Laurel Posted August 12, 2009 Share Posted August 12, 2009 I need to create a work plane which is perpendicular to a non-planar 3D line or axis. Is there an easy way to do this other than manually inputting the angle and offset? Quote Link to comment Share on other sites More sharing options...
shift1313 Posted August 12, 2009 Share Posted August 12, 2009 you can use the line and its endpoint to define a work plane. click your work plane button(or use ] ), select your line endpoint then select your line. Quote Link to comment Share on other sites More sharing options...
Laurel Posted August 12, 2009 Author Share Posted August 12, 2009 Excellent. Thanks Shifty. Quote Link to comment Share on other sites More sharing options...
