Results 1 to 3 of 3
    Junior Member
    Inventor 2010
    May 2009
    Greensboro, NC
    12
    Default inventor sketch to autocad sketch posible?
    im running inventor 2010 and i have a sketch of a sprocket (cut out of 3/4 plate). i then need the sketch in autocad 2008 so i can send it off to be torched on an nc cutting table. i realy dont want to redraw the sketch again. is there any tricky magical way to accoplish this???
    Super Member kencaz's Avatar
    kencaz's Computer Details
    XP Pro, Vista, Linux,W7
    HP,s Dell
    Mechanical
    kencaz's Discipline Details
    Designer/Machinist
    Mechanical
    AutoCAD 2013
    Jul 2007
    Las Vegas, NV
    759
    This link might help.
    http://discussion.autodesk.com/forum...sageID=6224705
    I have a similar issue in inventor 10. Sometimes I need export a 2D profile for our waterjet. I have to create an .idw file with the proper views of my feature, then export to dwg, open in Autocad, clean it up and save again as 2007 format.
    Hopefully, 2010 will be in my near future.
    KC
    Some of my AutoCAD and Inventor Pics and Videos...
    http://www.youtube.com/kencaz45
    Junior Member
    Inventor 2010
    May 2009
    Greensboro, NC
    12
    thanks kencaz it worked just like you said i realy apreciate it.
  1. Acad DWG into Inventor Sketch
    By BillB in forum Autodesk Inventor
    Last Post: 30th Jun 2009, 01:32 pm
  2. Inventor sketch method
    By adamk15 in forum Autodesk Inventor
    Last Post: 22nd Jun 2009, 04:18 pm
  3. help making a sketch for a truck using autocad
    By kikoks156 in forum AutoCAD Beginners' Area
    Last Post: 9th Dec 2008, 07:09 pm
  4. Export 3d Sketch to Autocad
    By mgigliotti in forum Autodesk Inventor
    Last Post: 14th Nov 2008, 04:58 pm
  5. How can I import a sketch to autocad?
    By nameIess in forum AutoCAD Beginners' Area
    Last Post: 21st Nov 2005, 04:03 pm
