Results 1 to 1 of 1
    Forum Newbie martymoose's Avatar
    AutoCAD 2010
    Nov 2008
    6
    Default Global Block Hatch Edit
    Hello,
    I need to globally edit hatch patterns on Layer 0 within blocks on a specific layer without exploding or bursting. Can this be done?
    BEDIT will allow me to make my changes, but I'm looking to isolate these changes to blocks only on layer M-HVAC-EXST-DUCT.
    This is a snipit of what I have so far:
    Code:
    (if (setq ss1 (ssget "_X" '((0 . "SOLID") (8 . "M-HVAC-EXST-DUCT"))))
    (command "_chprop" ss1 "" "Color" 9 "") "regenall")
    (if (setq ss2 (ssget "_X" '((0 . "HATCH") (2 . "SOLID") (8 . "M-HVAC-EXST-DUCT"))))
    (command "_chprop" ss2 "" "Color" 9 "") "regenall")
    This will effect all hatches on Layer M-HVAC-EXST-DUCT, but I need it to effect hatches on Layer 0 that are within blocks on that layer.
    I may be way off base in my approach.
    Any suggestions...
  1. Numerical Global Block Attribute
    By kristin in forum AutoLISP, Visual LISP & DCL
    Last Post: 16th Jun 2011, 10:52 am
  2. Global Block Changes
    By Kat in forum AutoCAD General
    Last Post: 24th Jun 2009, 10:15 pm
  3. Creating tool (lisp) for copy attribute and global attribute edit
    By MarcoW in forum AutoLISP, Visual LISP & DCL
    Last Post: 14th May 2009, 10:41 am
  4. global block
    By idontknow in forum AutoCAD Beginners' Area
    Last Post: 8th Oct 2008, 07:04 pm
  5. Global Spot Grade Edit.....
    By El Jefe '36 in forum AutoCAD Drawing Management & Output
    Last Post: 20th Nov 2007, 06:11 pm
