thanhan1983 Posted August 18, 2009 Share Posted August 18, 2009 I have a small problem on xreffing Image. Nomally, I usually save as PDF image in to .TIFT Image, and then I xref that TIFT Image to Cad. That work will made my drawing become greater size and my computer will work slowly. I don't know there is a way which xref PDF Image directly on Autocad 2008. Please show me any solution you know Thanks in advance! Quote Link to comment Share on other sites More sharing options...
Dipali Posted August 18, 2009 Share Posted August 18, 2009 to reduce the size, convert pdf image to dwf by using dwf writer as a printer. & than insert/xref/underlay dwf in dwg. Quote Link to comment Share on other sites More sharing options...
thanhan1983 Posted August 19, 2009 Author Share Posted August 19, 2009 That is also a good ideal, but I dont know how to convert Pdf image to dwf. Please describe more clearly. Thanks very much. Quote Link to comment Share on other sites More sharing options...
Dipali Posted August 19, 2009 Share Posted August 19, 2009 To covert pdf to dwf I open pdf file & go to print & slect 'Autodesk DWF Writer for 2D'(which gets automatically installed whe you install auotcad 2008 onward version in your computer) as printer and print so it creats dwf out of it. if it is multipage pdf select current page & print to dwf. repeat for each page of pdf. Quote Link to comment Share on other sites More sharing options...
thanhan1983 Posted August 19, 2009 Author Share Posted August 19, 2009 Im using Acrobat 7.0 Pro, maybe it doesn't support that funtion. I Will try to on Ver. later. Thanks. Quote Link to comment Share on other sites More sharing options...
