+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 10 of 11
  1. #1
    Forum Newbie
    Using
    AutoCAD 2009
    Join Date
    Aug 2009
    Posts
    8
    Default Disappearing cross hairs, pick box
    When switching to paper space, the cross hairs, pick box disappear. When moving curser out to the toolbars, it shows back up. What has happened? It didn't use to be this way. I can not see to pick viewports to modify. I can not see to pick anything in the viewport. CAN SOMEONE PLEASE HELP? Has some setting changed?
  2. #2
    Computer Details
    ReMark's Computer Details
    Operating System:
    Windows 7 Pro 64-bit
    Computer:
    Thinkmate
    Motherboard:
    Intel DX58SO2 LGA1366 X58
    CPU:
    RAM:
    12GB (3x4GB) PC3-106000 DDR3
    Graphics:
    nVidia Quadro 4000, 2GB GDDR5
    Primary Storage:
    Secondary Storage:
    none
    Monitor:
    Discipline
    See details...
    ReMark's Discipline Details
    Occupation
    Discipline
    See details below.
    Details
    Using
    AutoCAD 2013
    Join Date
    Nov 2005
    Location
    Norwalk, CT USofA
    Posts
    33,477
    Default
    When did the problem first occur?
    Does this happen in all drawings?
  3. #3
    Super Moderator Tiger's Avatar
    Computer Details
    Tiger's Computer Details
    Operating System:
    Windows 7 Enterprise 64 bit
    Computer:
    Dell Precision M4500
    CPU:
    Intel Core i5 2.40GHz
    RAM:
    8GB
    Graphics:
    NVIDIA Quadro FX 880M
    Primary Storage:
    280 GB
    Monitor:
    2 x Samsung SyncMaster 2443 24''
    Using
    AutoCAD 2012
    Join Date
    Nov 2006
    Location
    Sthlm, Sweden
    Posts
    4,606
    Default
    When you swtich to Paper Space, does it look like a command is active at the commandline? Does the crosshair come back aftera while, ie the drawing takes a long time to load when switching? Does hitting Escape bring the crosshair back?
    Life doesn't suck, although we all go through periods when it may be easier to think that, than to discern the solution to whatever problem is the most formidable
    at the moment in one's personal UCS.
    Go to PLAN view instead. - Dadgad
  4. #4
    Forum Newbie
    Using
    AutoCAD 2009
    Join Date
    Aug 2009
    Posts
    8
    Default
    This problem only occurs on one computer, on all drawings. The same drawing file opened on a different computer does not have the problem. I do not have the crosshairs disapear in model space.
    When switching to Paper Space, the command line shows what ever command I am using (move, draw a line, etc.) I am just unable to see what I a doing on the screen. If I go ahead and pick a location (to draw a line, move, etc.) the command executes properly but I am unable to see where the crosshairs are located. If drawing a line, the line shows up, if moving a viewport (if I am lucky enough to pick it) the viewport will move. It does not seem to be in the middle of a command and hitting the escape button does not bring the crosshair back.
    Do you know if I have inadvertently picked some sort of setting that would make the crosshairs to disappear?
    Please help!!
  5. #5
    Computer Details
    Operating System:
    Computer:
    Thinkmate
    Motherboard:
    CPU:
    RAM:
    Graphics:
    Primary Storage:
    Secondary Storage:
    none
    Monitor:
    Discipline
    See details...
    Occupation
    Discipline
    See details below.
    Details
    Using
    AutoCAD 2013
    Join Date
    Nov 2005
    Location
    Norwalk, CT USofA
    Posts
    33,477
    Default
    Could this possibly be graphics card related (a drivers issue)?
    Is this computer that is experiencing the problem set up differently than the other?
    Are you up-to-date with the service pack for 2009?
  6. #6
    Computer Details
    Operating System:
    Computer:
    Thinkmate
    Motherboard:
    CPU:
    RAM:
    Graphics:
    Primary Storage:
    Secondary Storage:
    none
    Monitor:
    Discipline
    See details...
    Occupation
    Discipline
    See details below.
    Details
    Using
    AutoCAD 2013
    Join Date
    Nov 2005
    Location
    Norwalk, CT USofA
    Posts
    33,477
    Default
    According to AutoDesk:
    "This problem can occur when the value for snap spacing is larger than the current view of the drawing."
    Maybe this is your situation?
  7. #7
    Forum Newbie
    Using
    AutoCAD 2009
    Join Date
    Aug 2009
    Posts
    8
    Default
    This computer has been used for about 5 years with no problems. I don't think that it could be a graphics card problem, but I will check. It is not set up differently than any other computer, that is why I thought some sort of setting might have gotten picked.
    I might have been unclear, I am using version 2007. I will check for service packs.
    Thanks
  8. #8
    Forum Newbie
    Using
    AutoCAD 2009
    Join Date
    Aug 2009
    Posts
    8
    Default
    Snap Spacing...... FANTASTIC!! Since I didn't understand the problem would you mind telling me how to view the value for snap spacing? Thanks
  9. #9
    Forum Newbie
    Using
    AutoCAD 2009
    Join Date
    Aug 2009
    Posts
    8
    Default
    I got it, that was the problem...
    Thanks so much ReMark, you were a big help!!!
  10. #10
    Computer Details
    Operating System:
    Computer:
    Thinkmate
    Motherboard:
    CPU:
    RAM:
    Graphics:
    Primary Storage:
    Secondary Storage:
    none
    Monitor:
    Discipline
    See details...
    Occupation
    Discipline
    See details below.
    Details
    Using
    AutoCAD 2013
    Join Date
    Nov 2005
    Location
    Norwalk, CT USofA
    Posts
    33,477
    Default
    Another satisfied customer. Thank you for shopping at CADTutor.
    Glad to hear that your problem was solved simply by adjusting the snap spacing. Thanks for updating us on its status.
    You're good to go on adjusting snap increment values right?
Similar Threads
  1. white cross hairs when I click...anywhere (blipmode)
    By truant in forum AutoCAD General
    Last Post: 25th Sep 2012, 12:37 am
  2. My Cross Hairs Gone and No OSNAP Control
    By ziemerd in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 26th Feb 2009, 06:43 pm
  3. Flashing cross hairs
    By DANIEL in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 21st Feb 2008, 10:46 pm
  4. UCS and Cross Hairs
    By Paul Mc in forum AutoCAD Drawing Management & Output
    Last Post: 12th Nov 2007, 08:08 pm
  5. hi all...newbie here...question about CROSS HAIRS...
    By lmn1220 in forum AutoCAD Beginners' Area
    Last Post: 16th Jul 2006, 06:01 pm
Posting Permissions
  • You may not post replies
  • You may not edit your posts
