Final7C Posted September 3, 2009 Posted September 3, 2009 Hey guys and Gals, The Problem: I am currently working on multiple drawings in NAD83 Coordinates, and I need to call out all of the standard things. Corners, and the like. Now, the problem is I am not finding any "Place Coordinate" command. (I am too used to Microstation) Anyway, So I was wondering if you guy/gals knew of any command that I could use that would automatically place coordinate readout text into the drawing, with a leader. I have thought about writing my own script for it, but frankly, that just seems like a whole lot of work for a problem that may already be solved. Thanks, Quote
chulse Posted September 3, 2009 Posted September 3, 2009 I think DIMORDINATE is what you are looking for. I've seen several lisps that may help automate what you are trying to do. Try a search here for them...(I don't have any off hand..) Quote
alanjt Posted September 3, 2009 Posted September 3, 2009 I have thought about writing my own script for it, but frankly, that just seems like a whole lot of work for a problem that may already be solved. Thanks, lol, that's just too funny. Quote
Final7C Posted September 3, 2009 Author Posted September 3, 2009 I know.. I'm lazy... but thanks for the help. Quote
alanjt Posted September 3, 2009 Posted September 3, 2009 (and (setq Point (getpoint "\nSpecify point: ")) (setq Point (mapcar 'rtos (trans Point 1 0)) Value (strcat "NORTHING: " (cadr Point) "\\P" "EASTING: " (car Point) "\\P" "ELEV.: " (caddr Point) ) ) ) Quote
lpseifert Posted September 3, 2009 Posted September 3, 2009 Create a Point; then create 2 fields using the point as the Object Type and Position as the Property. Specify Y position for Northing and X position as the Easting. Under Additional Format you can specify prefixes, e.g. N: E:. then make it a block using the point as the insert point. Quote
nesteele Posted September 29, 2009 Posted September 29, 2009 i would like to preface this by saying that i have not had hardly any experience in autocad past simply drawing shapes and polylines... i'm working on landscape construction documents for school and i was wondering how to set a particular point as 0,0 for the coordinate system so that i could base all my coordinates off of that beginning point. once i have that, how do i even dimension it to say: N: 532' 6" E: 401' 3" I tried using directions above and could not format the text to read how i wanted it to... Quote
