Hi
How can I found the scale of a viewport on my drawing.
I want to write this informations in my cartouche
I have only one tab (layout1) I could have more than one viewport, they should be all the same scale
ex:
If the result of
Scale relative to Paper space= 0.0208xp
Then I'm going to write 1/4"=1'-0"
Thanks for your help
Hi
The next time I'm going to do a better search
The answer was just under my eyes:oops:
http://www.cadtutor.net/forum/showthread.php?t=29175
This is was I extract from this link
Sub PVPortScale()
Dim strVpScaleStd As String
Dim strVpScaleCust As String
Dim Entity As AcadEntity
Dim PVport As AcadPViewport
Dim objLayout As AcadLayout
Dim i As Integer
  For Each objLayout In ThisDrawing.Layouts
     If objLayout.Name <> "Model" Then
        ThisDrawing.ActiveLayout = objLayout
       ThisDrawing.MSpace = False
        For i = 1 To objLayout.Block.Count - 1 'avoid primary Paperspace PViewport
           Set Entity = objLayout.Block.Item(i)
           If TypeOf Entity Is AcadPViewport Then
              Set PVport = Entity
              strVpScaleStd = PVport.StandardScale
              strVpScaleCust = PVport.CustomScale
              If strVpScaleCust > 0 Then
              Exit For
              End If
           End If
        Next
       End If
  Next
End Sub
Now I have to find out how compare my result with a list. The list contains the correspondence of results
ex. if strVpScaleStd = 30 the scale I have to write is 3/32"=1'0"
Have good day!
