some research... but I can´t find the answer yet...
I am not using CAB's routine cause that's for a different purpose... but yours is what I was looking for...
also the routine in the thread I mentioned didn´t work after modifying it... so your routine is the only one that works for the case i am running here... but would be perfect If I could get the 3 decimal places...
attached a sample dwg to test if necessary.
A SAMPLE.dwg
With NOMUTT, I don't think there is any harm in setting it to 0, I doubt any user has it always set to 1.
All works for me, its only in the rtos conversion.
wEell... I was updating my help files and found I already had this one from years ago.... and actually works as I expect for numbers and text as objects... I just didn´t remember....
; Increments the first postive number in a TEXT string by the given increment
;;;  Program: INC.LSP  ver 1.22
;;;  Purpose: Increments the first postive number in a TEXT string by the given increment
;;;  Syntax:  INC
;;;           Resolutions
;;;           P.O. Box 1265
;;;           Sumner WA 98390-0250
;;;           206-845-2200
;;;  Date:             5/10/95
;;;  Revisions:  ver 1.1  8/7/95    Added support for REALs
;;;  Revisions:  ver 1.2  12/12/95  Added support for Stations
;;;  Revisions:  ver 1.21 12/14/95  Fixed problem with decimal places
;;;  Revisions:  ver 1.22 1/16/96   Fixed problem with decimal places when
;;;                                 number is preceeded by alpha characters.
(defun C:INC (/ ; Functions & Variables
   ; Functions
           val put r_fill getdp at
   ; Variables
           ss inc i l e j k ascii_nr string newstring nr count dp1 dp
           OldStation dp_pos end_pos
; Entity assoc list utilities
(defun val (nr e) (cdr (assoc nr e)))
(defun put (x nr e)(subst (cons nr x) (assoc nr e) e))
;;; Function: AT
;;; Purpose : Returns the position of the first occurance of a string
;;;           or NIL if not found
;;; Params  : string        String to search
;;;               char            String to locate
;;; Uses    :
   (defun at (string char / i len clen)
       (if string
               (setq i 1 len (strlen string) clen (strlen char))
               (while (and (<= i len) (/= (substr string i clen) char))
                   (setq i (1+ i))
               (if (> i len)
                   (setq i nil)
               (eval i)
;;; Function: R_FILL <string> <len>
;;; Purpose : Returns a string filled with spaces on the right
;;; Params  : string        String to fill
;;;           len             String length
(defun r_fill (s len / space i)
  (setq space "" i (- len (strlen s)))
  (if (> i 0)
      (substr (strcat s (repeat i (setq space (strcat space " ")))) 1 len)
      s
;; Return number of decimal places of a REAL
(defun getdp (nr / n)
   (setq n 0 nr (abs nr))
   (while (null (equal (fix (+ nr 0.5)) nr 0.000001))
       (setq n (1+ n))
       (setq nr (* nr 10))
   n
   ;-- Start C:TEXTINC
   (setvar "CMDECHO" 0)
   (princ "\nSelect TEXT containing NUMBERS to increment.")
   (if (and
           (setq ss (ssget '((0 . "*TEXT"))))
           (setq inc (getreal "\nIncrement: "))
           (/= inc 0)
           (setq i 0 l (sslength ss) count 0)
           (while (< i l)
               (setq e (entget (ssname ss i)))
               (setq string (val 1 e))
               ;; --- Check for an number ---
               (if (and
                       (wcmatch string "*[0-9]*")       ; Find an INT
;                        (wcmatch string "~*#.#*")        ; No REALs
                       (wcmatch string "~*%%d*")        ; No BEARINGS
                       (setq count (1+ count))
                       (setq j 1 k (strlen string))
                       (if (wcmatch string "*#+##*")  ; Check for Station
                           (setq
                               OldStation string
                               j (at string "+")
                               string (strcat
                                       (substr string 1 (1- j))
                                       (substr string (1+ j))
                               j 1
                               k (strlen string)
                       ;; --- Step though the string looking
                       ;; --- for the first int ---
                       (while (<= j k)
                           (setq ascii_nr (ascii (substr string j 1)))
                           (if (and (>= ascii_nr 48)(<= ascii_nr 57))
                                   (setq end_pos j)
                                   (while (or (= ascii_nr 46)(and (>= ascii_nr 48)(<= ascii_nr 57)))
                                       (setq
                                           end_pos (1+ end_pos)
                                           ascii_nr (ascii (substr string end_pos 1))
                                   (setq
                                       dp_pos (at (substr string j) ".")
                                       nr    (atof (substr string j))
                                       dp1 (if dp_pos (- end_pos dp_pos j) 0)
                                       dp (max dp1 (getdp inc))
                                       nr (+ nr inc)
                                       newstring (strcat
                                           (rtos nr 2 dp)
                                           (substr string end_pos)
                                       j k     ;; Now exit
                           (setq j (1+ j))
                       ;; If station then insert the "+"
                       (if OldStation
                               (setq string Oldstation)
                               (if (setq j (at newstring "."))
                                   (setq j (- j 3))
                                   (setq j (- (strlen newstring) 2))
                               (setq newstring
                                   (strcat (substr newstring 1 j) "+"
                                           (substr newstring (1+ j))
                       ;; --- Echo changes to screen ---
                       (princ (strcat "\n" (r_fill string 12) "-->  " newstring))
                       ;; --- Update the TEXT entity ---
                       (entmod (put newstring 1 e))
                   (princ (strcat "\nNo Numeric value: " string))
               (setq i (1+ i))
           (princ (strcat "\n" (itoa count) " TEXT number\(s\) incremented."))
       (princ "\nTEXTINC cancelled.")
(princ "\nTEXTINC.LSP v1.22")
Does it error? What do you get?
Weird... I remember getting only 1 decimal place in the results at the office... in acad 2009, today in autocad 2008 everything was ok... so... I 'll let you know if there's something wrong tomorrow... but I don't think I'll need extra work cause the other option I found in my files... everything is ok...
It could be that you didn't reload the new LISP before testing - as I say, it was only in the number -> string conversion - it isn't a particularly complex LISP for things to go wrong. :)
