yrnomad Posted August 28, 2009 Posted August 28, 2009 I'm trying to make this routine not fail to reset the osmode variable if the user cancels the function between the arrow and the text inputs. How would I do that? ;;;****************HR************************* (defun c:hR (/ otmd osmd a b c) (setq otmd (getvar "orthomode")) (setq osmd (getvar "osmode")) (command "ortho" "off") (setvar "osmode" 695) (setq a (* 0.0333 (getvar "userr1"))) (setq b (* 0.1000 (getvar "userr1"))) (setq c (* 0.1 (getvar "userr1"))) (command "pline" pause "arc" "s" pause pause "L" "w" a 0.0 "L" b "") ;(setvar "osmode" 0) (setq textstart (getpoint "\nText start point: ")) (command "textstyle" "romans") (command "dtext" textstart c "") (setvar "orthomode" otmd) (setvar "osmode" 695) );end homerun. Quote
JohnM Posted August 28, 2009 Posted August 28, 2009 there have been many post on this subject here. just do a search and you will find more than you need Quote
SteveK Posted August 28, 2009 Posted August 28, 2009 One way is to use an error trap. Have a look at http://www.afralisp.net/lispa/lisp6.htm. ;;;****************HR************************* (defun c:hR (/ otmd osmd a b c [color=Blue]temperr[/color]) (setq otmd (getvar "orthomode")) (setq osmd (getvar "osmode")) [color=Blue] (setq temperr *error*) ;store *error* (setq *error* trap1) ;re-assign *error*[/color] (command "ortho" "off") (setvar "osmode" 695) (setq a (* 0.0333 (getvar "userr1"))) (setq b (* 0.1000 (getvar "userr1"))) (setq c (* 0.1 (getvar "userr1"))) (command "pline" pause "arc" "s" pause pause "L" "w" a 0.0 "L" b "") ;(setvar "osmode" 0) (setq textstart (getpoint "\nText start point: ")) (command "textstyle" "romans") (command "dtext" textstart c "") (setvar "orthomode" otmd) (setvar "osmode" 695) [color=Blue] (setq *error* temperr) ;restore *error*[/color] );end homerun. [color=Blue]; ERROR TRAP (defun trap1 (errmsg) ;define function (setq *error* temperr) ;restore *error* (setvar "orthomode" otmd) ;restore variable (setvar "osmode" osmd) ;restore variable (prompt "\nAn unknown error has occured or Escape has been pressed.\nProgram cancelled.\n") ;inform user (princ) )[/color] Not tested. Quote
gile Posted August 28, 2009 Posted August 28, 2009 Hi, Another way, nesting the redefined *error* function and declaring it local ;;;****************HR************************* (defun c:hR (/ [color=blue]*error*[/color] otmd osmd a b c) [color=blue];; redefine *error* (defun *error* (msg) (if (and msg (/= msg "Function cancelled")) (princ (strcat "\nError: " msg)) ) (setvar "orthomode" otmd) (setvar "osmode" osmd) (princ) )[/color] (setq otmd (getvar "orthomode")) (setq osmd (getvar "osmode")) (command "ortho" "off") (setvar "osmode" 695) (setq a (* 0.0333 (getvar "userr1"))) (setq b (* 0.1000 (getvar "userr1"))) (setq c (* 0.1 (getvar "userr1"))) (command "pline" pause "arc" "s" pause pause "L" "w" a 0.0 "L" b "") ;; (setvar "osmode" 0) (setq textstart (getpoint "\nText start point: ")) (command "textstyle" "romans") (command "dtext" textstart c "") [color=blue](*error* nil) ;_ restores variable calling *error*[/color] ) ;_ end homerun. Quote
alanjt Posted August 28, 2009 Posted August 28, 2009 give this a whirl: ;;;****************HR************************* (defun c:hR (/ *error* otmd osmd a b c) ;;; error handler (defun *error* (#Message) (and otmd (setvar "orthomode" otmd)) (and osmd (setvar "osmode" osmd)) (and #Message (or (member #Message '("console break" "Function cancelled" "quit / exit abort") ) ;_ member (princ (strcat "\nError: " #Message)) ) ;_ or ) ;_ and ) ;_ defun (setq otmd (getvar "orthomode")) (setq osmd (getvar "osmode")) (sevar "orthomode" 0) (setvar "osmode" 695) (setq a (* 0.0333 (getvar "userr1"))) (setq b (* 0.1000 (getvar "userr1"))) (setq c (* 0.1 (getvar "userr1"))) (command "pline" pause "arc" "s" pause pause "L" "w" a 0.0 "L" b "") ;(setvar "osmode" 0) (setq textstart (getpoint "\nText start point: ")) (command "textstyle" "romans") (command "dtext" textstart c "") ;; reset variables (*error* nil) );end homerun. *error* is a user redefinable subroutine. now, if you exit out of your routine, it will reset all variables (if defined). the MOST important thing you MUST REMEMBER is to localize the *error* handler. you want the original one after the routine is over. i also switched out your use of command for setvar on orthomode. Quote
Lee Mac Posted August 30, 2009 Posted August 30, 2009 I sometimes use WCMATCH instead of member/vl-position: (if (not (wcmatch (strcase msg) "*BREAK,*CANCEL*,*EXIT*")) (princ (strcat "\n** Error: " msg " **"))) Quote
alanjt Posted August 31, 2009 Posted August 31, 2009 I sometimes use WCMATCH instead of member/vl-position: (if (not (wcmatch (strcase msg) "*BREAK,*CANCEL*,*EXIT*")) (princ (strcat "\n** Error: " msg " **"))) another fine option. i wonder if one is one yields any better results. Quote
alanjt Posted September 1, 2009 Posted September 1, 2009 I just find that it is not as verbose... to each his own. i've seen the wcmatch way before, it's another nice method. that's the great thing about programming, you can accomplish the same thing 50 different ways. Quote
