GCarr78 Posted August 18, 2009 Share Posted August 18, 2009 Okay, So I have a drawing that I have received from an civil engineer.... this drawing is oriented to the World UCS (surveying purposes I presume). As you can see (image attached), my ucs icon is aligned in the default location, the drawing is oriented as such, do you notice my cross hairs? They are aligned with the drawing not my ucs icon. My ucs is at their default settings... Anyone else run into this problem? is there a fix? I've tried aligning the ucs to the way I want it but it doesn't seem to work. Quote Link to comment Share on other sites More sharing options...
ReMark Posted August 18, 2009 Share Posted August 18, 2009 Can you change the angle of the crosshairs with the SNAPANG command? Quote Link to comment Share on other sites More sharing options...
alanjt Posted August 18, 2009 Share Posted August 18, 2009 type: ucs or, as remark said, check your SNAPANG an set it back to 0. Quote Link to comment Share on other sites More sharing options...
GCarr78 Posted August 19, 2009 Author Share Posted August 19, 2009 Many thanks ReMark! - That's what did it! Its amazing, the more you learn about this program, the more you find out you DON'T know. Cheers Quote Link to comment Share on other sites More sharing options...
ReMark Posted August 19, 2009 Share Posted August 19, 2009 Its amazing, the more you learn about this program, the more you find out you DON'T know. Damn if I don't say that at the end of each and every day I work with AutoCAD. This website contains a plethora of information. So much so I think my head is going to explode! Quote Link to comment Share on other sites More sharing options...
