humaironline Posted August 19, 2009 Share Posted August 19, 2009 Normally views are set by default. I made a drawing in which my object is rotated from top> Kindly give me a way to set view as per face of object. Quote Link to comment Share on other sites More sharing options...
fuccaro Posted August 19, 2009 Share Posted August 19, 2009 So rotate the UCS with 45deg. Enter the UCS command and play around with those options. You can either Rotate the UCS, or Align it with an object in the drawing. After the UCS is in place, use the PLAN command. Quote Link to comment Share on other sites More sharing options...
