The Buzzard Posted July 20, 2009 Share Posted July 20, 2009 I am wondering if anyone could help here. I was looking thru the Developer Help Section in AutoCAD's help documentation and came across Visual Lisp Functions that start with the prefixes: vl vlax vlr However there does not seem to be many. I have also seen some functions start with (vla) that are not listed at all. This seems to be confusing to me. Where do you get all these functions from? Is there an index where they can be found? I am sure these functions are not randomly made up and should be a complete listing somewhere. Any clarification would be very helpful. Quote Link to comment Share on other sites More sharing options...
rkmcswain Posted July 20, 2009 Share Posted July 20, 2009 They are all documented in the Developers Guide (\Help\acad_dev.chm), more specifically, the "AutoCAD ActiveX and VBA Reference" Quote Link to comment Share on other sites More sharing options...
The Buzzard Posted July 20, 2009 Author Share Posted July 20, 2009 They are all documented in the Developers Guide (\Help\acad_dev.chm), more specifically, the "AutoCAD ActiveX and VBA Reference" Thank you, I will check that out. I was under the impression that it was for VBA only. Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted July 20, 2009 Share Posted July 20, 2009 The Visual LISP Editor Help files are written with VBA in mind, so you may have to make a few "links" between the two. for example: Type this in the VLIDE: vla-get-layer You will see it turn blue. Double click on it so that the whole function is selected, then click on the help button. You will see a page detailing the "layer" property, giving information on arguments and returns of this property. In the contents page of the VLIDE, have a look at the Active X and VBA Reference - there you will see a list of all the properties and methods available to you Lee Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted July 20, 2009 Share Posted July 20, 2009 McSwain, you beat me to it Quote Link to comment Share on other sites More sharing options...
The Buzzard Posted July 20, 2009 Author Share Posted July 20, 2009 The Visual LISP Editor Help files are written with VBA in mind, so you may have to make a few "links" between the two. for example: Type this in the VLIDE: vla-get-layer You will see it turn blue. Double click on it so that the whole function is selected, then click on the help button. You will see a page detailing the "layer" property, giving information on arguments and returns of this property. In the contents page of the VLIDE, have a look at the Active X and VBA Reference - there you will see a list of all the properties and methods available to you [ATTACH]13249[/ATTACH] Lee Lee, This Visual Lisp seems like a guessing game. The resources available are very confusing to know what is what. Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted July 20, 2009 Share Posted July 20, 2009 Lee, This Visual Lisp seems like a guessing game. The resources available are very confusing to know what is what. You need to experiment with it a bit I find, yes. Quote Link to comment Share on other sites More sharing options...
ollie Posted July 22, 2009 Share Posted July 22, 2009 From what I can tell vlax- = Object level vlr - = Event vla - = Methods & Properties of objects Open the vbaide with this an mind and go wild for a bit I may be wron right enough Ollie Quote Link to comment Share on other sites More sharing options...
The Buzzard Posted July 22, 2009 Author Share Posted July 22, 2009 From what I can tell vlax- = Object level vlr - = Event vla - = Methods & Properties of objects Open the vbaide with this an mind and go wild for a bit I may be wron right enough Ollie Thank You ollie, That is very helpful. Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted July 22, 2009 Share Posted July 22, 2009 vlax-curve functions are really good to look into... takes all the messiness out of DXF tables with objects. Quote Link to comment Share on other sites More sharing options...
Se7en Posted July 22, 2009 Share Posted July 22, 2009 I wrote up something on the differences once. I will have to look around for that. I cant promise anything though; that article would be 5 or 6 hard drives and several years ago. Quote Link to comment Share on other sites More sharing options...
The Buzzard Posted July 22, 2009 Author Share Posted July 22, 2009 vlax-curve functions are really good to look into... takes all the messiness out of DXF tables with objects. Thanks Lee, It is at this point a bit beyond me though. I still cannot make heads or tails out of the VBA section and how this relates to VL. It seems all trial and error to me at this point, But maybe I am trying to get to far ahead of myself. Patience I guess Quote Link to comment Share on other sites More sharing options...
The Buzzard Posted July 22, 2009 Author Share Posted July 22, 2009 I wrote up something on the differences once. I will have to look around for that. I cant promise anything though; that article would be 5 or 6 hard drives and several years ago. Thanks Se7en, I appreciate anything that can clear up some of the mystery behind VL. Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted July 22, 2009 Share Posted July 22, 2009 The Curve functions are well documented, and will also work with Entity Names, as well as VLA-Objects - definitely worth a look. just search for vlax-curve-, in the help files. EDIT: A great overview is the Section "Curve Measurement Functions" in the Developers Guide. Quote Link to comment Share on other sites More sharing options...
The Buzzard Posted July 22, 2009 Author Share Posted July 22, 2009 The Curve functions are well documented, and will also work with Entity Names, as well as VLA-Objects - definitely worth a look. just search for vlax-curve-, in the help files. EDIT: A great overview is the Section "Curve Measurement Functions" in the Developers Guide. I will give it a look, But I have had no sucess finding VL functions except for those listed in the AutoLISP Reference for AutoLisp Functions. My resouces for VL seems very limited. Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted July 22, 2009 Share Posted July 22, 2009 All the necessary functions are listed. For example, to change a property of an object, you can use: ([color=Blue][b]vlax-put-property[/b] [/color][color=Red][i]obj [/i][i]property[/i][i] arg[/i][/color]) Which is documented, and has the same functionality as: ([color=Blue][b]vla-put-[color=Red]<property>[/color][/b][/color] [color=Red][i]obj property arg[/i][/color]) As an example: [b]Obj is a Circle VLA-Object[/b] [color=Blue][b] (vla-put-layer Obj "0")[/b][/color] is the same as: [b][color=Blue] (vlax-put-property Obj 'Layer "0")[/color][/b] The same with the methods: ([color=Blue][b]vlax-invoke-method[/b][/color] [i][color=Red][i]obj [/i][i]method[/i][i] arg [arg...][/i][/color][/i]) And ([color=Blue][b]vla-[/b][/color][color=Red][b]<method>[/b][/color] [color=Red][i]Obj arg [arg...][/i][/color]) Are the same, or even just ([color=Blue][b]vlax-invoke[/b][/color][color=Red][i] Obj arg [arg...][/i][/color]) Although the above has the same functionality, it will return data in AutoLISP data types, as opposed to VLA data types such as Variants and Safearrays. If I have missed something, anyone feel free to chime in Lee Quote Link to comment Share on other sites More sharing options...
The Buzzard Posted July 22, 2009 Author Share Posted July 22, 2009 Part of what you have shown me is my point. How am I suppose to know this if I do not understand the difference between VL, VLA, VLAX & so on and so forth. I am not sure where or how each is used, But maybe I have not reach that point yet in learning this. Maybe I am learning backwards. Not sure. I have seen other prefixes used that are not shown in the help section at all. A very dry type read Im afraid. If I were to read the entire help section for VL, I would still draw blanks on these issues since I cannot find the resources that I need to help understand this stuff. Everyone has their own methods of learning. I prefer to test functions to see what they do and draw on my own conclusions. Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted July 22, 2009 Share Posted July 22, 2009 All I am saying is that there is not much that you cannot do just using the functions documented in the help files. EDIT: Forgot to mention, so see a list of functions available, use the Apropos in the VLIDE - for example: type "vl" and hit Ctrl-Shift-Space Quote Link to comment Share on other sites More sharing options...
The Buzzard Posted July 22, 2009 Author Share Posted July 22, 2009 All I am saying is that there is not much that you cannot do just using the functions documented in the help files. I realize that. But they help to get a better understanding. To learn regular lisp each function is documented and has examples for their usage with the expected type of return values you would encounter. And its nicely arranged. Visual Lisp on the other hand is like doing a cross-word puzzle with a blind fold on with the help section thats available. Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted July 22, 2009 Share Posted July 22, 2009 Also, take note of the edited post above - that apropos window is handy. Quote Link to comment Share on other sites More sharing options...
